Home » Eclipse Projects » Nebula » making column truly fixed, setMovable(false) on column can be worked around
making column truly fixed, setMovable(false) on column can be worked around [message #51313] Wed, 02 April 2008 04:10 Go to next message
Hi-ya,
I have a Grid, with GridTreeViewerColumn(s)and for my first column I do
column.setMovable(false) and my other columns are column.setMovable(true).
Now my first column I cannot move directly, but if I go and move one of
the other columns to the left of my first column, the first column will
will be displaced to the right, in other words it will move to to the
right of the column I am moving.
Does anyone have an idea how I can make it so that the first column is
fixed, ie not movable, even if another column is moved before it?
kentusha
Re: making column truly fixed, setMovable(false) on column can be worked around [message #51346 is a reply to message #51313] Wed, 02 April 2008 04:44 Go to previous message
sorry I messed up, I meant GridColumn not GridTreeViewerColumn.
Re: making column truly fixed, setMovable(false) on column can be worked around [message #589198 is a reply to message #51313] Wed, 02 April 2008 04:44 Go to previous message
Previous Topic:making column truly fixed, setMovable(false) on column can be worked around
Next Topic:[CompositeTable] a question of size
Current Time: Sun Jul 13 18:36:07 EDT 2025
Powered by FUDForum. Page generated in 0.04391 seconds
