Home » Archived » BIRT » BIRT Charting on OS X 10.6(Adding a chart to BIRT report using OX X 10.6 (Snow Leopard) causes Eclipse to crash)
BIRT Charting on OS X 10.6 [message #503011] |
Thu, 10 December 2009 15:05 |
No real name Messages: 1 Registered: December 2009 |
Junior Member |
Hi there,
I've recently installed Eclipse including BIRT onto my Mac (see below for further details) and whenever I try to add a chart to a report Eclipse crashes (it crashes after I return from the chart dialog to the layout screen).
I didn't see this kind of behaviour with OS X 10.5 and I've run out of ideas of how to address.
Eclipse / BIRT Version: - I've installed "eclipse-reporting-galileo-SR1-macosx-cocoa-x86_64.tar"
OS Version: Mac OS X 10.6.2
Java Version: Using standard OS X Java 1.6, I also installed Java 1.5 using instructions at http://chxor.chxo.com/post/183013153/installing-java-1-5-on- snow-leopard. That didn't solve the problem.
The full details reported on the crash are below, I'd be very grateful for any assistance ...
Gordon
Process: eclipse [3207]
Path: /Applications/eclipse/Eclipse.app/Contents/MacOS/eclipse
Identifier: org.eclipse.eclipse
Version: 3.5 (3.5)
Code Type: X86-64 (Native)
Parent Process: launchd [86]
Date/Time: 2009-12-10 14:43:51.806 +0000
OS Version: Mac OS X 10.6.2 (10C540)
Report Version: 6
Interval Since Last Report: 43509 sec
Crashes Since Last Report: 1
Per-App Interval Since Last Report: 82 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: B2F4FC32-92A1-47B9-95F1-6993B960C7C6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000014d748100
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
Java information:
Exception type: Bus Error (0xa) at pc=0x00007fff8340e820
Java VM: Java HotSpot(TM) 64-Bit Server VM (14.3-b01-101 mixed mode macosx-amd64)
Current thread (0x0000000113000800): JavaThread "main" [_thread_in_native, id=1882803168, stack(0x00007fff5f400000,0x00007fff5fc00000)]
Stack: [0x00007fff5f400000,0x00007fff5fc00000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J org.eclipse.swt.internal.cocoa.OS.objc_msgSend(JJ)J
j org.eclipse.swt.internal.cocoa.NSBezierPath.fill()V+7
j org.eclipse.swt.graphics.GC.fillRectangle(IIII)V+136
j org.eclipse.birt.chart.reportitem.ui.DesignerRepresentation. paintClientArea(Lorg/eclipse/draw2d/Graphics;)V+244
j org.eclipse.draw2d.Figure.paint(Lorg/eclipse/draw2d/Graphics ;)V+60
j org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.figures.ReportRootFigure.paintChildren(Lorg/eclipse/draw2 d/Graphics;)V+119
j org.eclipse.draw2d.Figure.paintClientArea(Lorg/eclipse/draw2 d/Graphics;)V+143
j org.eclipse.draw2d.Figure.paintChildren(Lorg/eclipse/draw2d/ Graphics;)V+60
j org.eclipse.draw2d.Figure.paintClientArea(Lorg/eclipse/draw2 d/Graphics;)V+120
j org.eclipse.draw2d.ScalableFreeformLayeredPane.paintClientAr ea(Lorg/eclipse/draw2d/Graphics;)V+24
j org.eclipse.draw2d.Figure.paintClientArea(Lorg/eclipse/draw2 d/Graphics;)V+100
j org.eclipse.draw2d.Viewport.paintClientArea(Lorg/eclipse/dra w2d/Graphics;)V+32
j org.eclipse.draw2d.DeferredUpdateManager.paint(Lorg/eclipse/ swt/graphics/GC;)V+71
j org.eclipse.draw2d.LightweightSystem.paint(Lorg/eclipse/swt/ graphics/GC;)V+5
j org.eclipse.draw2d.LightweightSystem$2.handleEvent(Lorg/ecli pse/swt/widgets/Event;)V+8
J org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/sw t/widgets/Event;)V
j org.eclipse.swt.widgets.Display.sendEvent(Lorg/eclipse/swt/w idgets/EventTable;Lorg/eclipse/swt/widgets/Event;)V+24
j org.eclipse.swt.widgets.Widget.sendEvent(Lorg/eclipse/swt/wi dgets/Event;)V+9
j org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/w idgets/Event;Z)V+73
j org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/w idgets/Event;)V+4
j org.eclipse.swt.widgets.Control.drawWidget(JLorg/eclipse/swt /internal/cocoa/NSGraphicsContext;Lorg/eclipse/swt/internal/ cocoa/NSRect;)V+121
j org.eclipse.swt.widgets.Canvas.drawWidget(JLorg/eclipse/swt/ internal/cocoa/NSGraphicsContext;Lorg/eclipse/swt/internal/c ocoa/NSRect;)V+18
j org.eclipse.swt.widgets.Widget.drawRect(JJLorg/eclipse/swt/i nternal/cocoa/NSRect;)V+108
j org.eclipse.swt.widgets.Canvas.drawRect(JJLorg/eclipse/swt/i nternal/cocoa/NSRect;)V+33
J org.eclipse.swt.widgets.Display.windowProc(JJJ)J
v ~StubRoutines::call_stub
j org.eclipse.swt.internal.cocoa.NSView.displayIfNeeded()V+7
j org.eclipse.swt.widgets.Control.update(Z)V+22
j org.eclipse.swt.widgets.Control.update()V+6
j org.eclipse.draw2d.NativeGraphicsSource.getGraphics(Lorg/ecl ipse/draw2d/geometry/Rectangle;)Lorg/eclipse/draw2d/Graphics ;+28
j org.eclipse.draw2d.DeferredUpdateManager.getGraphics(Lorg/ec lipse/draw2d/geometry/Rectangle;)Lorg/eclipse/draw2d/Graphic s;+14
j org.eclipse.draw2d.DeferredUpdateManager.repairDamage()V+206
j org.eclipse.draw2d.DeferredUpdateManager.performUpdate()V+30
j org.eclipse.gef.ui.parts.GraphicalViewerImpl.flush()V+7
j org.eclipse.birt.report.designer.internal.ui.editors.schemat ic.tools.ReportCreationTool$1.run()V+30
j org.eclipse.swt.widgets.RunnableLock.run()V+11
j org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Z)Z+29
j org.eclipse.swt.widgets.Display.runAsyncMessages(Z)Z+5
j org.eclipse.swt.widgets.Display.readAndDispatch()Z+133
j org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/ jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widge ts/Display;)V+9
j org.eclipse.ui.internal.Workbench.runUI()I+393
j org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/i nternal/Workbench;)I+1
j org.eclipse.ui.internal.Workbench$5.run()V+55
j org.eclipse.core.databinding.observable.Realm.runWithDefault (Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/R unnable;)V+12
j org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg /eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/Wor kbenchAdvisor;)I+18
j org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse /swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAd visor;)I+2
j org.eclipse.ui.internal.ide.application.IDEApplication.start (Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Ob ject;+84
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/ lang/Object;)Ljava/lang/Object;+135
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+149
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+161
j org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lan g/String;[Ljava/net/URL;)V+211
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/Strin g;)V+114
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+ 4
Java Threads: ( => current thread )
0x0000000117529000 JavaThread "Worker-6" [_thread_blocked, id=1382105088, stack(0x0000000152514000,0x0000000152614000)]
0x0000000117101000 JavaThread "Worker-5" [_thread_blocked, id=1381044224, stack(0x0000000152411000,0x0000000152511000)]
0x00000001135d6000 JavaThread "Worker-4" [_thread_blocked, id=1365209088, stack(0x00000001514f7000,0x00000001515f7000)]
0x0000000113547000 JavaThread "Worker-3" [_thread_blocked, id=1364148224, stack(0x00000001513f4000,0x00000001514f4000)]
0x0000000117100800 JavaThread "Worker-2" [_thread_blocked, id=1360687104, stack(0x00000001510a7000,0x00000001511a7000)]
0x0000000117178000 JavaThread "Worker-1" [_thread_blocked, id=1316347904, stack(0x000000014e65e000,0x000000014e75e000)]
0x00000001135d5800 JavaThread "Java indexing" daemon [_thread_blocked, id=1353981952, stack(0x0000000150a42000,0x0000000150b42000)]
0x0000000117309000 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=1307627520, stack(0x000000014de0d000,0x000000014df0d000)]
0x0000000117308000 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=1344675840, stack(0x0000000150162000,0x0000000150262000)]
0x0000000117653800 JavaThread "Worker-0" [_thread_blocked, id=1315287040, stack(0x000000014e55b000,0x000000014e65b000)]
0x00000001137f7000 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=1302220800, stack(0x000000014d8e5000,0x000000014d9e5000)]
0x0000000113439000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=1304952832, stack(0x000000014db80000,0x000000014dc80000)]
0x00000001175bb800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=1306566656, stack(0x000000014dd0a000,0x000000014de0a000)]
0x0000000117481000 JavaThread "State Data Manager" daemon [_thread_blocked, id=1300824064, stack(0x000000014d790000,0x000000014d890000)]
0x0000000113094800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=1263943680, stack(0x000000014b464000,0x000000014b564000)]
0x0000000117022000 JavaThread "CompilerThread1" daemon [_thread_blocked, id=1262882816, stack(0x000000014b361000,0x000000014b461000)]
0x0000000117021800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1261821952, stack(0x000000014b25e000,0x000000014b35e000)]
0x0000000117020800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1260761088, stack(0x000000014b15b000,0x000000014b25b000)]
0x0000000117020000 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=1259700224, stack(0x000000014b058000,0x000000014b158000)]
0x000000011701f000 JavaThread "Finalizer" daemon [_thread_blocked, id=1258639360, stack(0x000000014af55000,0x000000014b055000)]
0x000000011701e800 JavaThread "Reference Handler" daemon [_thread_blocked, id=1257578496, stack(0x000000014ae52000,0x000000014af52000)]
=>0x0000000113000800 JavaThread "main" [_thread_in_native, id=1882803168, stack(0x00007fff5f400000,0x00007fff5fc00000)]
Other Threads:
0x000000011307a800 VMThread [stack: 0x000000014ad4f000,0x000000014ae4f000] [id=1256517632]
0x0000000117023000 WatcherThread [stack: 0x000000014b567000,0x000000014b667000] [id=1265004544]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 18624K, used 5677K [0x0000000117800000, 0x0000000118cc0000, 0x000000011a190000)
eden space 16000K, 22% used [0x0000000117800000, 0x0000000117b86650, 0x00000001187a0000)
from space 2624K, 78% used [0x00000001187a0000, 0x00000001189a4ea0, 0x0000000118a30000)
to space 2624K, 0% used [0x0000000118a30000, 0x0000000118a30000, 0x0000000118cc0000)
concurrent mark-sweep generation total 63748K, used 40327K [0x000000011a190000, 0x000000011dfd1000, 0x0000000137800000)
concurrent-mark-sweep perm gen total 114584K, used 80118K [0x0000000137800000, 0x000000013e7e6000, 0x0000000147800000)
Virtual Machine Arguments:
JVM Args: -Dosgi.requiredJavaVersion=1.5 -XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts -XX:MaxPermSize=256m -Xms40m -Xmx512m -Xdock:icon=../Resources/Eclipse.icns -XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 1792M, Free = 12M
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.apple.CoreGraphics 0x00007fff8340e820 sseCGSFill8by1 + 224
1 com.apple.CoreGraphics 0x00007fff83492450 rgba32_mark_constshape + 672
2 com.apple.CoreGraphics 0x00007fff83492139 rgba32_mark + 537
3 libRIP.A.dylib 0x00007fff8805fd6e ripl_BltShape + 1980
4 libRIP.A.dylib 0x00007fff8805cd8a ripc_Render + 375
5 libRIP.A.dylib 0x00007fff88078e3e ripc_DrawPath + 678
6 com.apple.CoreGraphics 0x00007fff83469ff3 CGContextDrawPath + 160
7 com.apple.AppKit 0x00007fff85414c16 -[NSBezierPath fill] + 316
8 libswt-pi-cocoa-3555.jnilib 0x000000014ccfe4b1 Java_org_eclipse_swt_internal_cocoa_OS_objc_1msgSend__JJ + 46
9 ??? 0x0000000113a2d9d6 0 + 4624406998
10 ??? 0x00000001139098e9 0 + 4623210729
11 ??? 0x000000011390981a 0 + 4623210522
12 ??? 0x000000011390981a 0 + 4623210522
13 ??? 0x000000011390981a 0 + 4623210522
14 ??? 0x0000000113909cf4 0 + 4623211764
15 ??? 0x000000011390981a 0 + 4623210522
16 ??? 0x000000011390981a 0 + 4623210522
17 ??? 0x0000000113909cf4 0 + 4623211764
18 ??? 0x000000011390981a 0 + 4623210522
19 ??? 0x000000011390981a 0 + 4623210522
20 ??? 0x0000000113909cf4 0 + 4623211764
21 ??? 0x000000011390981a 0 + 4623210522
22 ??? 0x000000011390981a 0 + 4623210522
23 ??? 0x0000000113909cf4 0 + 4623211764
24 ??? 0x000000011390981a 0 + 4623210522
25 ??? 0x000000011390981a 0 + 4623210522
26 ??? 0x000000011390981a 0 + 4623210522
27 ??? 0x0000000113909cf4 0 + 4623211764
28 ??? 0x000000011390981a 0 + 4623210522
29 ??? 0x000000011390981a 0 + 4623210522
30 ??? 0x0000000113909cf4 0 + 4623211764
31 ??? 0x000000011390981a 0 + 4623210522
32 ??? 0x000000011390981a 0 + 4623210522
33 ??? 0x000000011390981a 0 + 4623210522
34 ??? 0x0000000113909cf4 0 + 4623211764
35 ??? 0x000000011390981a 0 + 4623210522
36 ??? 0x000000011390981a 0 + 4623210522
37 ??? 0x0000000113909cf4 0 + 4623211764
38 ??? 0x000000011390981a 0 + 4623210522
39 ??? 0x000000011390981a 0 + 4623210522
40 ??? 0x0000000113a68100 0 + 4624646400
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff81855bba kevent + 10
1 libSystem.B.dylib 0x00007fff81857a85 _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff8185775c _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff81857286 _dispatch_worker_thread2 + 244
4 libSystem.B.dylib 0x00007fff81856bb8 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff81856a55 start_wqthread + 13
Thread 2: Java: Exception Handler Thread
0 libSystem.B.dylib 0x00007fff8183ce3a mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff8183d4ad mach_msg + 59
2 libSystem.B.dylib 0x00007fff818ba147 mach_msg_server + 468
3 libclient.dylib 0x000000011280c6b5 JNI_CreateJavaVM_Impl + 45967
4 libclient.dylib 0x000000011280c681 JNI_CreateJavaVM_Impl + 45915
5 libclient.dylib 0x000000011280b4e8 JNI_CreateJavaVM_Impl + 41410
6 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
7 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 3: Java: Gang worker#0 (Parallel GC Threads)
2 libclient.dylib 0x000000011280bc9b JNI_CreateJavaVM_Impl + 43381
3 libclient.dylib 0x000000011280bb70 JNI_CreateJavaVM_Impl + 43082
4 libclient.dylib 0x000000011280badb JNI_CreateJavaVM_Impl + 42933
5 libclient.dylib 0x000000011280b82a JNI_CreateJavaVM_Impl + 42244
6 libclient.dylib 0x000000011280b639 JNI_CreateJavaVM_Impl + 41747
7 libclient.dylib 0x000000011281fb39 jio_vsnprintf + 251
8 libclient.dylib 0x000000011281fa96 jio_vsnprintf + 88
9 libclient.dylib 0x000000011280b4e8 JNI_CreateJavaVM_Impl + 41410
10 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
11 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 4: Java: Gang worker#1 (Parallel GC Threads)
Thread 5: Java: Concurrent Mark-Sweep GC Thread
2 libclient.dylib 0x000000011280bd50 JNI_CreateJavaVM_Impl + 43562
3 libclient.dylib 0x00000001128252bd jio_vsnprintf + 22655
4 libclient.dylib 0x000000011280bad4 JNI_CreateJavaVM_Impl + 42926
7 libclient.dylib 0x000000011292e473 JVM_Available + 261541
8 libclient.dylib 0x000000011292e3d0 JVM_Available + 261378
9 libclient.dylib 0x000000011282511e jio_vsnprintf + 22240
10 libclient.dylib 0x000000011280b4e8 JNI_CreateJavaVM_Impl + 41410
11 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
12 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 6: Java: VM Thread
7 libclient.dylib 0x000000011288ca59 JVM_Lseek + 152437
8 libclient.dylib 0x000000011288c881 JVM_Lseek + 151965
Thread 7: Java: Reference Handler
4 libclient.dylib 0x000000011289d048 JVM_MonitorWait + 3976
5 libclient.dylib 0x000000011289c3a6 JVM_MonitorWait + 742
6 libclient.dylib 0x000000011289c16b JVM_MonitorWait + 171
7 ??? 0x00000001139156a8 0 + 4623259304
10 ??? 0x00000001139043f1 0 + 4623188977
11 libclient.dylib 0x000000011288dc1d JVM_Lseek + 156985
12 libclient.dylib 0x000000011288da15 JVM_Lseek + 156465
13 libclient.dylib 0x000000011289bc57 JVM_InternString + 1459
14 libclient.dylib 0x000000011289bb4c JVM_InternString + 1192
15 libclient.dylib 0x000000011289bab5 JVM_InternString + 1041
16 libclient.dylib 0x000000011289b953 JVM_InternString + 687
17 libclient.dylib 0x000000011289b607 JVM_StartThread + 1211
18 libclient.dylib 0x000000011280b4e8 JNI_CreateJavaVM_Impl + 41410
19 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
20 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 8: Java: Finalizer
9 ??? 0x0000000113909973 0 + 4623210867
10 ??? 0x0000000113909973 0 + 4623210867
11 ??? 0x00000001139043f1 0 + 4623188977
12 libclient.dylib 0x000000011288dc1d JVM_Lseek + 156985
13 libclient.dylib 0x000000011288da15 JVM_Lseek + 156465
14 libclient.dylib 0x000000011289bc57 JVM_InternString + 1459
15 libclient.dylib 0x000000011289bb4c JVM_InternString + 1192
16 libclient.dylib 0x000000011289bab5 JVM_InternString + 1041
17 libclient.dylib 0x000000011289b953 JVM_InternString + 687
18 libclient.dylib 0x000000011289b607 JVM_StartThread + 1211
19 libclient.dylib 0x000000011280b4e8 JNI_CreateJavaVM_Impl + 41410
20 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
21 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 9: Java: Surrogate Locker Thread (CMS)
6 libclient.dylib 0x000000011280b5c2 JNI_CreateJavaVM_Impl + 41628
7 libclient.dylib 0x00000001128aaf30 JVM_IsPrimitiveClass + 5612
8 libclient.dylib 0x00000001128aabc1 JVM_IsPrimitiveClass + 4733
9 libclient.dylib 0x000000011289b953 JVM_InternString + 687
10 libclient.dylib 0x000000011289b607 JVM_StartThread + 1211
11 libclient.dylib 0x000000011280b4e8 JNI_CreateJavaVM_Impl + 41410
12 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
13 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 10: Java: Signal Dispatcher
0 libSystem.B.dylib 0x00007fff8183ce76 semaphore_wait_trap + 10
1 libclient.dylib 0x00000001128ab7b4 JVM_IsPrimitiveClass + 7792
2 libclient.dylib 0x00000001128ab659 JVM_IsPrimitiveClass + 7445
3 libclient.dylib 0x000000011289b953 JVM_InternString + 687
4 libclient.dylib 0x000000011289b607 JVM_StartThread + 1211
Thread 11: Java: CompilerThread0
7 libclient.dylib 0x00000001128aef2d JVM_IsPrimitiveClass + 21993
8 libclient.dylib 0x00000001128ac586 JVM_IsPrimitiveClass + 11330
9 libclient.dylib 0x00000001128ac451 JVM_IsPrimitiveClass + 11021
10 libclient.dylib 0x000000011289b953 JVM_InternString + 687
11 libclient.dylib 0x000000011289b607 JVM_StartThread + 1211
12 libclient.dylib 0x000000011280b4e8 JNI_CreateJavaVM_Impl + 41410
13 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
14 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 12: Java: CompilerThread1
Thread 13: Java: Low Memory Detector
7 libclient.dylib 0x00000001128af6cd JVM_IsPrimitiveClass + 23945
8 libclient.dylib 0x000000011289b953 JVM_InternString + 687
9 libclient.dylib 0x000000011289b607 JVM_StartThread + 1211
Thread 14: Java: VM Periodic Task Thread
3 libclient.dylib 0x00000001128b02cd JVM_IsPrimitiveClass + 27017
4 libclient.dylib 0x00000001128b0019 JVM_IsPrimitiveClass + 26325
Thread 15: Java: State Data Manager
3 libclient.dylib 0x00000001128b024b JVM_IsPrimitiveClass + 26887
4 libclient.dylib 0x0000000112995d98 JVM_Sleep + 186
5 ??? 0x00000001139156a8 0 + 4623259304
8 ??? 0x00000001139043f1 0 + 4623188977
9 libclient.dylib 0x000000011288dc1d JVM_Lseek + 156985
10 libclient.dylib 0x000000011288da15 JVM_Lseek + 156465
11 libclient.dylib 0x000000011289bc57 JVM_InternString + 1459
12 libclient.dylib 0x000000011289bb4c JVM_InternString + 1192
13 libclient.dylib 0x000000011289bab5 JVM_InternString + 1041
14 libclient.dylib 0x000000011289b953 JVM_InternString + 687
15 libclient.dylib 0x000000011289b607 JVM_StartThread + 1211
16 libclient.dylib 0x000000011280b4e8 JNI_CreateJavaVM_Impl + 41410
17 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
18 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 16: Java: Start Level Event Dispatcher
Thread 17: Java: Framework Event Dispatcher
Thread 18: Java: [Timer] - Main Queue Handler
4 libclient.dylib 0x000000011289cd53 JVM_MonitorWait + 3219
9 ??? 0x0000000113909cf4 0 + 4623211764
Thread 19: Java: Worker-0
3 libclient.dylib 0x0000000112a08ff5 JVM_ResolveClass + 7879
4 libclient.dylib 0x0000000112a08d2e JVM_ResolveClass + 7168
7 ??? 0x000000011390981a 0 + 4623210522
8 ??? 0x0000000113909cf4 0 + 4623211764
11 ??? 0x0000000113909973 0 + 4623210867
12 ??? 0x0000000113909973 0 + 4623210867
13 ??? 0x00000001139043f1 0 + 4623188977
14 libclient.dylib 0x000000011288dc1d JVM_Lseek + 156985
15 libclient.dylib 0x000000011288da15 JVM_Lseek + 156465
16 libclient.dylib 0x000000011289bc57 JVM_InternString + 1459
17 libclient.dylib 0x000000011289bb4c JVM_InternString + 1192
18 libclient.dylib 0x000000011289bab5 JVM_InternString + 1041
19 libclient.dylib 0x000000011289b953 JVM_InternString + 687
20 libclient.dylib 0x000000011289b607 JVM_StartThread + 1211
21 libclient.dylib 0x000000011280b4e8 JNI_CreateJavaVM_Impl + 41410
22 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
23 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 20: Java: Bundle File Closer
Thread 21: Java: [ThreadPool Manager] - Idle Thread
Thread 22:
0 libSystem.B.dylib 0x00007fff818569da __workq_kernreturn + 10
1 libSystem.B.dylib 0x00007fff81856dec _pthread_wqthread + 917
2 libSystem.B.dylib 0x00007fff81856a55 start_wqthread + 13
Thread 23: Java: Java indexing
10 ??? 0x0000000113909cf4 0 + 4623211764
Thread 24: JavaScriptCore: FastMalloc scavenger
0 libSystem.B.dylib 0x00007fff818779ee __semwait_signal + 10
1 libSystem.B.dylib 0x00007fff8187b7f1 _pthread_cond_wait + 1286
2 com.apple.JavaScriptCore 0x00007fff874d82b3 WTF::TCMalloc_PageHeap::scavengerThread() + 515
3 com.apple.JavaScriptCore 0x00007fff874d82f9 WTF::TCMalloc_PageHeap::runScavengerThread(void*) + 9
4 libSystem.B.dylib 0x00007fff81875f8e _pthread_start + 331
5 libSystem.B.dylib 0x00007fff81875e41 thread_start + 13
Thread 25:
2 com.apple.CoreFoundation 0x00007fff872a27a2 __CFRunLoopRun + 1698
3 com.apple.CoreFoundation 0x00007fff872a1c2f CFRunLoopRunSpecific + 575
4 com.apple.Foundation 0x00007fff8157e4cf +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 297
5 com.apple.Foundation 0x00007fff814fee99 __NSThread__main__ + 1429
Thread 26:
0 libSystem.B.dylib 0x00007fff818809e2 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x00007fff872c4242 __CFSocketManager + 818
Thread 27: Java: Worker-1
Thread 28: Java: Worker-2
Thread 29: Java: Worker-3
Thread 30: Java: Worker-4
Thread 31: Java: Worker-5
Thread 32: Java: Worker-6
Thread 33:
Thread 34:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000690 rbx: 0x00000000ffffffff rcx: 0x00000000ffffffff rdx: 0x00000000ffffffff
rdi: 0x00000000ffffffff rsi: 0x0000000000000001 rbp: 0x00007fff5fbf9cb0 rsp: 0x00007fff5fbf9c88
r8: 0x000000014d748100 r9: 0x0000000000000000 r10: 0x000000000001a400 r11: 0x00000000ffffffff
r12: 0x00000000ffffffff r13: 0x000000000001a400 r14: 0x00000000ffffffff r15: 0x000000000001a3ff
rip: 0x00007fff8340e820 rfl: 0x0000000000010216 cr2: 0x000000014d748100
Binary Images:
0x100000000 - 0x100003fff +org.eclipse.eclipse 3.5 (3.5) /Applications/eclipse/Eclipse.app/Contents/MacOS/eclipse
0x1000f2000 - 0x1000f9fff +eclipse_1207.so ??? (???) /Applications/eclipse/plugins/org.eclipse.equinox.launcher.c ocoa.macosx.x86_64_1.0.1.R35x_v20090707/eclipse_1207.so
0x1
Re: BIRT Charting on OS X 10.6 [message #503273 is a reply to message #503011] |
Fri, 11 December 2009 16:08 |
Gordon,
Can you log a bug for this?
Jason
gb@just-eat.com wrote:
> Hi there,
> layout screen).
> Gordon
> Version: 3.5 (3.5)
> Report Version: 6
> Java information:
> macosx-amd64)
> d/Graphics;)V+119
> d/Graphics;)V+143
> Graphics;)V+60
> d/Graphics;)V+120
> Graphics;)V+60
> d/Graphics;)V+120
> Graphics;)V+60
> d/Graphics;)V+120
> Graphics;)V+60
> d/Graphics;)V+120
> Graphics;)V+60
> d/Graphics;)V+100
> w2d/Graphics;)V+32
> Graphics;)V+60
> d/Graphics;)V+120
> graphics/GC;)V+5
> t/widgets/Event;)V
> dgets/Event;)V+9
> idgets/Event;Z)V+73
> idgets/Event;)V+4
> cocoa/NSRect;)V+121
> ocoa/NSRect;)V+18
> ts/Display;)V+9
> kbenchAdvisor;)I+18
> Other Threads:
> Heap
> 0x00000001187a0000)
> 0x0000000118a30000)
> 0x0000000118cc0000)
> 537
> + 1980
> 375
> + 678
> start_wqthread + 13
> + 10
> + 13
> + 10
> + 251
> + 88
> + 13
> + 10
> + 251
> + 88
> + 13
> + 10
> + 22655
> + 261541
> + 261378
> + 22240
> + 13
> + 10
> + 22655
> 152437
> 151965
> + 13
> + 10
> 156985
> 156465
> + 13
> + 10
> 156985
> 156465
> + 13
> + 10
> + 13
> + 13
> + 10
> + 13
> + 10
> + 13
> + 10
> + 13
> + 10
> + 13
> + 10
> 156985
> 156465
> + 13
> + 10
> 156985
> 156465
> + 13
> + 10
> 156985
> 156465
> + 13
> + 10
> + 22655
> 156985
> 156465
> + 13
> + 10
> 156985
> 156465
> + 13
> + 10
> 156985
> 156465
> + 13
> + 10
> 156985
> 156465
> + 13
> Thread 22:
> start_wqthread + 13
> + 10
> 156985
> 156465
> + 13
> + 13
> Thread 25:
> + 10
> + 13
> Thread 26:
> + 13
> + 10
> + 22655
> 156985
> 156465
> + 13
> + 10
> + 22655
> 156985
> 156465
> 20 libSy
Re: BIRT Charting on OS X 10.6 [message #505738 is a reply to message #505719] |
Mon, 04 January 2010 12:50 |
Jim,
I will ping the team again. Have you tried any of the 2.5 or 2.6
nightly builds?
Jason
jponeill@ducatcommerce.com wrote:
> Hi Jason,
> Any update on this? Unless there is a workaround, the BiRT designer is
> unusable on OS X 10.6.
> [I see bugzilla says it'll be fixed in 2.5.2 but I'm hoping that there
> will be a nightly build soon that I can grab].
> Thanks, Jim
Current Time: Fri Apr 26 00:48:30 GMT 2024
Powered by FUDForum. Page generated in 0.03416 seconds
