Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Access JET Conext variables in jet
Access JET Conext variables in jet [message #51294] |
Wed, 20 September 2006 12:59  |
Hi ,
how to access the passVariables that I have passed from the JETContext
inside the *.jet files.
The code snippet is
HashMap vMap = new HashMap();
vMap.put("projectName", modelFile.getProject().getName());
vMap.put("fileName", modelFile.getName() + "-strutsconfig.xml");
JET2Context context = new JET2Context(StrutsConfigType.class);
context.setVariables(vMap);
System.out.println("Artifact to be generated for "
+ modelFile.getName());
// TODO attach a progress monitor
IStatus transformStatus = JET2Platform.runTransformOnResource(
STRUTS_CONFIG_FILE_TRANSFORMER, modelFile,
new NullProgressMonitor());
if (transformStatus.isOK()) {
IStatus status = JET2Platform.runTransform(
STRUTS_CONFIG_FILE_TRANSFORMER, context,)
i need to access the vMap variables in the main.jet
<%@taglib prefix="ws" id="org.eclipse.jet.workspaceTags" %>
<c:setVariable var="vProjectName" select="{$projectName"/>
Thanks in advance .
Kamesh
Re: Access JET Conext variables in jet [message #51461 is a reply to message #51294] |
Thu, 21 September 2006 08:52   |
Kamesh:
There is a variant of runTransformOnResource that takes a map
IStatus status = JET2Platform.runTransformOnResource(
STRUTS_CONFIG_FILE_TRANSFORMER, modelFile, vMap, new NullProgressMonitor());
Your templates should then be able to get the variables in XPath expressions
such as:
<ws:project name="{$projectName}"/>
Also note that runTransformOnResource predefines a number of JET variables
derived from the resource name. All the names are prefixed with
org.eclipse.jet.resource, and then follow the IResource getter names. For
example:
org.eclipse.jet.resource.project.name
is the same as your variable $projectName. You can see all the variables
defined by viewing the Java doc for
org.eclipse.jet.taglib.workspace.WorkspaceContextExtender.lo adResourceAsSource()
Next, you should consider doing the calculation of 'projectName' and
'fileName' directly in your main.jet template. Based what I see in your
examples, it is part of your transformation proper. The following in
main.jet should work, assuming your invoke with
runTransformationOnResource():
<c:setVariable var="projectName"
select="$org.eclipse.jet.resource.project.name" />
<c:setVariable var="fileName" select="concat($org.eclipse.jet.resource.name,
'-structsconfig.xml')" />
Lastly, I notice your example has:
In general, you do not need (or want) the { and } braces in XPath
expressions for attributes named 'select' and 'test'. The tag handlers are
already expecting XPath expressions. In other attributes, the { and }
deliniate XPath expressions which are evaluated and converted to strings
prior to passing the attribute value to the tag handler.
In your case, <c:setVariable var="vProjectName" select="{$projectName}"/>
would likely result in an XPath parse error, because the setVariable tag
handler would try to interpret the VALUE of $projectName as an XPath
expression.
Paul Elder
JET Lead
"Kamesh Sampath" <kamesh_sampath@msn.com> wrote in message
news:eers14$rkp$1@utils.eclipse.org...
> Hi ,
> The code snippet is
> Thanks in advance .
> Kamesh
Re: Access JET Conext variables in jet [message #51737 is a reply to message #51461] |
Thu, 21 September 2006 13:37   |
Paul Elder wrote:
> Kamesh:
> such as:
> example:
> expression.
> Paul Elder
> JET Lead
>> Hi ,
>> The code snippet is
>> Thanks in advance .
>> Regards,
>> Kamesh
Paul,
Thanks for your help will try incorporating the same and let you know.
The last error w.r.t {} was due to a typo as per the JET documentation
am using {$variableName} to access all the variables.
Thanks once again for the early response.
Kamesh
Re: Access JET Conext variables in jet [message #52008 is a reply to message #51737] |
Fri, 22 September 2006 09:03   |
Kamesh:
If you find problems in the documentation, please submit bugzilla defects.
The following link will fill in most of the required information:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT& ;version=-&component=JET&rep_platform=PC&op_sys= Windows%20XP&priority=P3&bug_severity=normal&bug _status=NEW&assigned_to=pelder%40ca.ibm.com&qa_conta ct=&cc=&bug_file_loc=http%3A%2F%2F&short_desc=&a mp;comment=&commentprivacy=0&keywords=&dependson =&blocked=&maketemplate=Remember%20values%20as%20boo kmarkable%20template&form_name=enter_bug
(The link is pretty ugly - I have it in my bookmarks.)
Paul
news:eeuil4$9bf$1@utils.eclipse.org...
> Paul Elder wrote:
>> Kamesh:
>> expressions such as:
>> variables derived from the resource name. All the names are prefixed with
>> example:
>> select="concat($org.eclipse.jet.resource.name, '-structsconfig.xml')" />
>> are already expecting XPath expressions. In other attributes, the { and }
>> expression.
>> Paul Elder
>> JET Lead
>>> Hi ,
>>> The code snippet is
>>> Thanks in advance .
>>> Regards,
>>> Kamesh
> Paul,
> Thanks for your help will try incorporating the same and let you know. The
> last error w.r.t {} was due to a typo as per the JET documentation am
> Kamesh
Re: Access JET Conext variables in jet [message #52059 is a reply to message #52008] |
Fri, 22 September 2006 09:29   |
Paul Elder wrote:
> Kamesh:
> Paul
>> Paul Elder wrote:
>>> Kamesh:
>>> example:
>>> expression.
>>> Paul Elder
>>> JET Lead
>>>> Hi ,
>>>> The code snippet is
>>>> Thanks in advance .
>>>> Regards,
>>>> Kamesh
>> Paul,
>> Regards,
>> Kamesh
>thanks paul !
By the way am planning to contribute an article to Eclipse on EMF and
JET transformations , all your valuable inputs are required . Please let
me know i can post some questions to you personally ( if you dont mind')
Kamesh
Re: Access JET Conext variables in jet [message #52141 is a reply to message #52086] |
Fri, 22 September 2006 09:51  |
Paul Elder wrote:
> Kamesh:
> I'd be pleased to answer any questions, and to review your article.
> But, please post questions to the group - its a good way to share knowledge.
> If you have a draft you'd like me to review, you can send it to me directly.
> Paul
>>>>>> snip!
>> By the way am planning to contribute an article to Eclipse on EMF and JET
>> transformations , all your valuable inputs are required . Please let me
>> Regards,
>> Kamesh
thanks paul . will do that as you said sharing knowledge among all
newsgroup folks would be great. I have just started with the article
will dftnly send the article for your review once the draft is ready .
as JET2 lead you will know the flips and flops well .
Thanks for your courtesy.
Kamesh
Re: Access JET Conext variables in jet [message #591563 is a reply to message #51294] |
Kamesh:
such as:
example:
expression.
Paul Elder
JET Lead
> Hi ,
> The code snippet is
> Thanks in advance .
> Kamesh
Re: Access JET Conext variables in jet [message #591672 is a reply to message #51461] |
Paul Elder wrote:
> Kamesh:
> such as:
> example:
> expression.
> Paul Elder
> JET Lead
>> Hi ,
>> The code snippet is
>> Thanks in advance .
>> Regards,
>> Kamesh
Paul,
Kamesh
Re: Access JET Conext variables in jet [message #591747 is a reply to message #51737] |
Kamesh:
Paul
> Paul Elder wrote:
>> Kamesh:
>> example:
>> expression.
>> Paul Elder
>> JET Lead
>>> Hi ,
>>> The code snippet is
>>> Thanks in advance .
>>> Regards,
>>> Kamesh
> Paul,
> Kamesh
Re: Access JET Conext variables in jet [message #591755 is a reply to message #52008] |
Paul Elder wrote:
> Kamesh:
> Paul
>> Paul Elder wrote:
>>> Kamesh:
>>> example:
>>> expression.
>>> Paul Elder
>>> JET Lead
>>>> Hi ,
>>>> The code snippet is
>>>> Thanks in advance .
>>>> Regards,
>>>> Kamesh
>> Paul,
>> Regards,
>> Kamesh
>thanks paul !
Kamesh
Re: Access JET Conext variables in jet [message #591759 is a reply to message #52059] |
Fri, 22 September 2006 09:43  |
Kamesh:
Paul
>>>>> snip!
> Kamesh
Re: Access JET Conext variables in jet [message #591780 is a reply to message #52086] |
Paul Elder wrote:
> Kamesh:
> Paul
>>>>>> snip!
>> Regards,
>> Kamesh
Kamesh
Current Time: Mon Jul 21 22:11:53 EDT 2025
Powered by FUDForum. Page generated in 0.06227 seconds
