Home » Eclipse Projects » Plugin Development Environment (PDE) » Ensuring plugin activation at startup
Ensuring plugin activation at startup [message #4489] |
Wed, 28 May 2008 11:45  |
Originally posted by: respond_to_newsgroup.nowhere.com
What is the recommended way to ensure that a plugin is activated when
eclipse starts up? I've looked at the org.eclipse.ui.startup extension
point, but the doc says it's deprecated.
Re: Ensuring plugin activation at startup [message #4628 is a reply to message #4560] |
Wed, 28 May 2008 15:16   |
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:g1k48p$2un$1@build.eclipse.org...
> In other words, if you think you "need" to activate your plugin on
> startup, think again. If you still think you "need" to, think again.
> Repeat until you realize you don't really need to do it. :-)
I understand the eclipse lazy-activation strategy, but unfortunately I don't
think I can avoid activating it at startup.
Here's the situation: Plugin B (the one I think I have to activate at
startup) needs to register itself as a listener for events that are
generated when a user interacts with features in Plugin A. The only time A
will ever call into B is when it's notifying registered listeners. A can't
depend on B for packaging reasons--B may not be installed. However, B does
depend on A. If there's a way to tell eclipse to activate B when A is
activated, I can avoid activating plugin B at startup. If not, I think I'll
have to activate B at startup, otherwise it won't be active when events
occur. I'm not aware of any way to link two plugins together like that, but
I may just not have stumbled across it.
The docs *are* ambiguous--I wondered if the deprecated part only applied to
having the Activator implement IStartup. So if I add a class to the plugin
that implements IStartup instead of having the Activator do it, that's okay,
right? Thanks for the clarification.
Re: Ensuring plugin activation at startup [message #4835 is a reply to message #4628] |
Thu, 29 May 2008 09:59   |
> depend on A.
I would define an extension point in A to represent listeners of those
events, and then B can implement that extension point with its own
class. That maintains the dependency directionality (B depends on A but
A does not know about B until runtime).
When A is activating, it would get all the extensions (via
Platform.getExtensionRegistry()) that implement its extension point,
instantiate the classes (which will activate the defining plugin, B in
your case), and register them as listeners.
Does that explanation make sense?
Hope this helps,
Eric
Re: Ensuring plugin activation at startup [message #4899 is a reply to message #4835] |
Thu, 29 May 2008 11:55  |
news:g1mcpf$3rs$1@build.eclipse.org...
> events, and then B can implement that extension point with its own class.
> That maintains the dependency directionality (B depends on A but A does
Yes, it makes sense. Thanks, Eric. :-)
Re: Ensuring plugin activation at startup [message #567472 is a reply to message #4489] |
Wed, 28 May 2008 13:21  |
The doc is ambiguous, IIRC. I think it is trying to say that using the
plugin Activator class as the startup extension class is deprecated, not
the entire extension point itself.
Having said that, automatically activating a plugin at startup is
STRONGLY discouraged; Eclipse uses a lazy (on-demand) activation
strategy on purpose - imagine what it would be like if many plugins
decided they needed to be activated on startup... it would take 5
minutes for your workbench to come up.
Eric
Re: Ensuring plugin activation at startup [message #567502 is a reply to message #4560] |
Re: Ensuring plugin activation at startup [message #567614 is a reply to message #4628] |
> depend on A.
Hope this helps,
Eric
Re: Ensuring plugin activation at startup [message #567680 is a reply to message #4835] |
Current Time: Sun Jul 13 08:38:32 EDT 2025
Powered by FUDForum. Page generated in 0.06855 seconds
