Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » NullPointer exception when using Elver/Teneo's HibernateResource (with solution)
NullPointer exception when using Elver/Teneo's HibernateResource (with solution) [message #50908] Mon, 18 September 2006 18:12 Go to next message
Originally posted by: sprakash.tibco.com
Martin,
I used Elver/Teneo's (0.7.2) HibernateResource to execute a Hibernate
query. I get the following NPE:
Exception in thread "main" java.lang.NullPointerException
org.elver.store.resource.StoreResource.attachedHelper(StoreR esource.java:456)
at org.elver.store.resource.StoreResource.attached(StoreResourc e.java:414)
at org.elver.store.resource.StoreResource.load(StoreResource.ja va:245)
I do not get the NPE if I use Hibernate sessions directly i.e. the query
executes just fine. The NPE gets resolved if I add a null check in the
following method of org.elver.store.resource.StoreResource.java (Is this a
valid fix?):
protected void attachedHelper(EObject eObject) {
// a bit strange as an object can only be contained once but this can
happen if someone
// adds an object to a resource directly and then later add this same
object as a child
// to a container
if (eObject == null) return; /* Inserted null check */
if (newEObjects.contains(eObject) || loadedEObjects.contains(eObject))
return;
addedEObject(eObject);
if (isTrackingModification()) {
eObject.eAdapters().add(modificationTrackingAdapter);
Map map = getIntrinsicIDToEObjectMap();
if (map != null) {
String id = EcoreUtil.getID(eObject);
if (id != null) {
map.put(id, eObject);
if (eObject instanceof InternalEObject && eObject.eResource() == null) {
StoreUtil.setEResource((InternalEObject)eObject, this);
// now also attach all ereferences with single values
for (Iterator it = eObject.eClass().getEAllReferences().iterator();
it.hasNext();) {
final EReference eref = (EReference)it.next();
if (!eref.isMany() && eObject.eGet(eref) != null) { // the ismanies are
handled differently
final Resource res = ((EObject)eObject.eGet(eref)).eResource();
if (res == null) { // attach it to this resource because it has no
other
attached((EObject)eObject.eGet(eref));
Re: NullPointer exception when using Elver/Teneo's HibernateResource (with solution) [message #50965 is a reply to message #50908] Tue, 19 September 2006 00:41 Go to previous message
Hi Sundeep,
I am not sure but can you check where the null eobject and npe actually comes from?
As far as I can see the attachedhelper gets the result of an iterator. It seems that the iterator
next statement returns null, although there is a hasNext check.
In the source code I have line 456 is this:
gr. Martin
Sundeep Prakash wrote:
> Martin,
> at
> at
> a valid fix?):
> this can happen if someone
> same object as a child
> // to a container
> loadedEObjects.contains(eObject)) return;
> if (map != null) {
> if (id != null) {
> null) {
> for (Iterator it =
> eObject.eClass().getEAllReferences().iterator(); it.hasNext();) {
> ismanies are handled differently
> it has no other
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: NullPointer exception when using Elver/Teneo's HibernateResource (with solution) [message #591358 is a reply to message #50908] Tue, 19 September 2006 00:41 Go to previous message
Hi Sundeep,
gr. Martin
> Martin,
> at
> at
> a valid fix?):
> // to a container
> if (map != null) {
> if (id != null) {
> null) {
> for (Iterator it =
> it has no other
The Netherlands
Previous Topic:Teneo: Hibernate 3.2rc4 incompatibility
Next Topic:Re: Ecore to DBSchema...Is sympedia's CDO same as the one in EMFT now
Current Time: Sat Jul 12 23:47:58 EDT 2025
Powered by FUDForum. Page generated in 0.03692 seconds
