Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo: Hibernate and Arrays as EDataType
Teneo: Hibernate and Arrays as EDataType [message #51104] Wed, 20 September 2006 05:40 Go to next message
we have an EMF-model in which we have defined an Integer-Array as EDataType:
<eClassifiers xsi:type="ecore:EDataType" name="IntegerArray"
instanceClassName="int[]"/>
So far everything worked just fine using only the EMF-Framework an
storing everything into XML-Files.
But trying to use the EMF - Hibernate integration results in the
following Exception:
org.hibernate.MappingException: Could not determine type for: int[], for
columns: [org.hibernate.mapping.Column(elt)]
at org.hibernate.mapping.SimpleValue.getType(SimpleValue.java:2 66)
at org.hibernate.mapping.SimpleValue.isValid(SimpleValue.java:2 53)
at org.hibernate.mapping.Collection.validate(Collection.java:26 2)
at org.hibernate.cfg.Configuration.validate(Configuration.java: 988)
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1169)
org.eclipse.emf.teneo.hibernate.HbDataStore.buildSessionFact ory(HbDataStore.java:474)
org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:187)
when calling
HbDataStore hbds = HbHelper.INSTANCE.createRegisterDataStore("test");
hbds.setEPackages(new Package[]{MyPackage.eINSTANCE});
hbds.setHibernateProperties(properties);
hbds.initialize(); // <- this throws the Exception
Is this a Bug, are we doing anything wrong, is there a possible workaround ?
greetings,
Hans
Re: Teneo: Hibernate and Arrays as EDataType [message #51243 is a reply to message #51104] Wed, 20 September 2006 11:12 Go to previous messageGo to next message
Hi Hans,
Arrays are not yet supported (elists are). If you want you can enter a bugzilla to give an extra
hint that support for arrays (of primitive types) is important.
As a workaround you can try to manually adapt a generated hibernate.hbm.xml. The hibernate.hbm.xml
is generated with a right click on the .ecore file and then select the submenu under teneo.
gr. Martin
Hans Mueller-Dieckert wrote:
> EDataType:
> at
> at
> at
> at
> when calling
> workaround ?
> greetings,
> Hans
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: Hibernate and Arrays as EDataType [message #51435 is a reply to message #51243] Thu, 21 September 2006 08:24 Go to previous messageGo to next message
Hi Martin,
thank you for your answer! I've just made a bugzilla entry.
Within this I've also described a problem with EByteArray, which is a
EMF-predefined EDataType. I think this is a related problem.
greetings,
Hans
Martin Taal schrieb:
> Hi Hans,
> bugzilla to give an extra hint that support for arrays (of primitive
> hibernate.hbm.xml. The hibernate.hbm.xml is generated with a right click
> gr. Martin
>> EDataType:
>> for columns: [org.hibernate.mapping.Column(elt)]
>> at
>> at
>> at
>> at
>> when calling
>> workaround ?
>> greetings,
>> Hans
Re: Teneo: Hibernate and Arrays as EDataType [message #52195 is a reply to message #51435] Fri, 22 September 2006 10:06 Go to previous messageGo to next message
Hi Hans,
Support for arrays has been added in the version in cvs and will be available in the next build
(probably next week).
Other remarks:
- Only primitive type arrays are supported.
- Arrays are currently persisted in a separate table (so not serialized in one column/field).
- A byte array can be persisted as a blob using the lob annotation from jpa/ejb3.
This addition is done for both hibernate and jpox.
gr. Martin
> Hi Martin,
> greetings,
> Hans
>> Hi Hans,
>> gr. Martin
>>> Hi,
>>> EDataType:
>>> at
>>> at
>>> at
>>> at
>>> when calling
>>> workaround ?
>>> greetings,
>>> Hans
The Netherlands
Re: Teneo: Hibernate and Arrays as EDataType [message #52348 is a reply to message #52195] Mon, 25 September 2006 05:47 Go to previous message
Hi Martin,
thanks for the info. I'll give it a try in the next few days.
greetings,
Hans
> Hi Hans,
> available in the next build (probably next week).
> Other remarks:
> jpa/ejb3.
> gr. Martin
Re: Teneo: Hibernate and Arrays as EDataType [message #591463 is a reply to message #51104] Wed, 20 September 2006 11:12 Go to previous message
Hi Hans,
gr. Martin
> EDataType:
> at
> at
> at
> at
> when calling
> workaround ?
> greetings,
> Hans
The Netherlands
Re: Teneo: Hibernate and Arrays as EDataType [message #591557 is a reply to message #51243] Thu, 21 September 2006 08:24 Go to previous message
Hi Martin,
greetings,
Hans
> Hi Hans,
> gr. Martin
>> EDataType:
>> at
>> at
>> at
>> at
>> when calling
>> workaround ?
>> greetings,
>> Hans
Re: Teneo: Hibernate and Arrays as EDataType [message #591793 is a reply to message #51435] Fri, 22 September 2006 10:06 Go to previous message
Hi Hans,
Other remarks:
gr. Martin
> Hi Martin,
> greetings,
> Hans
>> Hi Hans,
>> gr. Martin
>>> Hi,
>>> EDataType:
>>> at
>>> at
>>> at
>>> at
>>> when calling
>>> workaround ?
>>> greetings,
>>> Hans
The Netherlands
Re: Teneo: Hibernate and Arrays as EDataType [message #591855 is a reply to message #52195] Mon, 25 September 2006 05:47 Go to previous message
Hi Martin,
greetings,
Hans
> Hi Hans,
> Other remarks:
> jpa/ejb3.
> gr. Martin
Previous Topic:Teneo: storing custom EDataType attributes (i.e. java.io.File)
Next Topic:JET - Feature 'version' not found
Current Time: Thu Jul 17 22:03:31 EDT 2025
Powered by FUDForum. Page generated in 0.06624 seconds
