[ANN] oXygen XML Editor available as closely integrated eclipse plugin [message #51086] |
Wed, 28 May 2003 03:54  |
Originally posted by: george.sync.ro
A closely integrated version of oXygen is available as oXygen 2.0.2 beta
for Eclipse from
http://www.oxygenxml.com/download.html
Not all the oXygen features are covered (they will be soon) but the core
points are there:
- support for XML, XSL, XSD and DTD documents
- validation and well formed checks reporting problems as problem
markers
- content assistant driven by XML Schema, DTD or the document structure
itself
- syntax coloring
- transformation support allowing both XSLT and FOP
- XPath support allows evaluation of XPath expressions
- format and indent the documents
Feedback more than welcome.
Thank you,
George
George Cristian Bina mailto:george@sync.ro
COO - sync.ro
Phone +40-(0)251-461480, +40-(0)251-461481
Fax +40-(0)251-461482
Mobile +40-(0)723-224067
SyncRO Soft srl, Bd N. Titulescu 170, Craiova, 1100 - Romania
http://www.sync.ro
<oXygen/> XML Editor - http://www.oxygenxml.com/
Re: [ANN] oXygen XML Editor available as closely integrated eclipse plugin [message #51547 is a reply to message #51086] |
Wed, 28 May 2003 06:44   |
erm, what does this plugin do? I dont see syntax coloring on my XML, DTD
or XSD files. The configuration dialog still seems to be swing, and is
not integrated in the eclipse preferences
> for Eclipse from
> points are there:
> markers
> itself
> - syntax coloring
> Thank you,
> George
> COO - sync.ro
> http://www.sync.ro
FUDForum. Page generated in 0.09405 seconds
