Home » Eclipse Projects » Eclipse Platform » How to make buttons on JFace dialog
How to make buttons on JFace dialog [message #51143] Wed, 28 May 2003 04:10 Go to next message
Originally posted by: mnaglik.NOSPAMgazeta.pl
I've got simple form with two labels and two texts
and I want two have default buttons on it (inherited from jface.dialog)
But they don't appear when I call createButtonBar(parent);
Even when I override createButtonsForButtonBar...
What should I change in code bellow?
import org.eclipse.jface.dialogs.Dialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class ProductDialog extends Dialog {
* @param arg0
public ProductDialog(Shell shell) {
super(shell);
* @see
org.eclipse.jface.window.Window#createContents(org.eclipse.s wt.widgets.Compo
site)
protected Control createContents(Composite container) {
Composite parent = (Composite) super.createDialogArea(container);
Composite composite = new Composite(parent,SWT.NONE);
GridLayout layout = new GridLayout();
composite.setLayout(layout);
layout.numColumns = 2;
layout.verticalSpacing = 9;
Label label0 = new Label(composite,SWT.NONE);
label0.setText("Produkt:");
Text text0 = new Text(composite,SWT.BORDER);
Label label1 = new Label(composite,SWT.NONE);
label1.setText("Ilo
Re: How to make buttons on JFace dialog [message #51199 is a reply to message #51143] Wed, 28 May 2003 05:24 Go to previous messageGo to next message
Originally posted by: stelian.iancu.gmxREMOVE.net
In your dialog class overwrite createDialogArea(Composite aParent) and
createButtonBar(Composite aParent). Here's an example.
Stelian Iancu
"Marcin" <mnaglik@NOSPAMgazeta.pl> wrote in message
news:bb1qnh$e59$1@rogue.oti.com...
Re: How to make buttons on JFace dialog [message #54373 is a reply to message #51143] Thu, 29 May 2003 12:28 Go to previous message
Originally posted by: knut_radloff.oti.com
You should override createDialogArea instead of createContents.
You are missing the call to initializeDialogUnits that Dialog.createContents does for you. If you don't want to override
createDialogArea for some reason you should call super.createContents in your createContents method and then use the result of
getDialogArea to create your dialog widgets.
Just rename createContents to createDialogArea.
Knut
"Marcin" <mnaglik@NOSPAMgazeta.pl> wrote in message news:bb1qnh$e59$1@rogue.oti.com...
> * @param arg0
> super(shell);
> * @see
> site)
> label1.setText("Ilo
Previous Topic:Problem with markers
Next Topic:eclipse not handling international chars
Current Time: Tue Jul 22 02:36:06 EDT 2025
Powered by FUDForum. Page generated in 0.04025 seconds
