JRun Plugin Alternative? [message #51167] |
Fri, 06 June 2003 00:31 |
Originally posted by: matt.mattkruse.com
I use the JRun plugin (http://www.monyplaza.net/soft/eclipse_e.xtp) on a
regular basis because unfortunately I'm sometimes forced to develop for the
POS called JRun :)
Are there any alternatives available anywhere?
This version works well, but it only lets me hook into either the 'admin' or
'default' servers. If I have 5 projects, I want them hooked into 5 different
jrun instances, so they all don't start when I startup a single one to test.
Currently I'm commenting out the projects I'm not working on in the jrun
config file, which is a pain.
Are there other alternatives, other than just starting it by hand?
(Having the JRun console right there to immediately see problems and logging
is very handy!)
Thanks!
Matt Kruse
http://www.mattkruse.com/
FUDForum. Page generated in 0.07636 seconds
