Home » Language IDEs » AspectJ » Aspect priority(weaving order)
Aspect priority(weaving order) [message #51268] Tue, 03 May 2005 10:14 Go to next message
Originally posted by: absolutntn.netscape.net
Hi, I'm using Eclise 3.0.2 with AspectJ 1.5.0M1
The problem is I can't catch the pointcut on the method i "introduced" in
another aspect.
i have the following model:
interface ISomeInterface{
public void setProperty(String newValue);
aspect ASomeInterfaceImpl{
private String ISomeInterface._property;
public void ISomeInterface.setProperty(String newValue){
_property = newValue;
aspect AEventListener{
pointcut propertyChanged() :
execution(ISomeInterface+.setProperty(..));
after() : propertyChanged() {
// event handling code
// never reached
// so i tried to change the pointcut to:
set(String ISomeInterface._property);
// but it doesn't work either :(((
so, from i can see the AEventListener is weaved(???) before the
ASomeIntImpl(which defines the setProperty default behaviour).
Re: Aspect priority(weaving order) [message #51295 is a reply to message #51268] Tue, 03 May 2005 10:50 Go to previous messageGo to next message
Originally posted by: clemas.uk.ibm.com
Does that pointcut compile?
You need a return value for the setProperty() method()
pointcut propertyChanged():
execution(* ISomeInterface+.setProperty(..));
You can't get into ordering problems since the changes to the type
system (your method ITD) happen before the advice matching.
This works for me:
interface I { public void m(String s); }
aspect X { public void I.m(String s) {} }
aspect Y { after(): execution(* I+.m(..)) {} }
C:\>ajc X.aj Y.aj I.java -showWeaveInfo
Type 'X' (X.aj:1) advised by after advice from 'Y' (Y.aj:1)
Type 'I' (I.java) has intertyped method from 'X' (X.aj:'void
I.m(java.lang.String)')
The first line of weaving info indicates the pointcut matched.
I must admit I am on 1.5.0M2 but I don't think anything in that area for
ages.
cheers,
Andy.
> another aspect.
> // never reached
Re: Aspect priority(weaving order) [message #51320 is a reply to message #51295] Tue, 03 May 2005 12:31 Go to previous message
yeah, u r right, it works in isolation, so it must be some my internal bug
thank for the help anyway - at least i know it's my fault and not yours)))))
"Andy Clement" <clemas@uk.ibm.com> wrote in message
news:d583ee$5v6$1@news.eclipse.org...
> This works for me:
> ages.
> cheers,
> Andy.
in
> > another aspect.
> > // never reached
Re: Aspect priority(weaving order) [message #587971 is a reply to message #51268] Tue, 03 May 2005 10:50 Go to previous message
This works for me:
ages.
cheers,
Andy.
> another aspect.
> // never reached
Re: Aspect priority(weaving order) [message #587984 is a reply to message #51295] Tue, 03 May 2005 12:31 Go to previous message
> This works for me:
> ages.
> cheers,
> Andy.
in
> > another aspect.
> > // never reached
Previous Topic:Aspect priority(weaving order)
Next Topic:Looking for Class File ByteCode Weaving for Eclipse 2.1
Current Time: Fri Jul 18 00:39:18 EDT 2025
Powered by FUDForum. Page generated in 0.27249 seconds
