Home » Archived » XML Schema Definition (XSD) » How to retrieve Attributes for a complex ElementDeclaration
| How to retrieve Attributes for a complex ElementDeclaration [message #51267] |
Mon, 23 August 2004 17:51  |
Originally posted by: gj.puredge.com
Given the schema fragment:
<xsd:element name="Test">
<xsd:complexType>
<xsd:choice>
<xsd:element ref="comment"></xsd:element>
<xsd:element name="choice2" type="xsd:string"></xsd:element>
</xsd:choice>
<xsd:attribute name="Attribute" type="xsd:string"></xsd:attribute>
</xsd:complexType>
</xsd:element>
From the complexType particle, getTerm() gets the "choice" ModelGroup.
Which method gets the attribute(s)?
Sorry for such a newbie question.
| Re: How to retrieve Attributes for a complex ElementDeclaration [message #51538 is a reply to message #51512] |
Tue, 24 August 2004 10:37   |
--------------020405000909090205010801
Content-Type: text/plain; charset=us-ascii; format=flowed
Gary,
Yes, that's exactly right. ;-)
Gary J wrote:
>Thanks Ed,
>getAttributeContents vs getAttributeUses
>Am I correct that this is another example of the difference between the
>"Concrete" and "Abstract" representations of the schema?
>The Concrete representation is what's actually written in the schema file
>itself whereas Abstract is (sort of) the "expanded" version of the schema
>with all the inherited types, groups, refs, etc available.
>I'd use the Concrete model if I wanted to serialize (write) the schema and
>the Abstract to walk the schema elements, among other things.
>I think I'm actually starting to get a clue. That perhaps qualifies me a
>"cluebie" .
>"Ed Merks" <merks@ca.ibm.com> wrote in message
>news:cgf9ov$ujg$1@eclipse.org...
>Gary,
>Yes, the contents will always be of type XSDAttributeUse, so there's no
>need for a instanceof check. Note that getAttributeContents returns the
>physically contained attribute declarations whereas getAttributeUses
>will get the inherited ones as well as the local ones just as getContent
>returns the physically contained content model (particle/simple type)
>whereas getContentType will return the inherited content model as well.
>Gary J wrote:
>>I think I found what I need. Here's some code I wrote to print out
>>attributes for an element. Correct me if I'm wrong.
>>Starting with: ElementDeclaration element
>>XSDTypeDefinition type = element.getTypeDefinition();
>>if (type instanceof XSDComplexTypeDefinition)
>> EList list = ((XSDComplexTypeDefinition) type).getAttributeContents();
>> for (Iterator iter = list.iterator(); iter.hasNext();)
>> Object obj = iter.next();
>> if (obj instanceof XSDAttributeUse)
>> XSDAttributeUse a = (XSDAttributeUse) obj;
>> System.out.println(a.getAttributeDeclaration().getName());
>>I'm not sure if the results of getAttributeContents() are always an
>>instance
>>of XSDAttributeUse so I check just in case.
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
Yes, that's exactly right. ;-)<br>
<br>
<br>
Gary J wrote:<br>
<blockquote cite="midcgfjbg$i5q$1@eclipse.org" type="cite">
<pre wrap="">Thanks Ed,
"cluebie" .
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:cgf9ov$ujg$1@eclipse.org">news:cgf9ov$ujg$1@eclipse.org</a>...
Gary,
Gary J wrote:
</pre>
<blockquote type="cite">
<pre wrap="">I think I found what I need. Here's some code I wrote to print out
instance
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------020405000909090205010801--
| attribute use from declaration [message #54280 is a reply to message #51538] |
Wed, 27 October 2004 02:49   |
Sorry to drop this question..may be stupid one
How can one get XSDAttributeUse for an attribute from attributedeclaration.
best
roy
Ed Merks wrote:
> Gary,
> Gary J wrote:
>>Thanks Ed,
>>"cluebie" .
>>Gary,
>>>instance
| Re: attribute use from declaration [message #54307 is a reply to message #54280] |
Wed, 27 October 2004 13:00  |
Roy,
If the attribute use is not the container
(XSDConcreteComponent.getContainer()) of the attribute declaration, then
there isn't a way since there can be arbitrarily many attributes uses
that share a particular attribute declaration (because they have "ref"
to it).
> best
> roy
> Ed Merks wrote:
>> Gary,
>> Gary J wrote:
>>> Thanks Ed,
>>> the "Concrete" and "Abstract" representations of the schema?
>>> file itself whereas Abstract is (sort of) the "expanded" version of
>>> the schema with all the inherited types, groups, refs, etc available.
>>> schema and the Abstract to walk the schema elements, among other
>>> things.
>>> me a "cluebie" .
>>> Gary,
>>> the
>>> getContent
>>>> instance
| Re: How to retrieve Attributes for a complex ElementDeclaration [message #590790 is a reply to message #51267] |
Mon, 23 August 2004 23:15  |
I'm not sure if the results of getAttributeContents() are always an instance
| Re: How to retrieve Attributes for a complex ElementDeclaration [message #590923 is a reply to message #51293] |
Tue, 24 August 2004 07:48  |
Gary,
| Re: How to retrieve Attributes for a complex ElementDeclaration [message #590953 is a reply to message #51458] |
Tue, 24 August 2004 10:32  |
Thanks Ed,
"cluebie" .
Gary,
>instance
| Re: How to retrieve Attributes for a complex ElementDeclaration [message #590966 is a reply to message #51512] |
Gary,
Gary J wrote:
>Thanks Ed,
>"cluebie" .
>Gary,
>>instance
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
<br>
<br>
Gary J wrote:<br>
"cluebie" .
Gary,
Gary J wrote:
</pre>
instance
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
| attribute use from declaration [message #592228 is a reply to message #51538] |
best
roy
Ed Merks wrote:
> Gary,
> Gary J wrote:
>>Thanks Ed,
>>"cluebie" .
>>Gary,
>>>instance
| Re: attribute use from declaration [message #592249 is a reply to message #54280] |
Roy,
to it).
> best
> roy
> Ed Merks wrote:
>> Gary,
>> Gary J wrote:
>>> Thanks Ed,
>>> things.
>>> me a "cluebie" .
>>> Gary,
>>> the
>>> getContent
>>>> instance
Current Time: Sat Nov 22 03:31:36 EST 2025
Powered by FUDForum. Page generated in 0.06699 seconds
