Home » Modeling » GMF (Graphical Modeling Framework) » Missing methods in a generated Class
Missing methods in a generated Class [message #51196] |
Tue, 19 September 2006 10:44  |
Originally posted by: dont.spam.net
--------------050603090708080904090704
I have attached all models from my project to this posting.
The code generation works fine. I can generate the following projects:
com.eads.statemachine
com.eads.statemachine.edit
com.eads.statemachine.editor
com.eads.statemachine.tests
com.eads.statemachine.diagram
But the .diagram Project makes me not happy. When I try to build the
whole stuff, Eclipse points me to two Files in the
statemachine2.diagram.edit.parts package where something is missing. The
files are:
CompositeState2EditPart.java
CompositeStateEditPart.java
Both files have a inner Class "CompositeStateFigure". They try to call
the function .getFigureStateNameLabel() on instance of this class.
But the "CompositeStateFigure" Class doesn't have such a function.
Is it a Problem with my model? Or did I something wrong with the code
generation?
Christian
Content-Type: text/xml;
name="statemachine2.ecore"
Content-Disposition: inline;
filename="statemachine2.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="statemachine2"
nsURI="http://openarchitectureware.org/statemachine2" nsPrefix="statemachine2">
<eClassifiers xsi:type="ecore:EClass" name="Named" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Machine" eSuperTypes="#//CompositeState #//Named"/>
<eClassifiers xsi:type="ecore:EClass" name="CompositeState" eSuperTypes="#//State">
<eStructuralFeatures xsi:type="ecore:EReference" name="states" lowerBound="1"
upperBound="-1" eType="#//AbstractState" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="transitions" upperBound="-1"
eType="#//Transition" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AbstractState" abstract="true">
<eStructuralFeatures xsi:type="ecore:EReference" name="inTransitions" upperBound="-1"
eType="#//Transition" eOpposite="#//Transition/to"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="outTransitions" upperBound="-1"
eType="#//Transition" eOpposite="#//Transition/from"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="actions" upperBound="-1"
eType="#//Action" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="State" eSuperTypes="#//AbstractState #//Named"/>
<eClassifiers xsi:type="ecore:EClass" name="StartState" eSuperTypes="#//AbstractState"/>
<eClassifiers xsi:type="ecore:EClass" name="StopState" eSuperTypes="#//AbstractState #//Named"/>
<eClassifiers xsi:type="ecore:EClass" name="Transition" eSuperTypes="#//Named">
<eStructuralFeatures xsi:type="ecore:EReference" name="from" lowerBound="1" eType="#//AbstractState"
eOpposite="#//AbstractState/outTransitions"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="to" lowerBound="1" eType="#//AbstractState"
eOpposite="#//AbstractState/inTransitions"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="event" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="guard" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Action" eSuperTypes="#//Named">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="kind" lowerBound="1" eType="#//ActionKind"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="ActionKind">
<eLiterals name="ENTRY" value="1"/>
<eLiterals name="EXIT" value="2"/>
</eClassifiers>
</ecore:EPackage>
name="statemachine2.genmodel"
filename="statemachine2.genmodel"
<genmodel:GenModel xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel" modelDirectory="/com.eads.statemachine/src"
modelPluginID="com.eads.statemachine" modelName="Statemachine2" importerID="org.eclipse.emf.importer.ecore">
<foreignModel>statemachine2.ecore</foreignModel>
<genPackages prefix="Statemachine2" disposableProviderFactory="true" ecorePackage="statemachine2.ecore#/">
<genEnums ecoreEnum="statemachine2.ecore#//ActionKind">
<genEnumLiterals ecoreEnumLiteral="statemachine2.ecore#//ActionKind/ENTRY"/ >
<genEnumLiterals ecoreEnumLiteral="statemachine2.ecore#//ActionKind/EXIT"/>
</genEnums>
<genClasses image="false" ecoreClass="statemachine2.ecore#//Named">
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute statemachine2.ecore#//Named/name"/>
</genClasses>
<genClasses ecoreClass="statemachine2.ecore#//Machine"/>
<genClasses ecoreClass="statemachine2.ecore#//CompositeState">
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference statemachine2.ecore#//CompositeState/states"/>
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference statemachine2.ecore#//CompositeState/transitions"/>
</genClasses>
<genClasses image="false" ecoreClass="statemachine2.ecore#//AbstractState">
<genFeatures notify="false" createChild="false" propertySortChoices="true" ecoreFeature="ecore:EReference statemachine2.ecore#//AbstractState/inTransitions"/>
<genFeatures notify="false" createChild="false" propertySortChoices="true" ecoreFeature="ecore:EReference statemachine2.ecore#//AbstractState/outTransitions"/>
<genFeatures property="None" children="true" createChild="true" ecoreFeature="ecore:EReference statemachine2.ecore#//AbstractState/actions"/>
</genClasses>
<genClasses ecoreClass="statemachine2.ecore#//State"/>
<genClasses ecoreClass="statemachine2.ecore#//StartState"/>
<genClasses ecoreClass="statemachine2.ecore#//StopState"/>
<genClasses ecoreClass="statemachine2.ecore#//Transition">
<genFeatures notify="false" createChild="false" propertySortChoices="true" ecoreFeature="ecore:EReference statemachine2.ecore#//Transition/from"/>
<genFeatures notify="false" createChild="false" propertySortChoices="true" ecoreFeature="ecore:EReference statemachine2.ecore#//Transition/to"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute statemachine2.ecore#//Transition/event"/>
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute statemachine2.ecore#//Transition/guard"/>
</genClasses>
<genClasses ecoreClass="statemachine2.ecore#//Action">
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute statemachine2.ecore#//Action/kind"/>
</genClasses>
</genPackages>
</genmodel:GenModel>
name="statemachine2.gmfgraph"
filename="statemachine2.gmfgraph"
<gmfgraph:Canvas xmi:version="2.0"
xmlns:gmfgraph="http://www.eclipse.org/gmf/2005/GraphicalDefinition" name="statemachine2">
<figures
name="Default">
<figures
xsi:type="gmfgraph:Rectangle"
referencingElements="State ActionCompartment"
name="StateFigure">
<children
xsi:type="gmfgraph:Label"
referencingElements="StateNameDiagramLabel"
name="StateNameLabel"
text="<...>"/>
<backgroundColor
xsi:type="gmfgraph:ConstantColor"
value="lightGray"/>
</figures>
<figures
xsi:type="gmfgraph:PolylineConnection"
referencingElements="Transition"
name="TransitionFigure">
<children
referencingElements="TransitionDiagramLabel"
name="TransitionLabel"
text="<...>"/>
<children
xsi:type="gmfgraph:PolylineDecoration"
name="RE">
<backgroundColor
xsi:type="gmfgraph:RGBColor"
green="128"/>
<location/>
<size
y="1"/>
<template
x="-1"
y="1"/>
<template
x="-1"
y="-1"/>
<template
y="-1"/>
<template/>
</children>
<backgroundColor
value="darkGray"/>
</figures>
<figures
xsi:type="gmfgraph:Ellipse"
name="StopStateEllipse"
lineWidth="2">
<children
name="StopStateFigure"
lineWidth="2">
<backgroundColor
xsi:type="gmfgraph:RGBColor"/>
</children>
<backgroundColor
</figures>
<figures
referencingElements="CompositeState SubStateCompartment"
name="CompositeStateFigure">
<children
name="CompositeNameLabel"
text="<Huzifaki>">
<backgroundColor
value="black"/>
</children>
<backgroundColor
value="lightGray"/>
</figures>
<figures
referencingElements="Action"
name="ActionFigure">
<children
referencingElements="ActionDiagramLabel"
name="ActionLabel"
text="<...>"/>
</figures>
<figures
referencingElements="StartState"
name="StartStateRectangle">
<layout
xsi:type="gmfgraph:BorderLayout"/>
<children
name="StartStateEllipse"
lineWidth="2">
<layoutData
xsi:type="gmfgraph:BorderLayoutData"/>
<backgroundColor
</children>
<children
name="StartStateNameLabel"
text="StartState">
<layoutData
alignment="END"
vertical="true"/>
</children>
</figures>
<figures
xsi:type="gmfgraph:RoundedRectangle"
referencingElements="StopState"
name="StopStateRectangle">
<layout
<children
referencingElements="StopStateDiagramLabel"
name="StopStateNameLabel"
text="StopState">
<layoutData
alignment="END"
vertical="true"/>
</children>
<children
name="outerEllipse">
<layoutData
<layout
<children
name="innerEllipse"
xorFill="true">
<layoutData
<backgroundColor
value="black"/>
</children>
<maximumSize
dx="80"
dy="80"/>
<minimumSize
dx="60"
dy="60"/>
<preferredSize
dx="60"
dy="60"/>
<border
xsi:type="gmfgraph:MarginBorder">
<insets
top="5"
left="5"
bottom="5"
right="5"/>
</border>
</children>
</figures>
</figures>
<nodes
name="State"
figure="StateFigure"/>
<nodes
name="StartState"
figure="StartStateRectangle"/>
<nodes
name="StopState"
figure="StopStateRectangle"/>
<nodes
figure="CompositeStateFigure"/>
<nodes
name="Action"
figure="ActionFigure"/>
<connections
name="Transition"
figure="TransitionFigure"/>
<compartments
name="SubStateCompartment"
<compartments
name="ActionCompartment"
<labels
name="StateNameDiagramLabel"
figure="StateNameLabel"/>
<labels
name="TransitionDiagramLabel"
figure="TransitionLabel"/>
<labels
name="ActionDiagramLabel"
figure="ActionLabel"/>
<labels
name="StopStateDiagramLabel"
figure="StopStateNameLabel"/>
</gmfgraph:Canvas>
name="statemachine2.gmftool"
filename="statemachine2.gmftool"
<gmftool:ToolRegistry xmi:version="2.0"
xmlns:gmftool="http://www.eclipse.org/gmf/2005/ToolDefinition">
<palette>
<tools
xsi:type="gmftool:ToolGroup"
title="States">
<tools
xsi:type="gmftool:CreationTool"
title="State"
description="Create new State">
<smallIcon
xsi:type="gmftool:BundleImage"
path="platform:/plugin/com.eads.statemachine/icons/state.gif "/>
</tools>
<tools
title="StartState"
description="Create new StartState">
<smallIcon
path="platform:/plugin/com.eads.statemachine/icons/start.gif "/>
</tools>
<tools
xsi:type="gmftool:PaletteSeparator"/>
<tools
title="StopState"
description="Create new StopState">
<smallIcon
path="platform:/plugin/com.eads.statemachine/icons/stop.gif "/>
</tools>
<tools
title="CompositeState"
description="Create new CompositeState">
<smallIcon
path="platform:/plugin/com.eads.statemachine/icons/compstate.gif "/>
</tools>
</tools>
<tools
title="Transition"
description="Create new Transition">
<smallIcon
path="platform:/plugin/com.eads.statemachine/icons/transition.gif "/>
</tools>
<tools
title="Action"
description="Create new Action">
<smallIcon
path="platform:/plugin/com.eads.statemachine/icons/action.gif "/>
</tools>
</palette>
</gmftool:ToolRegistry>
name="statemachine2.gmfgen"
filename="statemachine2.gmfgen"
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<gmfgen:GenEditorGenerator xmi:version=3D"2.0"
xmlns:xmi=3D"http://www.omg.org/XMI"
xmlns:xsi=3D"http://www.w3.org/2001/XMLSchema-instance"
xmlns:gmfgen=3D"http://www.eclipse.org/gmf/2005/GenModel">
<diagram
visualID=3D"1000"
editPartClassName=3D"MachineEditPart"
itemSemanticEditPolicyClassName=3D"MachineItemSemanticEditPolicy "
notationViewFactoryClassName=3D"MachineViewFactory"
iconProviderPriority=3D"Low"
canonicalEditPolicyClassName=3D"MachineCanonicalEditPolicy" >
<diagramRunTimeClass
href=3D"../../plugin/org.eclipse.gmf.runtime.notation/model/notat=
ion.genmodel#//notation/Diagram"/>
<elementType
xsi:type=3D"gmfgen:MetamodelType"
editHelperClassName=3D"MachineEditHelper"/>
<viewmap
xsi:type=3D"gmfgen:FigureViewmap"
figureQualifiedClassName=3D"org.eclipse.draw2d.FreeformLayer "/>
<domainDiagramElement
href=3D"model/statemachine2.genmodel#//statemachine2/Machine "/>
<childNodes
visualID=3D"3001"
editPartClassName=3D"ActionEditPart"
itemSemanticEditPolicyClassName=3D"ActionItemSemanticEditPolicy "
notationViewFactoryClassName=3D"ActionViewFactory"
canonicalEditPolicyClassName=3D"ActionCanonicalEditPolicy"
graphicalNodeEditPolicyClassName=3D"ActionGraphicalNodeEditPolicy=
containers=3D"//@diagram/@compartments.0 //@diagram/@compartments=
=2E3">
href=3D"../../plugin/org.eclipse.gmf.runtime.notation/model/not=
ation.genmodel#//notation/Node"/>
<elementType
editHelperClassName=3D"ActionEditHelper"/>
<viewmap
xsi:type=3D"gmfgen:InnerClassViewmap"
className=3D"ActionFigure"
classBody=3D"
 * @generated
public class ActionFigure extends org.eclipse.draw2d.R=
ectangleFigure {
&a mp;#xA;	 * @generated&=
#xD;
	public ActionFigure() {
&#x=
9;
	& ;#x9;
		createContents()=
& ;#xA;
&#x 9; * =
@generated
	private void createContents(){=
		org.eclipse.gmf.runtime. draw2d.ui.figures.WrapLabel f=
ig_0 =3D new org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel();&# xD;&=
#xA;fig_0.setText("<...> ");
&am p;#xA;&#x=
D;
		setFigureActionLabel(fig_0);&am p;#xD;
&#x=
A;		Object layData0 =3D null;
		t his.a=
dd(fig_0, layData0);
& ;#x9;
xD;
	 * @generated
#x9;private org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel fActionLa=
bel;
&am p;#xA;	 * @generated
x9; */
	public org.eclipse.gmf.runtime.draw2d.ui.figures.Wra=
pLabel getFigureActionLabel() {
		return fActionLabel;&#=
xD;
&a mp;#xA;	/**
	 * @generat=
ed
	private void setFigureActionLabel(org.=
eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel fig){
fActionLabel =3D fig;
& amp;#xA;
#xA;
	 ; * @generated
	private boolean myUseLocalCoordinates =3D false;
	 * @generated
;protected boolean useLocalCoordinates() {
		return myUs=
eLocalCoordinates;
& #xA;
#x9; * @generated
	protected void setUseLo=
calCoordinates(boolean useLocalCoordinates) {
		myUseLoc=
alCoordinates =3D useLocalCoordinates;
&am p;#xA;
	& ;#xD;
<requiredPluginIDs>org.eclipse.draw2d</requiredPluginIDs>
<requiredPluginIDs>org.eclipse.gmf.runtime.draw2d.ui</requiredPlu=
ginIDs>
</viewmap>
<modelFacet>
<metaClass
href=3D"model/statemachine2.genmodel#//statemachine2/Action "/=
<containmentMetaFeature
href=3D"model/statemachine2.genmodel#//statemachine2/Abstract=
State/actions"/>
<childMetaFeature
State/actions"/>
</modelFacet>
<labels
visualID=3D"5001"
editPartClassName=3D"ActionKindNameEditPart"
itemSemanticEditPolicyClassName=3D"ActionKindNameItemSemanticEd=
itPolicy"
notationViewFactoryClassName=3D"ActionKindNameViewFactory"
elementIcon=3D"true">
href=3D"../../plugin/org.eclipse.gmf.runtime.notation/model/n=
otation.genmodel#//notation/Node"/>
<viewmap
xsi:type=3D"gmfgen:ParentAssignedViewmap"
getterName=3D"getFigureActionLabel"
figureQualifiedClassName=3D"org.eclipse.gmf.runtime.draw2d.ui=
=2Efigures.WrapLabel"/>
<modelFacet
xsi:type=3D"gmfgen:CompositeFeatureLabelModelFacet"
viewPattern=3D"{0}/{1}"
editPattern=3D"{0}/{1}">
<metaFeatures
href=3D"model/statemachine2.genmodel#//statemachine2/Action=
/kind"/>
<metaFeatures
href=3D"model/statemachine2.genmodel#//statemachine2/Named/=
name"/>
</modelFacet>
</labels>
</childNodes>
<childNodes
visualID=3D"3002"
editPartClassName=3D"State2EditPart"
itemSemanticEditPolicyClassName=3D"State2ItemSemanticEditPolicy "
notationViewFactoryClassName=3D"State2ViewFactory"
canonicalEditPolicyClassName=3D"State2CanonicalEditPolicy"
compartments=3D"//@diagram/@compartments.3"
graphicalNodeEditPolicyClassName=3D"State2GraphicalNodeEditPolicy=
containers=3D"//@diagram/@compartments.2 //@diagram/@compartments=
=2E5">
<elementType
xsi:type=3D"gmfgen:SpecializationType"
metamodelType=3D"//@diagram/@topLevelNodes.0/@elementType"
editHelperAdviceClassName=3D"StateEditHelperAdvice"/>
<viewmap
className=3D"StateFigure"
classBody=3D"
 * @generated
public class StateFigure extends org.eclipse.draw2d.Re=
ctangleFigure {
&a mp;#xA;	 * @generated&#=
xD;
	public StateFigure() {
	&# x9;
		this.setBackground=
Color(org.eclipse.draw2d.ColorConstants.lightGray
&a mp;#xA;
xD;
		createContents();
& ;#xA;	}
xD;
	 * @generated
#x9;private void createContents(){
		org.ecl ipse.gmf.run=
time.draw2d.ui.figures.WrapLabel fig_0 =3D new org.eclipse.gmf.runtime.dr=
fig_0.setText( "<... >")=
& #xD;
		setFigureStateNameLabe=
l(fig_0);
&# xA;		Object layData0 =3D null=
		this. add(fig_0, layData0);
	&# x9;
	 * @g=
enerated
	private org.eclipse.gmf.runtime.=
draw2d.ui.figures.WrapLabel fStateNameLabel;
	 * @generated
	public org.e=
clipse.gmf.runtime.draw2d.ui.figures.WrapLabel getFigureStateNameLabel() =
		return fStateNameLabel;
&#x A;&#x=
9;
	 * @generated
xA;	private void setFigureStateNameLabel(org.eclipse.gmf.runtime.draw=
		fStateNameLabel =3D fig;=
& #xA;
&a mp;#x9;/*=
	 * @generated
	private boo=
	/**&# xD;&#x=
A;	 * @generated
	protected boolean us=
		return myUseLocalCoordinates;&#x=
D;
&am p;#x9;/**
	 * @generated
	protected void setUseLocalCoordinates(boolea=
		myUseLocalCoordinates =3D use=
LocalCoordinates;
&# xA;
<attributes
xsi:type=3D"gmfgen:StyleAttributes"
fixedBackground=3D"true"/>
ginIDs>
</viewmap>
<modelFacet>
<metaClass
href=3D"model/statemachine2.genmodel#//statemachine2/State"/ >=
href=3D"model/statemachine2.genmodel#//statemachine2/Composit=
eState/states"/>
<childMetaFeature
eState/states"/>
</modelFacet>
<labels
visualID=3D"5004"
editPartClassName=3D"StateName2EditPart"
itemSemanticEditPolicyClassName=3D"StateName2ItemSemanticEditPo=
licy"
notationViewFactoryClassName=3D"StateName2ViewFactory"
<viewmap
getterName=3D"getFigureStateNameLabel"
<modelFacet
xsi:type=3D"gmfgen:FeatureLabelModelFacet">
<metaFeature
name"/>
</modelFacet>
</labels>
</childNodes>
<childNodes
visualID=3D"3003"
editPartClassName=3D"StartState2EditPart"
itemSemanticEditPolicyClassName=3D"StartState2ItemSemanticEditPol=
icy"
notationViewFactoryClassName=3D"StartState2ViewFactory"
canonicalEditPolicyClassName=3D"StartState2CanonicalEditPolicy "
graphicalNodeEditPolicyClassName=3D"StartState2GraphicalNodeEditP=
olicy"
=2E5">
<elementType
metamodelType=3D"//@diagram/@topLevelNodes.2/@elementType"
editHelperAdviceClassName=3D"StartStateEditHelperAdvice"/>
<viewmap
className=3D"StartStateRectangle"
classBody=3D"
 * @generated
public class StartStateRectangle extends org.eclipse.d=
raw2d.RectangleFigure {
&a mp;#xA;	 * @gen=
erated
	public StartStateRectangle() {	=
& #x9;	org.eclipse.draw2d.BorderLayout =
myGenLayoutManager =3D new org.eclipse.draw2d.BorderLayout();
x9;
&am p;#x9;	this.setLayoutManager(myGenLay=
outManager);
	&am p;#x9;
		createConte=
nts();
&a mp;#x=
9; * @generated
	private void createConten=
ts(){
		org.eclipse.draw2d. Ellipse fig_0 =3D new org.ecl=
ipse.draw2d.Ellipse();
&a mp;#x9;	fig_0.setLineWidth(2)=
		fig_0.setBackgroundColo r(STARTSTATEELLIPSE_BACK
& ;#xA;
		s etFig=
ureStartStateEllipse(fig_0);
	& #x9;
	Object lay=
Data0 =3D org.eclipse.draw2d.BorderLayout.CENTER;
&am p;#xD;
& #x9;	this.add(fig_0, layData0);
#xA;		org.eclipse.gmf.runtime.draw2d.ui.figu res.WrapLabel fig_1 =3D=
fig_=
1.setText("StartState");
;		setFigureStartStateNameLabel(fig_1);& #xD;
#xA;	Object layData1 =3D org.eclipse.draw2d.BorderLayout.BOTTOM;
			&# xD;
		this.add(fig _=
1, layData1);
& ;#x9;
	 * @generated
	pri=
vate org.eclipse.draw2d.Ellipse fStartStateEllipse;
#x9;/**
	 * @generated
	publi=
c org.eclipse.draw2d.Ellipse getFigureStartStateEllipse() {
;	return fStartStateEllipse;
& ;#xA;
	 * @generated
	priv=
ate void setFigureStartStateEllipse(org.eclipse.draw2d.Ellipse fig){
		fStartStateEllipse =3D fig;
	/**&am p;#xD;
	 * @generated
x9; */
	private org.eclipse.gmf.runtime.draw2d.ui.figures.Wr=
apLabel fStartStateNameLabel;
&am p;#xA;	=
* @generated
	public org.eclipse.gmf.runt=
ime.draw2d.ui.figures.WrapLabel getFigureStartStateNameLabel() {
;		return fStartStateNameLabel;
&a mp;#xA;	&#x=
D;
	 * @generated
x9;private void setFigureStartStateNameLabel(org.eclipse.gmf.runtime.draw=
		fStartStateNameLabe l =3D=
fig;
& amp;#xA;
&#x A;&#=
x9;/**
	 * @generated
	privat=
	/**&# x=
D;
	 * @generated
	protected boole=
		return myUseLocalCoordinate=
s;
&am p;#xA;	/**
	 * @generate=
d
	protected void setUseLocalCoordinates(b=
		myUseLocalCoordinates =3D=
&am p;#xA;
	&# xD;
	 * @genera=
ted
	public static final org.eclipse.swt.g=
raphics.Color STARTSTATEELLIPSE_BACK =3D new org.eclipse.swt.graphics.Col=
or(null, 0, 0, 0);
ginIDs>
</viewmap>
<modelFacet>
<metaClass
href=3D"model/statemachine2.genmodel#//statemachine2/StartSta=
te"/>
eState/states"/>
<childMetaFeature
eState/states"/>
</modelFacet>
</childNodes>
<childNodes
visualID=3D"3004"
editPartClassName=3D"StopState2EditPart"
itemSemanticEditPolicyClassName=3D"StopState2ItemSemanticEditPoli=
cy"
notationViewFactoryClassName=3D"StopState2ViewFactory"
canonicalEditPolicyClassName=3D"StopState2CanonicalEditPolicy "
graphicalNodeEditPolicyClassName=3D"StopState2GraphicalNodeEditPo=
licy"
=2E5">
<elementType
metamodelType=3D"//@diagram/@topLevelNodes.1/@elementType"
editHelperAdviceClassName=3D"StopStateEditHelperAdvice"/>
<viewmap
className=3D"StopStateRectangle"
classBody=3D"
 * @generated
public class StopStateRectangle extends org.eclipse.dr=
aw2d.RoundedRectangle {
&a mp;#xA;	 * @gen=
erated
	public StopStateRectangle() {	=
&# x9;	org.eclipse.draw2d.BorderLayout m=
&#x=
9;
& ;#x9;	this.setLayoutManager(myGenLayo=
utManager);
	& ;#x9;
this.setCornerDimensio=
ns(new org.eclipse.draw2d.geometry.Dimension(getMapMode().DPtoLP(8) , getM=
apMode().DPtoLP(8)));
&am p;#x9;	createContents();
& #xD;
	 * @gener=
ated
#xA;		org.eclipse.gmf.runtime.draw2d.ui.figu res.WrapLabel fig_0 =3D=
fig_=
0.setText("StopState");
& amp;#xD;
		setFigureStopStateNameLabel(fig_0);&#x D;
&#x=
A;	Object layData0 =3D org.eclipse.draw2d.BorderLayout.BOTTOM;
xA;
&am p;#xA;
		this.add(fig_0,=
layData0);
		org.eclipse.dr aw2d.Ellipse fig_1 =3D new o=
rg.eclipse.draw2d.Ellipse();
& #xA;		fig_1.setPrefer=
redSize(getMapMode().DPtoLP(60), getMapMode().DPtoLP(60));
	fig_1.setMaximumSize(new org.eclipse.draw2d.geometry.Dimension(getMa=
pMode().DPtoLP(80), getMapMode().DPtoLP(80)));
	&#x 9;fig_1.s=
etMinimumSize(new org.eclipse.draw2d.geometry.Dimension(getMapMode().DPto=
LP(60), getMapMode().DPtoLP(60)));
	&#x 9;fig_1.setBorder(&#x=
9;
new org.eclipse.draw2d.MarginBorder(getMapMode().DPtoLP(5), g=
etMapMode().DPtoLP(5), getMapMode().DPtoLP(5), getMapMode().DPtoLP(5))&#x=
D;
	&a mp;#x9;org.eclipse.draw2d.BorderLayout la=
youter1 =3D new org.eclipse.draw2d.BorderLayout();
	 ;	&#x=
D;
		fig_ 1.setLayoutManager(layouter1);
xA;
		set FigureouterEllipse(fig_1);
#x9;
	Object layData1 =3D org.eclipse.draw2d.BorderLayo=
ut.CENTER;
	& #x9;
	&a mp;#x=
9;this.add(fig_1, layData1);
		org.eclipse.dr aw2d.Ellips=
e fig_2 =3D new org.eclipse.draw2d.Ellipse();
& ;#xA;	&#x=
9;fig_2.setFillXOR(true);
		 ;fig_2.setBackgroundColor(org=
=2Eeclipse.draw2d.ColorConstants.black
& ;#xD;
&#x=
D;
	& ;#x9;
	Object layData2 =3D o=
& ;#xD;
		fig_1. add(fig_2, layData2);
	&# x9;
	 * @g=
enerated
draw2d.ui.figures.WrapLabel fStopStateNameLabel;
	 * @generated
	public o=
rg.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel getFigureStopStateName=
Label() {
		return fStopStateNameLabel;
#xD;
	 * @generated
&#x=
9; */
	private void setFigureStopStateNameLabel(org.eclipse.=
		fStopSta=
& amp;#xA;
xA;	/**
	 * @generated
	p=
rivate org.eclipse.draw2d.Ellipse fOuterEllipse;
	 * @generated
	public o=
rg.eclipse.draw2d.Ellipse getFigureOuterEllipse() {
		re=
turn fOuterEllipse;
	 * @generated
	private void setF=
igureouterEllipse(org.eclipse.draw2d.Ellipse fig){
		fOu=
terEllipse =3D fig;
& amp;#xA;
&#x=
A;
	 * @generated
xA;	private boolean myUseLocalCoordinates =3D false;
xA;	/**
	 * @generated
	p=
		return myUseL=
ocalCoordinates;
&#x A;
&#x=
9; * @generated
	protected void setUseLoca=
		myUseLocal=
&am p;#xA;
#xA;
& amp;#xA; ">
ginIDs>
</viewmap>
<modelFacet>
<metaClass
href=3D"model/statemachine2.genmodel#//statemachine2/StopStat=
e"/>
eState/states"/>
<childMetaFeature
eState/states"/>
</modelFacet>
<labels
visualID=3D"5005"
editPartClassName=3D"StopStateName2EditPart"
itemSemanticEditPolicyClassName=3D"StopStateName2ItemSemanticEd=
itPolicy"
notationViewFactoryClassName=3D"StopStateName2ViewFactory"
<viewmap
getterName=3D"getFigureStopStateNameLabel"
<modelFacet
<metaFeature
name"/>
</modelFacet>
</labels>
</childNodes>
<childNodes
visualID=3D"3005"
editPartClassName=3D"CompositeState2EditPart"
itemSemanticEditPolicyClassName=3D"CompositeState2ItemSemanticEdi=
tPolicy"
notationViewFactoryClassName=3D"CompositeState2ViewFactory"
canonicalEditPolicyClassName=3D"CompositeState2CanonicalEditPolic=
y"
compartments=3D"//@diagram/@compartments.4 //@diagram/@compartmen=
ts.5"
graphicalNodeEditPolicyClassName=3D"CompositeState2GraphicalNodeE=
ditPolicy"
containers=3D"//@diagram/@compartments.5 //@diagram/@compartments=
=2E2">
<elementType
metamodelType=3D"//@diagram/@topLevelNodes.3/@elementType"
editHelperAdviceClassName=3D"CompositeStateEditHelperAdvice "/>
<viewmap
className=3D"CompositeStateFigure"
classBody=3D"
 * @generated
public class CompositeStateFigure extends org.eclipse.=
draw2d.RectangleFigure {
&a mp;#xA;	 * @ge=
nerated
	public CompositeStateFigure() {&#=
x9;
&am p;#xD;
this.setBackgroundColor(org.eclipse.draw2d.ColorConstants.li ghtGray
#xA;
		 createContents();
	/**&a mp;#xD;
	 * @generated
#x9; */
		o=
rg.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel fig_0 =3D new org.ecli=
& #xA;fig_0.setText(&qu=
ot;<Huzifaki> ");
		fig_0.setBac kgroundColor(org.=
&#x D;
#xA;
		se tFigureCompositeNameLabel(fig_0);
	& #x9;Object layData0 =3D null;
xD;
& ;#x=
9;
& ;#x9;/**
	 * @generated
	private org.eclipse.gmf.runtime.draw2d.ui.fig=
ures.WrapLabel fCompositeNameLabel;
&am p;#xA=
;	 * @generated
	public org.eclipse.gm=
f.runtime.draw2d.ui.figures.WrapLabel getFigureCompositeNameLabel() {
		return fCompositeNameLabel;
&am p;#xA;	=
	 * @generated
&#x=
A;	private void setFigureCompositeNameLabel(org.eclipse.gmf.runtime.d=
		fCompositeNameLabel =3D=
fig;
& amp;#xA;
&#x A;&#=
x9;/**
	 * @generated
	privat=
	/**&# x=
D;
	 * @generated
	protected boole=
s;
&am p;#xA;	/**
	 * @generate=
d
&am p;#xA;
<attributes
ginIDs>
</viewmap>
<modelFacet>
<metaClass
eState"/>
eState/states"/>
<childMetaFeature
eState/states"/>
</modelFacet>
<labels
visualID=3D"5006"
editPartClassName=3D"CompositeStateNameEditPart"
itemSemanticEditPolicyClassName=3D"CompositeStateNameItemSemant=
icEditPolicy"
notationViewFactoryClassName=3D"CompositeStateNameViewFactory "
<viewmap
<modelFacet
viewPattern=3D""
editPattern=3D"">
<metaFeature
name"/>
</modelFacet>
Re: Missing methods in a generated Class [message #51238 is a reply to message #51196] |
Tue, 19 September 2006 11:35   |
The explanation below is a bit complicated because the problem lies in the
relation between Node Mapping/Label Mapping in the map model, corresponding
Diagram Node/Diagram Label in the "diagram elements" part of the gmf graph
model and corresponding figures/labels in the "Figures" part of the gmfgraph
model. I am sorry that I can not explain this better.
In the gmfgraph you have CompositeStateFigure with child label
CompositeNameLabel.
You also have Diagram Label StateNameDiagramLabel that references _different
label figure_, in particular, the label form _different and unrelated
figures hierarchy_.
You also have diagram node that references CompositeStateFigure and
NodeMapping that references this diagram node.
Inside this mapping you also have Label Mapping that references that
UNRELATED StateNameDiagramLabel from the gmfgraph.
To fix compilation error you need to ensure that Label Mapping either:
1. Indirectly (via gmfgraph Diagram Label medium) references the
"uncontained" label (the one that is not inside any figure hierarchy, the
direct child of its FigureGallery) -- in this case this label will be
considered external.
2. Or indirectly references the label from the same figure hierarchy that
the figure indirectly referenced by Node Mapping (I guess that it should be
Diagram Label for "CompositeNameLabel") -- in this case the "inner" label
will be used with positions defined by figure hierarchy.
You may take a look at the attached diagram (also a bit cryptic)
Michael
"Christian Barth" <dont@spam.net> wrote in message
news:eeovli$era$1@utils.eclipse.org...
> files are:
> generation?
> Christian
> </eClassifiers>
> lowerBound="1"
> upperBound="-1"
> </eClassifiers>
> abstract="true">
> upperBound="-1"
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> <genEnumLiterals
> <genEnumLiterals
> </genEnums>
> </genClasses>
> </genClasses>
> </genClasses>
> </genClasses>
> </genClasses>
> </genPackages>
> <figures
> name="Default">
> <figures
> name="StateFigure">
> <children
> text="<...>"/>
> <backgroundColor
> value="lightGray"/>
> </figures>
> <figures
> <children
> text="<...>"/>
> <children
> name="RE">
> <backgroundColor
> green="128"/>
> <location/>
> <size
> y="1"/>
> <template
> x="-1"
> y="1"/>
> <template
> x="-1"
> y="-1"/>
> <template
> y="-1"/>
> <template/>
> </children>
> <backgroundColor
> value="darkGray"/>
> </figures>
> <figures
> lineWidth="2">
> <children
> lineWidth="2">
> <backgroundColor
> </children>
> <backgroundColor
> </figures>
> <figures
> <children
> text="<Huzifaki>">
> <backgroundColor
> value="black"/>
> </children>
> <backgroundColor
> value="lightGray"/>
> </figures>
> <figures
> <children
> name="ActionLabel"
> text="<...>"/>
> </figures>
> <figures
> <layout
> <children
> lineWidth="2">
> <layoutData
> <backgroundColor
> </children>
> <children
> text="StartState">
> <layoutData
> alignment="END"
> vertical="true"/>
> </children>
> </figures>
> <figures
> <layout
> <children
> text="StopState">
> <layoutData
> alignment="END"
> vertical="true"/>
> </children>
> <children
> <layoutData
> <layout
> <children
> name="innerEllipse"
> xorFill="true">
> <layoutData
> <backgroundColor
> value="black"/>
> </children>
> <maximumSize
> dx="80"
> dy="80"/>
> <minimumSize
> dx="60"
> dy="60"/>
> <preferredSize
> dx="60"
> dy="60"/>
> <border
> <insets
> top="5"
> left="5"
> bottom="5"
> right="5"/>
> </border>
> </children>
> </figures>
> </figures>
> <nodes
> name="State"
> <nodes
> name="StartState"
> <nodes
> name="StopState"
> <nodes
> <nodes
> name="Action"
> <connections
> name="Transition"
> <compartments
> <compartments
> <labels
> <labels
> <labels
> <labels
> </gmfgraph:Canvas>
> <palette>
> <tools
> title="States">
> <tools
> title="State"
> <smallIcon
> </tools>
> <tools
> title="StartState"
> <smallIcon
> </tools>
> <tools
> <tools
> title="StopState"
> <smallIcon
> </tools>
> <tools
> <smallIcon
> </tools>
> </tools>
> <tools
> title="Transition"
> <smallIcon
> </tools>
> <tools
> title="Action"
> <smallIcon
> </tools>
> </palette>
<gmfgen:GenEditorGenerator xmi:version="2.0"
xmlns:gmfgen="http://www.eclipse.org/gmf/2005/GenModel">
<diagram
visualID="1000"
editPartClassName="MachineEditPart"
itemSemanticEditPolicyClassName="MachineItemSemanticEditPolicy "
notationViewFactoryClassName="MachineViewFactory"
iconProviderPriority="Low"
canonicalEditPolicyClassName="MachineCanonicalEditPolicy">
href=" ../../plugin/org.eclipse.gmf.runtime.notation/model/notation .genmodel#//notation/Diagram "/>
<elementType
xsi:type="gmfgen:MetamodelType"
editHelperClassName="MachineEditHelper"/>
<viewmap
xsi:type="gmfgen:FigureViewmap"
figureQualifiedClassName="org.eclipse.draw2d.FreeformLayer"/ >
href="model/statemachine2.genmodel#//statemachine2/Machine"/ >
<childNodes
visualID="3001"
editPartClassName="ActionEditPart"
itemSemanticEditPolicyClassName="ActionItemSemanticEditPolicy "
notationViewFactoryClassName="ActionViewFactory"
canonicalEditPolicyClassName="ActionCanonicalEditPolicy"
graphicalNodeEditPolicyClassName="ActionGraphicalNodeEditPolicy "
containers="//@diagram/@compartments.0 //@diagram/@compartments.3">
href=" ../../plugin/org.eclipse.gmf.runtime.notation/model/notation .genmodel#//notation/Node "/>
<elementType
editHelperClassName="ActionEditHelper"/>
<viewmap
xsi:type="gmfgen:InnerClassViewmap"
className="ActionFigure"
classBody="
@generated
org.eclipse.draw2d.RectangleFigure
& #xA;
&a mp;#x9;	createContents();
& #x9;/**
* @generated
	private void
createContents(){
		org.ecl ipse.gmf.runtime.draw2d.ui.figures.WrapLabel
fig_0 = new
fig_0.setText("<... > ");
&am p;#xA;
		setFigureActionLab el(fig_0);
& #xA;		Object
layData0 = null;
		t his.add(fig_0,
layData0);
& ;#x9;
& amp;#x9;/**
* @generated
	private
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel fActionLabel;
	public org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel
		return
fActionLabel;
& amp;#x9;
& ;#x9;
* @generated
	private void
setFigureActionLabel(org.eclipse.gmf.runtime.draw2d.ui.figur es.WrapLabel
fig){
		fActionLabel =
fig;
& amp;#xA;
&#x A;	/**
* @generated
	private boolean
myUseLocalCoordinates = false;
	/**&# xD;
@generated
	protected boolean
		return
& amp;#xA;
& ;#x9;
* @generated
	protected void
setUseLocalCoordinates(boolean useLocalCoordinates)
&am p;#xA;
<requiredPluginIDs>org.eclipse.gmf.runtime.draw2d.ui</requiredPluginIDs >
</viewmap>
<modelFacet>
<metaClass
href="model/statemachine2.genmodel#//statemachine2/Action"/ >
href=" model/statemachine2.genmodel#//statemachine2/AbstractState/a ctions "/>
<childMetaFeature
</modelFacet>
<labels
visualID="5001"
editPartClassName="ActionKindNameEditPart"
itemSemanticEditPolicyClassName="ActionKindNameItemSemanticEditPolicy "
notationViewFactoryClassName="ActionKindNameViewFactory"
elementIcon="true">
<viewmap
xsi:type="gmfgen:ParentAssignedViewmap"
getterName="getFigureActionLabel"
figureQualifiedClassName="org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel "/>
<modelFacet
xsi:type="gmfgen:CompositeFeatureLabelModelFacet"
viewPattern="{0}/{1}"
editPattern="{0}/{1}">
<metaFeatures
href="model/statemachine2.genmodel#//statemachine2/Action/kind "/>
<metaFeatures
href="model/statemachine2.genmodel#//statemachine2/Named/name "/>
</modelFacet>
</labels>
</childNodes>
<childNodes
visualID="3002"
editPartClassName="State2EditPart"
itemSemanticEditPolicyClassName="State2ItemSemanticEditPolicy "
notationViewFactoryClassName="State2ViewFactory"
canonicalEditPolicyClassName="State2CanonicalEditPolicy"
compartments="//@diagram/@compartments.3"
graphicalNodeEditPolicyClassName="State2GraphicalNodeEditPolicy "
containers="//@diagram/@compartments.2 //@diagram/@compartments.5">
<elementType
xsi:type="gmfgen:SpecializationType"
metamodelType="//@diagram/@topLevelNodes.0/@elementType"
editHelperAdviceClassName="StateEditHelperAdvice"/>
<viewmap
className="StateFigure"
classBody="
@generated
& #xA;
&a mp;#x9;	this.setBackgroundColor(org.eclipse.draw2d.C olorConstants.lightGray
		createContents();&# xD;
&a mp;#xD;
* @generated
	private void
createContents(){
fig_0 = new
&am p;#xA;
		setFigureStateName Label(fig_0);
&a mp;#xA;		Object
layData0 = null;
		t his.add(fig_0,
layData0);
& ;#x9;
& amp;#x9;/**
* @generated
	private
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel fStateNameLabel;
getFigureStateNameLabel() {
		return
fStateNameLabel;
&#x A;
& amp;#x9;
* @generated
	private void
setFigureStateNameLabel(org.eclipse.gmf.runtime.draw2d.ui.fi gures.WrapLabel
fig){
		fStateNameLabel =
fig;
& amp;#xA;
&#x A;	/**
* @generated
	private boolean
	/**&# xD;
@generated
	protected boolean
		return
& amp;#xA;
& ;#x9;
* @generated
	protected void
&am p;#xA;
<attributes
xsi:type="gmfgen:StyleAttributes"
fixedBackground="true"/>
</viewmap>
<modelFacet>
<metaClass
href="model/statemachine2.genmodel#//statemachine2/State"/ >
href=" model/statemachine2.genmodel#//statemachine2/CompositeState/ states "/>
<childMetaFeature
</modelFacet>
<labels
visualID="5004"
editPartClassName="StateName2EditPart"
itemSemanticEditPolicyClassName="StateName2ItemSemanticEditPolicy "
notationViewFactoryClassName="StateName2ViewFactory"
elementIcon="true">
<viewmap
getterName="getFigureStateNameLabel"
<modelFacet
xsi:type="gmfgen:FeatureLabelModelFacet">
<metaFeature
</modelFacet>
</labels>
</childNodes>
<childNodes
visualID="3003"
editPartClassName="StartState2EditPart"
itemSemanticEditPolicyClassName="StartState2ItemSemanticEditPolicy "
notationViewFactoryClassName="StartState2ViewFactory"
canonicalEditPolicyClassName="StartState2CanonicalEditPolicy "
graphicalNodeEditPolicyClassName="StartState2GraphicalNodeEditPolicy "
<elementType
metamodelType="//@diagram/@topLevelNodes.2/@elementType"
editHelperAdviceClassName="StartStateEditHelperAdvice"/>
<viewmap
className="StartStateRectangle"
classBody="
@generated
& #xA;		org.eclipse.draw2d.BorderLayout
myGenLayoutManager = new
& #x9;	this.setLayoutManager(myGenLayoutManager);& #xD;
&a mp;#xA;		createContents();
& #xA;	/**
* @generated
	private void
createContents(){
		org.ecl ipse.draw2d.Ellipse fig_0 = new
& ;#xA;		fig_0.setLineWidth(2);
&# xA;		fig_0.setBackgroundColor(STARTSTATEELLI PSE_BACK
& #xA;
&a mp;#x9;	setFigureStartStateEllipse(fig_0);
& amp;#xA;
	Object
layData0 =
&am p;#xD;
		this.add(fig_0,
layData0);
		org.eclipse.gm f.runtime.draw2d.ui.figures.WrapLabel
fig_1 = new
fig_1.setText("StartState");&a mp;#xD;
		setFigureStartStateNameLabel(fig _1);
&a mp;#x9;Object
layData1 =
&am p;#xD;
		this.add(fig_1,
layData1);
& ;#x9;
& amp;#x9;/**
* @generated
	private
	public org.eclipse.draw2d.Ellipse
		return
fStartStateEllipse;
& ;#xA;
&#x A;
* @generated
	private void
fig){
fig;
& amp;#xA;
	/**& ;#xD;
* @generated
	private
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel fStartStateNameLabel;
		return
&a mp;#xA;
& #xA;
* @generated
	private void
setFigureStartStateNameLabel(org.eclipse.gmf.runtime.draw2d. ui.figures.WrapLabel
fig){
fig;
& amp;#xA;
&#x A;	/**
* @generated
	private boolean
	/**&# xD;
@generated
	protected boolean
		return
& amp;#xA;
& ;#x9;
* @generated
	protected void
&am p;#xA;
& #xA;	/**
* @generated
	public static final
org.eclipse.swt.graphics.Color STARTSTATEELLIPSE_BACK = new
org.eclipse.swt.graphics.Color(null, 0, 0, 0);
</viewmap>
<modelFacet>
<metaClass
href="model/statemachine2.genmodel#//statemachine2/StartState "/>
<childMetaFeature
</modelFacet>
</childNodes>
<childNodes
visualID="3004"
editPartClassName="StopState2EditPart"
itemSemanticEditPolicyClassName="StopState2ItemSemanticEditPolicy "
notationViewFactoryClassName="StopState2ViewFactory"
canonicalEditPolicyClassName="StopState2CanonicalEditPolicy "
graphicalNodeEditPolicyClassName="StopState2GraphicalNodeEditPolicy "
<elementType
metamodelType="//@diagram/@topLevelNodes.1/@elementType"
editHelperAdviceClassName="StopStateEditHelperAdvice"/>
<viewmap
className="StopStateRectangle"
classBody="
@generated
org.eclipse.draw2d.RoundedRectangle
&a mp;#xA;this.setCornerDimensions(new
getMapMode().DPtoLP(8)));
 ;		createContents();
&# x9;}
&a mp;#x9;/**
* @generated
	private void
createContents(){
fig_0 = new
fig_0.setText("StopState");&am p;#xD;
		setFigureStopStateNameLabel(fig_0 );
& ;#x9;Object
layData0 =
&am p;#xD;
		this.add(fig_0,
layData0);
		org.eclipse.dr aw2d.Ellipse fig_1 = new
& ;#xA;		fig_1.setPreferredSize(getMapMode().D PtoLP(60),
		 ;fig_1.setMaximumSize(new
org.eclipse.draw2d.geometry.Dimension(getMapMode().DPtoLP(80 ),
	&#x 9;fig_1.setMinimumSize(new
org.eclipse.draw2d.geometry.Dimension(getMapMode().DPtoLP(60 ),
new
getMapMode().DPtoLP(5), getMapMode().DPtoLP(5),
		org.eclipse.draw2d.Bord erLayout
layouter1 = new
& #x9;	fig_1.setLayoutManager(layouter1);
& ;#xA;
		s etFigureouterEllipse(fig_1);
	& #x9;
	Object
layData1 =
&am p;#xD;
		this.add(fig_1,
layData1);
		org.eclipse.dr aw2d.Ellipse fig_2 = new
& ;#xA;		fig_2.setFillXOR(true);
& #xA;		fig_2.setBackgroundColor(org.eclipse.d raw2d.ColorConstants.black
&#x A;);
&a mp;#xD;
	 ;Object
layData2 =
&am p;#xD;
		fig_1.add(fig_2,
layData2);
& ;#x9;
& amp;#x9;/**
* @generated
	private
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel fStopStateNameLabel;
getFigureStopStateNameLabel() {
		return
&am p;#xA;
&# xA;
* @generated
	private void
setFigureStopStateNameLabel(org.eclipse.gmf.runtime.draw2d.u i.figures.WrapLabel
fig){
		fStopStateNameLabel =
fig;
& amp;#xA;
	/**& ;#xD;
* @generated
	private
	public org.eclipse.draw2d.Ellipse getFigureOuterEllipse()
		return
fOuterEllipse;
&am p;#x9;
* @generated
	private void
setFigureouterEllipse(org.eclipse.draw2d.Ellipse
fig){
		fOuterEllipse =
fig;
& amp;#xA;
&#x A;	/**
* @generated
	private boolean
	/**&# xD;
@generated
	protected boolean
		return
& amp;#xA;
& ;#x9;
* @generated
	protected void
&am p;#xA;
</viewmap>
<modelFacet>
<metaClass
href="model/statemachine2.genmodel#//statemachine2/StopState "/>
<childMetaFeature
</modelFacet>
<labels
visualID="5005"
editPartClassName="StopStateName2EditPart"
itemSemanticEditPolicyClassName="StopStateName2ItemSemanticEditPolicy "
notationViewFactoryClassName="StopStateName2ViewFactory"
elementIcon="true">
<viewmap
getterName="getFigureStopStateNameLabel"
<modelFacet
<metaFeature
</modelFacet>
</labels>
</childNodes>
<childNodes
visualID="3005"
editPartClassName="CompositeState2EditPart"
itemSemanticEditPolicyClassName="CompositeState2ItemSemanticEditPolicy "
notationViewFactoryClassName="CompositeState2ViewFactory"
canonicalEditPolicyClassName="CompositeState2CanonicalEditPolicy "
compartments="//@diagram/@compartments.4 //@diagram/@compartments.5"
graphicalNodeEditPolicyClassName="CompositeState2GraphicalNodeEditPolicy "
containers="//@diagram/@compartments.5 //@diagram/@compartments.2">
<elementType
metamodelType="//@diagram/@topLevelNodes.3/@elementType"
editHelperAdviceClassName="CompositeStateEditHelperAdvice"/ >
<viewmap
className="CompositeStateFigure"
classBody="
@generated
& #xA;
&a mp;#xD;
* @generated
	private void
createContents(){
fig_0 = new
fig_0.setText("<Huzifaki > ");
		fig_0.setBac kgroundColor(org.eclipse.draw2d.ColorConstants.black
&am p;#xA;
		 setFigureCompositeNameLabel(fig_0);
&#x 9;
		Object
layData0 = null;
		t his.add(fig_0,
layData0);
& ;#x9;
& amp;#x9;/**
* @generated
	private
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel fCompositeNameLabel;
		return
&am p;#xA;
&# xA;
* @generated
	private void
setFigureCompositeNameLabel(org.eclipse.gmf.runtime.draw2d.u i.figures.WrapLabel
fig){
fig;
& amp;#xA;
&#x A;	/**
* @generated
	private boolean
	/**&# xD;
@generated
	protected boolean
		return
& amp;#xA;
& ;#x9;
* @generated
	protected void
useLocalCoordinates;&#
Re: Missing methods in a generated Class [message #52931 is a reply to message #51238] |
Thu, 21 September 2006 09:39  |
Hi Michael,
thanks for the great explanation. It helped me a lot. The Statemachine
is running now. :)
Thanks!
Christian
Michael Golubev schrieb:
> CompositeNameLabel.
> figures hierarchy_.
> Michael
>> files are:
>> generation?
>> Regards,
>> Christian
>> <?xml version="1.0" encoding="UTF-8"?>
>> </eClassifiers>
>> lowerBound="1"
>> upperBound="-1"
>> </eClassifiers>
>> abstract="true">
>> upperBound="-1"
>> upperBound="-1"
>> upperBound="-1"
>> </eClassifiers>
>> </eClassifiers>
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
>> <genEnumLiterals
>> <genEnumLiterals
>> </genEnums>
>> </genClasses>
>> </genClasses>
>> </genClasses>
>> </genClasses>
>> </genClasses>
>> </genPackages>
>> <figures
>> name="Default">
>> <figures
>> name="StateFigure">
>> <children
>> text="<...>"/>
>> <backgroundColor
>> value="lightGray"/>
>> </figures>
>> <figures
>> <children
>> text="<...>"/>
>> <children
>> name="RE">
>> <backgroundColor
>> green="128"/>
>> <location/>
>> <size
>> y="1"/>
>> <template
>> x="-1"
>> y="1"/>
>> <template
>> x="-1"
>> y="-1"/>
>> <template
>> y="-1"/>
>> <template/>
>> </children>
>> <backgroundColor
>> value="darkGray"/>
>> </figures>
>> <figures
>> lineWidth="2">
>> <children
>> lineWidth="2">
>> <backgroundColor
>> </children>
>> <backgroundColor
>> </figures>
>> <figures
>> <children
>> text="<Huzifaki>">
>> <backgroundColor
>> value="black"/>
>> </children>
>> <backgroundColor
>> value="lightGray"/>
>> </figures>
>> <figures
>> <children
>> name="ActionLabel"
>> text="<...>"/>
>> </figures>
>> <figures
>> <layout
>> <children
>> lineWidth="2">
>> <layoutData
>> <backgroundColor
>> </children>
>> <children
>> text="StartState">
>> <layoutData
>> alignment="END"
>> vertical="true"/>
>> </children>
>> </figures>
>> <figures
>> <layout
>> <children
>> text="StopState">
>> <layoutData
>> alignment="END"
>> vertical="true"/>
>> </children>
>> <children
>> <layoutData
>> <layout
>> <children
>> name="innerEllipse"
>> xorFill="true">
>> <layoutData
>> <backgroundColor
>> value="black"/>
>> </children>
>> <maximumSize
>> dx="80"
>> dy="80"/>
>> <minimumSize
>> dx="60"
>> dy="60"/>
>> <preferredSize
>> dx="60"
>> dy="60"/>
>> <border
>> <insets
>> top="5"
>> left="5"
>> bottom="5"
>> right="5"/>
>> </border>
>> </children>
>> </figures>
>> </figures>
>> <nodes
>> name="State"
>> <nodes
>> name="StartState"
>> <nodes
>> name="StopState"
>> <nodes
>> <nodes
>> name="Action"
>> <connections
>> name="Transition"
>> <compartments
>> <compartments
>> <labels
>> <labels
>> <labels
>> <labels
>> </gmfgraph:Canvas>
>> <palette>
>> <tools
>> title="States">
>> <tools
>> title="State"
>> <smallIcon
>> </tools>
>> <tools
>> title="StartState"
>> <smallIcon
>> </tools>
>> <tools
>> <tools
>> title="StopState"
>> <smallIcon
>> </tools>
>> <tools
>> <smallIcon
>> </tools>
>> </tools>
>> <tools
>> title="Transition"
>> <smallIcon
>> </tools>
>> <tools
>> title="Action"
>> <smallIcon
>> </tools>
>> </palette>
> <diagram
> visualID="1000"
> <elementType
> <viewmap
> <childNodes
> visualID="3001"
> <elementType
> <viewmap
> classBody="
> @generated
& #xA;
& #x9;/**
> * @generated
	private void
> createContents(){
> fig_0 = new
&am p;#xA;
& #xA;		Object
> layData0 = null;
		t his.add(fig_0,
> layData0);
& ;#x9;
& amp;#x9;/**
> * @generated
	private
		return
> fActionLabel;
& amp;#x9;
& ;#x9;
> * @generated
	private void
> fig){
		fActionLabel =
> fig;
& amp;#xA;
&#x A;	/**
> * @generated
	private boolean
	/**&# xD;
> @generated
	protected boolean
		return
& amp;#xA;
& ;#x9;
> * @generated
	protected void
&am p;#xA;
> </viewmap>
> <modelFacet>
> <metaClass
> <childMetaFeature
> </modelFacet>
> <labels
> visualID="5001"
> elementIcon="true">
> <viewmap
> <modelFacet
> <metaFeatures
> <metaFeatures
> </modelFacet>
> </labels>
> </childNodes>
> <childNodes
> visualID="3002"
> <elementType
> <viewmap
> classBody="
> @generated
& #xA;
&a mp;#xD;
> * @generated
	private void
> createContents(){
> fig_0 = new
&am p;#xA;
&a mp;#xA;		Object
> layData0 = null;
		t his.add(fig_0,
> layData0);
& ;#x9;
& amp;#x9;/**
> * @generated
	private
		return
> fStateNameLabel;
&#x A;
& amp;#x9;
> * @generated
	private void
> fig){
		fStateNameLabel =
> fig;
& amp;#xA;
&#x A;	/**
> * @generated
	private boolean
	/**&# xD;
> @generated
	protected boolean
		return
& amp;#xA;
& ;#x9;
> * @generated
	protected void
&am p;#xA;
> <attributes
> </viewmap>
> <modelFacet>
> <metaClass
> <childMetaFeature
> </modelFacet>
> <labels
> visualID="5004"
> elementIcon="true">
> <viewmap
> <modelFacet
> <metaFeature
> </modelFacet>
> </labels>
> </childNodes>
> <childNodes
> visualID="3003"
> <elementType
> <viewmap
> classBody="
> @generated
& #xA;	/**
> * @generated
	private void
> createContents(){
& #xA;
& amp;#xA;
	Object
> layData0 =
&am p;#xD;
		this.add(fig_0,
> layData0);
> fig_1 = new
&a mp;#x9;Object
> layData1 =
&am p;#xD;
		this.add(fig_1,
> layData1);
& ;#x9;
& amp;#x9;/**
> * @generated
	private
		return
> fStartStateEllipse;
& ;#xA;
&#x A;
> * @generated
	private void
> fig){
> fig;
& amp;#xA;
	/**& ;#xD;
> * @generated
	private
		return
&a mp;#xA;
& #xA;
> * @generated
	private void
> fig){
> fig;
& amp;#xA;
&#x A;	/**
> * @generated
	private boolean
	/**&# xD;
> @generated
	protected boolean
		return
& amp;#xA;
& ;#x9;
> * @generated
	protected void
&am p;#xA;
& #xA;	/**
> * @generated
	public static final
> </viewmap>
> <modelFacet>
> <metaClass
> <childMetaFeature
> </modelFacet>
> </childNodes>
> <childNodes
> visualID="3004"
> <elementType
> <viewmap
> classBody="
> @generated
 ;		createContents();
&# x9;}
&a mp;#x9;/**
> * @generated
	private void
> createContents(){
> fig_0 = new
& ;#x9;Object
> layData0 =
&am p;#xD;
		this.add(fig_0,
> layData0);
new
> layouter1 = new
& ;#xA;
	& #x9;
	Object
> layData1 =
&am p;#xD;
		this.add(fig_1,
> layData1);
&#x A;);
&a mp;#xD;
	 ;Object
> layData2 =
&am p;#xD;
		fig_1.add(fig_2,
> layData2);
& ;#x9;
& amp;#x9;/**
> * @generated
	private
		return
&am p;#xA;
&# xA;
> * @generated
	private void
> fig){
> fig;
& amp;#xA;
	/**& ;#xD;
> * @generated
	private
		return
> fOuterEllipse;
&am p;#x9;
> * @generated
	private void
> fig){
		fOuterEllipse =
> fig;
& amp;#xA;
&#x A;	/**
> * @generated
	private boolean
	/**&# xD;
> @generated
	protected boolean
		return
& amp;#xA;
& ;#x9;
> * @generated
	protected void
&am p;#xA;
> </viewmap>
> <modelFacet>
> <metaClass
> <childMetaFeature
> </modelFacet>
> <labels
> visualID="5005"
> elementIcon="true">
> <viewmap
> <modelFacet
> <metaFeature
> </modelFacet>
> </labels>
> </childNodes>
> <childNodes
> visualID="3005"
Current Time: Tue Jul 22 06:33:21 EDT 2025
Powered by FUDForum. Page generated in 0.04274 seconds
