Home » Archived » BIRT » BIRT 2.0: The BIRT PMC is Looking for Your Input
BIRT 2.0: The BIRT PMC is Looking for Your Input [message #51298] Fri, 24 June 2005 13:39 Go to next message
All,
The BIRT PMC is starting the planning process for BRT 2.0, which we are
targeting for Dec this year. We want to hear from the community what
you would like to see in the BIRT 2.0 release.
If you have not done so already, please log your enhancement requests in
Bugzilla for BIRT. Or, if there is already an enhancement request for
the feature, please add your vote for that feature (and add information
on your usage scenario/needs).
The BIRT PMC would love to hear what you would like to see in the BIRT
2.0 release.
Thanks in advance for your input.
Paul Clenahan
BIRT PMC
Re: BIRT 2.0: The BIRT PMC is Looking for Your Input [message #51464 is a reply to message #51298] Fri, 24 June 2005 17:33 Go to previous messageGo to next message
Originally posted by: kimandrew.yahoo.com
I would like to see XML schema support similar to Microsoft Infopath.
In Infopath, I can specify XML schema as data source, and then use a sample
XML document instance to test the form. I would like to able to do the same
in BIRT. i.e. specify XML schema as the data source and use sample XML
document to test the report while developing the report.
"Paul Clenahan" <pclenahan@actuate.com> wrote in message
news:d9hggv$325$1@news.eclipse.org...
> All,
> 2.0 release.
> Paul Clenahan
> BIRT PMC
Re: BIRT 2.0: The BIRT PMC is Looking for Your Input [message #51519 is a reply to message #51464] Fri, 24 June 2005 23:01 Go to previous messageGo to next message
Ak,
Could you please log this into Bugzilla. If you set the version to 2.0
and list it as an enhancement, it will allow the PMC team to track the
issue. In addition, you will be given notification of status changes as
we work with this.
Also, one issue with XML is a data source is that in many cases it is
difficult to determine the proper way to de-normalize the XML hierarchy
into a collection of rows and columns. How is this handled in Infopath?
Any thoughts would be helpful,
Scott Rosenbaum
BIRT PMC
>>All,
>>2.0 release.
>>Paul Clenahan
>>BIRT PMC
Re: BIRT 2.0: The BIRT PMC is Looking for Your Input [message #51544 is a reply to message #51464] Fri, 24 June 2005 23:49 Go to previous messageGo to next message
Originally posted by: mohsen_s.myrealbox.com
+ Unicode support in PDF/other formats export.
+ Word doc/Excel/Text/XML export
"ak" <kimandrew@yahoo.com> wrote in message
news:d9hu85$ik9$1@news.eclipse.org...
> > All,
> > 2.0 release.
> > Paul Clenahan
> > BIRT PMC
Re: BIRT 2.0: The BIRT PMC is Looking for Your Input [message #52895 is a reply to message #51298] Thu, 30 June 2005 11:03 Go to previous messageGo to next message
I don't see a way to vote for existing enhancement requests. Is it
possible voting isn't turned on?
Re: BIRT 2.0: The BIRT PMC is Looking for Your Input [message #53235 is a reply to message #51298] Sat, 02 July 2005 12:39 Go to previous message
Originally posted by: my_name_with.between_names.lombardisoftware.com
I would strongly suggest OLAP support in some form or fashion. Posted a
enhancement on it as requested:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=102554
> All,
> 2.0 release.
> Paul Clenahan
> BIRT PMC
Previous Topic:last birt cvs and eclispe 3.1
Next Topic:Spring, Hibernate
Current Time: Sun Jul 27 06:10:30 EDT 2025
Powered by FUDForum. Page generated in 0.03969 seconds
