Re: Syntax highlighting same as PHPEclipse? [message #505941 is a reply to message #505531] |
Tue, 05 January 2010 15:29  |
Basil Gohar Messages: 24 Registered: July 2009 |
Junior Member |
On 12/31/2009 01:56 PM, Basil Mohamed Gohar wrote:
> I just installed a fresh copy of PDT using Eclipse Classic 3.5
> (following the instructions on this page:
> http://wiki.eclipse.org/PDT/Installation#Eclipse_3.5_.2F_Gal ileo_.2F_PDT_2.2).
> After getting everything up-and-running and recreating my PHP project
> from scratch, I was surprised to find the syntax highlighting of PDT has
> changed to be nearly identical to that of the PHPEclipse project!
> I have to be honest, I found PDT's original syntax highlighting to be
> much better, clearer, and even more appealing to the eye. Is there a
> simple way to revert this back, or what else can I do?
For the time being, I just changed the color scheme back to the
2.1-styling. I guess with 2.2, there are quite a few new highlightable
elements, but I am not sure why the particular colorings were chosen.
For those that are curious, I basically loaded my older copy of Eclipse
with PDT 2.1 and manually changed each syntax coloring element to the
same value as in 2.1, copy-and-pasting the hex color code.
FUDForum. Page generated in 2.35175 seconds
