Home » Archived » XML Schema Definition (XSD) » i want to make a tree(control) from a XSD file
i want to make a tree(control) from a XSD file [message #51319] |
Tue, 24 August 2004 01:37  |
Originally posted by: feminie.hanmail.net
hi,
as i wrote the title of this article, i want to make a tree(control) from a
XSD file
but i can't load a XSD file.. T.T please help me
and let me know how can I parsing XSD file and make the tree(control)
you got the point but...... [message #51586 is a reply to message #51487] |
Wed, 25 August 2004 02:13   |
you knew my point exactly.
but I got the error when I tried load an XSD
I debugged that method loadAndPrint() in XSDMainTest class
public void loadAndPrint(String xsdFile)
throws Exception
File file = new File(xsdFile);
URI uri;
if(file.isFile())
uri = URI.createFileURI(file.getCanonicalFile().toString());
else
uri = URI.createURI(xsdFile);
ResourceSet resourceSet = new ResourceSetImpl();
XSDResourceImpl xsdMainResource =
(XSDResourceImpl)resourceSet.createResource(URI.createURI("*.xsd "));
xsdMainResource.setURI(uri);
xsdMainResource.load(resourceSet.getLoadOptions()); <----------
this line has occured exception
this is org.eclipse.emf.ecore.resource.impl.ResourceImpl class
public void load(Map options) throws IOException
if (!isLoaded)
URIConverter uriConverter = getURIConverter();
InputStream inputStream = uriConverter.createInputStream(getURI());
try
load(inputStream, options); <---------- this line has occured
exception
finally
inputStream.close();
exception is MissingResourceException
I have no idea about this error, so I couldn't load an XSD now.... but in
EMF project, I can load xsd file without any error
when I run this codes, I can get parsed document object
xsdParser = new XSDParser();
XSDSchema xsdSchema = XSDFactory.eINSTANCE.createXSDSchema();
xsdParser.setSchema(xsdSchema);
xsdParser.parse(uri);
xmlDoc = xsdParser.getDocument();
but this codes don't work properly.
Element rootElement = xmlDOM.getDocumentElement();
xsdSchema.setElement(rootElement); <--- this method cause exception
what is the reason why this thing happen? and how can I solve this problem,
please let me know and help
one more thing!
how can I use org.eclipse.xsd.presentation.XSDEditor class for my project as
a module to insert
I can't import org.eclipse.xsd.presentation namespace.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:<cgf9vf$uv3$1@eclipse.org>...
> Cheolmin,
> You mean a tree view just like in the Sample XML Schema editor? Have a
> look at org.eclipse.xsd.presentation.XSDEditor for that. The sample in
> org.eclipse.xsd.test.XSDMainTest will help you with how to load an XSD.
> Cheolmin Shin wrote:
> >hi,
a
> >XSD file
> >Thanks,
news:cgf9vf$uv3$1@eclipse.org...
> Cheolmin,
> >hi,
a
> >XSD file
> >Thanks,
Re: you got the point but...... [message #51632 is a reply to message #51586] |
Wed, 25 August 2004 07:30   |
--------------050402010700060307060302
Content-Type: text/plain; charset=us-ascii; format=flowed
Cheolmin,
When using XSD standalone, you must include xsd.resource.jar on the
classpath (or it won't be able to find plugin.properties). Without
seeing a stack trace for your setElement problem, I can only guess as to
the problem, and I don't think you've even given me enough clues to
guess. To use org.eclipse.xsd.editor in your own project, you need to
add a dependency for it to your plugin.xml.
> throws Exception
> URI uri;
> if(file.isFile())
> else
> if (!isLoaded)
> try
>exception
> finally
>one more thing!
>a module to insert
>>Cheolmin,
>>>hi,
>a
>>>XSD file
>>>Thanks,
>>Cheolmin,
>>>hi,
>a
>>>XSD file
>>>Thanks,
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Cheolmin,<br>
<br>
to the problem, and I don't think you've even given me enough clues to
add a dependency for it to your plugin.xml.<br>
<br>
<br>
<blockquote cite="midcgham9$39i$1@eclipse.org" type="cite">
<pre wrap="">you knew my point exactly.
throws Exception
URI uri;
if(file.isFile())
else
if (!isLoaded)
try
exception
finally
one more thing!
a module to insert
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
news:<a class="moz-txt-link-rfc2396E" href="mailto:cgf9vf$uv3$1@eclipse.org"><cgf9vf$uv3$1@eclipse.org></a>...
</pre>
<blockquote type="cite">
<pre wrap="">Cheolmin,
</pre>
<pre wrap="">hi,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->a
</pre>
<pre wrap="">XSD file
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:cgf9vf$uv3$1@eclipse.org">news:cgf9vf$uv3$1@eclipse.org</a>...
</pre>
</pre>
<pre wrap="">hi,
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------050402010700060307060302--
Ed, I did it!! thank you very much ^^; [message #51771 is a reply to message #51632] |
Wed, 25 August 2004 23:30  |
Thanks for your help...
I solved that problem(load error) as I include xsd.resource.jar
setElement problem has gone at the same time
news:cght46$2ol$1@eclipse.org...
> Cheolmin,
> > throws Exception
> > URI uri;
> > if(file.isFile())
> > else
> > if (!isLoaded)
> > try
> >exception
> > finally
in
problem,
> >one more thing!
as
> >a module to insert
> >>Cheolmin,
> >>>hi,
from
> >a
> >>>XSD file
> >>>Thanks,
> >>Cheolmin,
> >>>hi,
from
> >a
> >>>XSD file
> >>>Thanks,
Re: i want to make a tree(control) from a XSD file [message #590937 is a reply to message #51319] |
Tue, 24 August 2004 07:52  |
Cheolmin,
>hi,
>XSD file
>Thanks,
you got the point but...... [message #590993 is a reply to message #51487] |
throws Exception
URI uri;
if(file.isFile())
else
if (!isLoaded)
try
exception
finally
one more thing!
a module to insert
> Cheolmin,
> >hi,
a
> >XSD file
> >Thanks,
> Cheolmin,
> >hi,
a
> >XSD file
> >Thanks,
this is stacktrace [message #591014 is a reply to message #51586] |
Wed, 25 August 2004 02:59  |
java.util.MissingResourceException: Missing properties:
org/eclipse/xsd/plugin.properties
at org.eclipse.emf.common.EMFPlugin.getBaseURL(EMFPlugin.java:1 17)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:687)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2020)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1465)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2221)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentIm
pl.java:1202)
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:822)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:470)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:867)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:741)
at org.eclipse.xsd.examples.infosetTest.loadAndPrint(infosetTes t.java:200)
org.eclipse.xsd.examples.EclipseXSDDemo2.xsdParsingResult(Ec lipseXSDDemo2.ja
va:169)
at org.eclipse.xsd.examples.EclipseXSDDemo2.main(EclipseXSDDemo 2.java:180)
my code call that loadAndPrint() method
XSDMainTest myMainTest = new XSDMainTest();
myMainTest.loadAndPrint("d:\\project\\po.xsd");
Re: you got the point but...... [message #591036 is a reply to message #51586] |
Cheolmin,
> throws Exception
> URI uri;
> if(file.isFile())
> else
> if (!isLoaded)
> try
>exception
> finally
>one more thing!
>a module to insert
>>Cheolmin,
>>>hi,
>a
>>>XSD file
>>>Thanks,
>>Cheolmin,
>>>hi,
>a
>>>XSD file
>>>Thanks,
<html>
<head>
<title></title>
</head>
Cheolmin,<br>
<br>
<br>
<br>
throws Exception
URI uri;
if(file.isFile())
else
if (!isLoaded)
try
exception
finally
one more thing!
a module to insert
</pre>
</pre>
<pre wrap="">hi,
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
<pre wrap="">hi,
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Ed, I did it!! thank you very much ^^; [message #591089 is a reply to message #51632] |
> Cheolmin,
> > throws Exception
> > URI uri;
> > if(file.isFile())
> > else
> > if (!isLoaded)
> > try
> >exception
> > finally
in
problem,
> >one more thing!
as
> >a module to insert
> >>Cheolmin,
> >>>hi,
from
> >a
> >>>XSD file
> >>>Thanks,
> >>Cheolmin,
> >>>hi,
from
> >a
> >>>XSD file
> >>>Thanks,
Current Time: Thu Jul 31 02:28:41 EDT 2025
Powered by FUDForum. Page generated in 0.06498 seconds
