Home » Language IDEs » PHP Development Tools (PDT) » how to use the PDT Debugger with application programs instead of browsers?
how to use the PDT Debugger with application programs instead of browsers? [message #51190] |
Thu, 13 September 2007 14:34  |
I'm trying to use the Zend PDT Debugger to debug PHP scripts that
implement REST and SOAP web services for clients that are application
programs, not browsers.
For my runtime, I have installed "Zend Core for IBM 2.0.3" (Apache
2.2.2, PHP 5.2.3, and Zend Debugger 5.2.9). For my IDE, I have
installed "Eclipse PDT all-in-one-incubation S20070910 RC1".
When the Eclipse "Debug As -> PHP Web Page" action invokes PHP scripts
with a browser, the PDT Debugger works as expected: the Debugger stops
at breakpoints in PHP scripts, and the browser receives the output of
the scripts.
But when an application program (such as a Java or C program, or the
"wget" or "curl" command) invokes the same scripts with the same URLs,
they don't appear to execute at all: the PDT Debugger does not stop on
breakpoints in PHP scripts, and the clients receive no output from the
scripts (that is, the content of HTTP response messages is empty).
The Eclipse "Debug As -> PHP Web Page" action launches browsers with a
URL that contains a lot of debugger-related arguments, like this:
http://localhost/whatever/index.php
?debug_session_id=1005
&start_debug=1
&debug_start_session=1
&debug_host=9.2.26.33%2C127.0.0.1
&debug_no_cache=1189699647453
&debug_port=10000
&send_sess_end=1
&original_url=http://localhost/whatever/index.php
&debug_stop=1
I have not found any documentation on these debugger-related arguments,
or the debugging protocol used on port 10000.
How can application programs written in Java or C invoke PHP scripts
with URLs like these so that the PDT Debugger will work?
-- Edward Pring <pring@us.ibm.com>
Re: how to use the PDT Debugger with application programs instead of browsers? [message #51326 is a reply to message #51190] |
Thu, 13 September 2007 16:19   |
Originally posted by: schreck84.gmail.com
"Edward Pring" <pring@us.ibm.com> wrote in message
news:fcbvrf$q02$1@build.eclipse.org...
> For my runtime, I have installed "Zend Core for IBM 2.0.3" (Apache 2.2.2,
> PHP 5.2.3, and Zend Debugger 5.2.9). For my IDE, I have installed
> with a browser, the PDT Debugger works as expected: the Debugger stops at
> breakpoints in PHP scripts, and the browser receives the output of the
> scripts.
> The Eclipse "Debug As -> PHP Web Page" action launches browsers with a URL
> &start_debug=1
> &debug_port=10000
> &send_sess_end=1
> &debug_stop=1
> I have not found any documentation on these debugger-related arguments, or
> How can application programs written in Java or C invoke PHP scripts with
Check out the following link:
http://www.eclipse.org/pdt/documents/PDT%20-%20Debug%20Proto col.pdf
This is the protocol for the Zend Debugger. Hopefully, that will be a good
start for you. I have not dealt with Zend Debugger too much, but the
document looks impressive (not as much as xDebug, mind you)
Schreck
Re: how to use the PDT Debugger with application programs instead of browsers? [message #51833 is a reply to message #51326] |
Fri, 14 September 2007 14:56   |
>> scripts.
>> &start_debug=1
>> &debug_port=10000
>> &send_sess_end=1
>> &debug_stop=1
> Schreck
Thanks for the pointer. This document lists the debugger-related
arguments (the table appears on page 5, under the heading "4.1. Data
Types:", but it should be on page 4, under the heading "3.2 HTTP
Parameters"). But it does not describe how the PDT Debugger uses them.
The rest of the document describes the binary messages exchanged between
the PHP engine (called the "server" in this document) and the PDT
Debugger (called the "client"). It does not describe how to start a PDT
Debugger session without invoking a browser, or how an application
program can cause a PHP engine to connect to the PDT Debugger.
-- Ed
Re: how to use the PDT Debugger with application programs instead of browsers? [message #51860 is a reply to message #51833] |
Fri, 14 September 2007 15:19  |
I am not sure how the zend debugger within PDT is implemented exactly but if
it is like the xdebug implementation, unless there is a valid PDT launch being
done, any external connection from the debugger (server side) is ignored.
So if you for example just send the URL to a web server, the zend debugger may
attempt to connect to PDT but as there is no associated launch, the connection
is rejected.
I don't know if this is the case for zend, but this is how the xdebug implementation works.
Dave Kelsey
>>> scripts with a browser, the PDT Debugger works as expected: the
>>> Debugger stops at breakpoints in PHP scripts, and the browser
>>> receives the output of the scripts.
>>> URLs, they don't appear to execute at all: the PDT Debugger does not
>>> stop on breakpoints in PHP scripts, and the clients receive no output
>>> from the scripts (that is, the content of HTTP response messages is
>>> empty).
>>> a URL that contains a lot of debugger-related arguments, like this:
>>> &start_debug=1
>>> &debug_port=10000
>>> &send_sess_end=1
>>> &debug_stop=1
>>> arguments, or the debugging protocol used on port 10000.
>> good start for you. I have not dealt with Zend Debugger too much, but
>> the document looks impressive (not as much as xDebug, mind you)
>> Schreck
> -- Ed
Current Time: Mon Jul 14 06:42:27 EDT 2025
Powered by FUDForum. Page generated in 0.08064 seconds
