Home » Archived » M2M (model-to-model transformation) » [ATL] Debugging problem
[ATL] Debugging problem [message #51103] Fri, 06 July 2007 10:47 Go to next message
Originally posted by: NewsgroupSPAM.iKupp.de
Im new with ATL and I have a problem with the debugger.
the debugger doesnt work with my old Eclipse 3.2 Version, so I installed
a fresh new 3.3 with ATL, EMF, VE ....
When I startet the debugger the first time with the 3.3 Version with the
Families2Person transformation, everything works fine. Then I started my
own transformation and everything works too (I could navigate thru the
steps and saw the variables, like it should be).
But then I terminated the transformation, and wanted to start the
debugging mode again. After that the debugger wont work (tested with
both transformations).
The console output is:
Trying to connect to remote debuggee
Connected.
sent : 13 - [30:17-30:50]
sent : 13 - [13:9-13:22]
sent : 13 - [34:17-34:47]
and then I can push the resume button or the step buttons once but
nothing happens, and no variables are shown.
I already restarted Eclipse but no change happend.
Any ideas?
It is hard for a beginner to work with atl without the debugging mode :-(
thanks very much,
Ina
P.S. I use Eclipse 3.3, Mac OS X.4.9 and Java 1.5.0_07-87 ATL Debugger 1.0.9
Re: [ATL] Debugging problem [message #51184 is a reply to message #51103] Fri, 06 July 2007 11:26 Go to previous messageGo to next message
The messages you get are about breakpoints.
You may try to remove every breakpoint before launching your transformation.
Frédéric Jouault
Ina Kupp wrote:
> Connected.
> Any ideas?
> thanks very much,
> Ina
> 1.0.9
Re: [ATL] Debugging problem [message #51290 is a reply to message #51184] Sat, 07 July 2007 08:43 Go to previous message
thanks, now the debugger works.
Ina
Frédéric Jouault schrieb:
> Hello,
> transformation.
> Frédéric Jouault
> Ina Kupp wrote:
>> installed a fresh new 3.3 with ATL, EMF, VE ....
>> the Families2Person transformation, everything works fine. Then I
>> started my own transformation and everything works too (I could
>> navigate thru the steps and saw the variables, like it should be).
>> Connected.
>> Any ideas?
>> thanks very much,
>> Ina
>> 1.0.9
Previous Topic:Apply Profiles to UML models?
Next Topic:[ATL/AMW] July 13th, 2007 - Free tutorial - "Practice of model transformation and model weaving
Current Time: Mon Oct 13 15:38:29 EDT 2025
Powered by FUDForum. Page generated in 0.02771 seconds
