Home » Eclipse Projects » Eclipse Platform » Working example of revealing a tree node
Working example of revealing a tree node [message #51324] Wed, 28 May 2003 05:35 Go to next message
Originally posted by: pavan_podila.persistent.co.in
Can someone please show me a working example of how to reveal a particular
node in a tree. I've tried the code given in the Eclipse Article but in
vain. Please help asap.
thanks,
O-o-o-o-o-o-o-o-o-o-o-o-o-o-o-o-o-O
Pavan Podila
Member of Technical Staff
Persistent Systems Pvt. Ltd.
Phone: 567 8900 X 479
http://pavanpodila.cjb.net/
Re: Working example of revealing a tree node [message #51408 is a reply to message #51324] Wed, 28 May 2003 05:54 Go to previous messageGo to next message
Originally posted by: stelian.iancu.gmxREMOVE.net
"Pavan Podila" <pavan_podila@persistent.co.in> wrote in message
news:bb1vr5$iso$1@rogue.oti.com...
Revealing, like in expanding ? Or ?
For selecting an item, see the setSelection(TreeItem[] items) method of the
Tree class. If you want to expand an Item, see the setExpanded(boolean
expanded) method of TreeItem.
> thanks,
> Pavan Podila
Re: Working example of revealing a tree node [message #52886 is a reply to message #51408] Wed, 28 May 2003 23:25 Go to previous messageGo to next message
I want to set the selection on this node in the tree and expand all parents
if necessary. There is a method called reveal() which can be called on the
treeviewer (I am using a treeviewer and have knowledge of only the objects
and not in terms of treeitems), but it is not doing it's job. Can someone
tell me how the reveal() method can be used on a treeviewer ???
"Stelian Iancu" <stelian.iancu@gmxREMOVE.net> wrote in message
news:bb211t$jo0$1@rogue.oti.com...
particular
the
> > thanks,
> > Pavan Podila
Re: Working example of revealing a tree node [message #54124 is a reply to message #52886] Thu, 29 May 2003 12:14 Go to previous messageGo to next message
Originally posted by: knut_radloff.oti.com
reveal only shows an element (i.e., expands the parent elements and scrolls the tree if necessary). Use setSelection(ISelection,
true) if you want to set the selection and make the selected element visible.
In the JFace Tree Viewer article example I added
viewer.setSelection(new StructuredSelection((Model)event.receiver()), true);
to MovingBoxContentProvider.add to select and reveal a newly added item.
Knut
"Pavan Podila" <pavan_podila@persistent.co.in> wrote in message news:bb3uh1$8ma$1@rogue.oti.com...
> particular
> the
> > > thanks,
> > > Pavan Podila
Re: Working example of revealing a tree node [message #55427 is a reply to message #54124] Fri, 30 May 2003 03:58 Go to previous messageGo to next message
Hello Knut,
Could you send me your new article source. I've tried using the
setSelection() but it fails and I'm not seeing any selection made on my
treeviewer.
thanks
"Knut Radloff" <knut_radloff@oti.com> wrote in message
news:bb5bkk$6o6$1@rogue.oti.com...
visible.
true);
> Knut
parents
the
objects
someone
> > particular
in
of
> > the
> > > > thanks,
> > > > Pavan Podila
Re: Working example of revealing a tree node [message #66071 is a reply to message #55427] Fri, 06 June 2003 19:13 Go to previous message
This is MovingBoxContentProvider.add
public void add(DeltaEvent event) {
Object movingBox = ((Model)event.receiver()).getParent();
viewer.refresh(movingBox, false);
viewer.setExpandedState(movingBox, true);
// viewer.reveal((Model)event.receiver());
Knut
"Pavan Podila" <pavan_podila@persistent.co.in> wrote in message news:bb72td$b29$1@rogue.oti.com...
> Hello Knut,
> treeviewer.
> thanks
> visible.
> true);
> > Knut
> parents
> the
> objects
> someone
> > > particular
> in
> of
> > > the
> > > > > thanks,
> > > > > Pavan Podila
Previous Topic:Opening Java Editor from Double Click
Next Topic:How to add a builder?
Current Time: Mon Jul 07 23:58:47 EDT 2025
Powered by FUDForum. Page generated in 0.04179 seconds
