Home » Eclipse Projects » Plugin Development Environment (PDE) » Ensuring plugin activation at startup
Ensuring plugin activation at startup [message #4489] Wed, 28 May 2008 11:45 Go to next message
Originally posted by: respond_to_newsgroup.nowhere.com
What is the recommended way to ensure that a plugin is activated when
eclipse starts up? I've looked at the org.eclipse.ui.startup extension
point, but the doc says it's deprecated.
Re: Ensuring plugin activation at startup [message #4560 is a reply to message #4489] Wed, 28 May 2008 13:21 Go to previous messageGo to next message
The doc is ambiguous, IIRC. I think it is trying to say that using the
plugin Activator class as the startup extension class is deprecated, not
the entire extension point itself.
Having said that, automatically activating a plugin at startup is
STRONGLY discouraged; Eclipse uses a lazy (on-demand) activation
strategy on purpose - imagine what it would be like if many plugins
decided they needed to be activated on startup... it would take 5
minutes for your workbench to come up.
In other words, if you think you "need" to activate your plugin on
startup, think again. If you still think you "need" to, think again.
Repeat until you realize you don't really need to do it. :-)
Eric
Re: Ensuring plugin activation at startup [message #4628 is a reply to message #4560] Wed, 28 May 2008 15:16 Go to previous messageGo to next message
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:g1k48p$2un$1@build.eclipse.org...
I understand the eclipse lazy-activation strategy, but unfortunately I don't
think I can avoid activating it at startup.
Here's the situation: Plugin B (the one I think I have to activate at
startup) needs to register itself as a listener for events that are
generated when a user interacts with features in Plugin A. The only time A
will ever call into B is when it's notifying registered listeners. A can't
depend on B for packaging reasons--B may not be installed. However, B does
depend on A. If there's a way to tell eclipse to activate B when A is
activated, I can avoid activating plugin B at startup. If not, I think I'll
have to activate B at startup, otherwise it won't be active when events
occur. I'm not aware of any way to link two plugins together like that, but
I may just not have stumbled across it.
The docs *are* ambiguous--I wondered if the deprecated part only applied to
having the Activator implement IStartup. So if I add a class to the plugin
that implements IStartup instead of having the Activator do it, that's okay,
right? Thanks for the clarification.
Re: Ensuring plugin activation at startup [message #4835 is a reply to message #4628] Thu, 29 May 2008 09:59 Go to previous messageGo to next message
> depend on A.
I would define an extension point in A to represent listeners of those
events, and then B can implement that extension point with its own
class. That maintains the dependency directionality (B depends on A but
A does not know about B until runtime).
When A is activating, it would get all the extensions (via
Platform.getExtensionRegistry()) that implement its extension point,
instantiate the classes (which will activate the defining plugin, B in
your case), and register them as listeners.
Does that explanation make sense?
Hope this helps,
Eric
Re: Ensuring plugin activation at startup [message #4899 is a reply to message #4835] Thu, 29 May 2008 11:55 Go to previous message
news:g1mcpf$3rs$1@build.eclipse.org...
> events, and then B can implement that extension point with its own class.
> That maintains the dependency directionality (B depends on A but A does
Yes, it makes sense. Thanks, Eric. :-)
Re: Ensuring plugin activation at startup [message #567472 is a reply to message #4489] Wed, 28 May 2008 13:21 Go to previous message
Eric
Re: Ensuring plugin activation at startup [message #567502 is a reply to message #4560] Wed, 28 May 2008 15:16 Go to previous message
Re: Ensuring plugin activation at startup [message #567614 is a reply to message #4628] Thu, 29 May 2008 09:59 Go to previous message
> depend on A.
Hope this helps,
Eric
Re: Ensuring plugin activation at startup [message #567680 is a reply to message #4835] Thu, 29 May 2008 11:55 Go to previous message
Previous Topic:Actions and Commands
Next Topic:No more handles [gtk_init_check() failed]
Current Time: Tue Jul 22 01:37:05 EDT 2025
Powered by FUDForum. Page generated in 0.05049 seconds
