Home » Eclipse Projects » GEF » how to refresh the view after a part was added?
how to refresh the view after a part was added? [message #50846] Mon, 23 December 2002 17:21 Go to next message
Originally posted by: HeinzGraalfs.web.de
I tried to change the model for the GEF 6 sample.
I added a selection pane entry to add a new node.
Basically it works 'fine', but I don't know how to refresh the view to see
the
added node element.
When I debug the model I see my newly added EditPart in the Model (the
Model now has an ArrayList not the fixed size Vector) but the added node
doesn't show up in the actual view.
How does the Framework works? Is there some more documentation available?
I can debug thru GEF, but that can't be the solution in order to get
familiar with this framework.
Perhaps somebody can help?
Heinz
Re: how to refresh the view after a part was added? [message #50902 is a reply to message #50846] Tue, 24 December 2002 11:19 Go to previous messageGo to next message
Originally posted by: eric_to_jeff.hotmail.com
Hi Heinz,
I think your model should add property change listener to your editpart,
just like Logic Designer Example:
getLogicSubpart().addPropertyChangeListener(this);
if the properties of your model changed, the model should broadcast the
event to all its listener.
and the editpart should handle PropertyChangeEvent event use
propertyChange method.
Eric Suen
"Heinz " <HeinzGraalfs@web.de> ??????:au82a6$mgo$1@rogue.oti.com...
| the
| added node element.
| Heinz
Re: how to refresh the view after a part was added? [message #51093 is a reply to message #50902] Wed, 25 December 2002 12:23 Go to previous messageGo to next message
Hi Eric, thanks for the answer, I'll try ASAP and let you know if it
helped.
Merry Christmas to all GEF enthusiasts!
Heinz
Eric Suen wrote:
> Hi Heinz,
> Regards
> Eric Suen
> | the
> | added node element.
> | Heinz
Re: how to refresh the view after a part was added? [message #51231 is a reply to message #51093] Thu, 26 December 2002 16:30 Go to previous messageGo to next message
Hi Eric,
I was finally able to add rectangle objects thru an additional palette
CreationTool entry.
As I said I had the added object within my model.
I had already the code you suggested. But the refresh on the TopEditPart
was
missing. The refresh() causes to call the getModelChildren() of the the
TopEditPart and that performs the activate() on the EditPart. That was it.
Now I want to
1. be able to delete a current selection (part or connection)
2. display names for the parts and connectors
3. create a right mouse click popup menu for a current selection and
implement
some functionality for the current selection
4. display properties of the parts and connections in a property pane
Do you have some simple samples or hints in order to do these kinds of
trivial things? Unfortunately it doesn't seem to be that simple without
any kind of additional documentation.
Heinz
> helped.
> Heinz
> Eric Suen wrote:
> > Hi Heinz,
editpart,
> > Regards
> > Eric Suen
see
> > | the
> > | added node element.
> > | Heinz
Re: how to refresh the view after a part was added? [message #51258 is a reply to message #51231] Thu, 26 December 2002 22:20 Go to previous message
Originally posted by: hudsonr.us.eye-bee-em.com
"Heinz" <HeinzGraalfs@web.de> wrote in message
news:aufsda$dbr$1@rogue.oti.com...
> Hi Eric,
> CreationTool entry.
> was
> Now I want to
See DeleteAction
This is non-trivial, depending on the flexibility of such labels.
> implement
We are currently looking at reworking the context menu. See
contextMenuProvider for now.
Read the workbench documentation on the property sheet and IPropertySource.
AbstractEditPart is IAdaptable, and will implement getAdapter properly.
Look at the model in logic example.
> Heinz
> > helped.
> > Heinz
> > Eric Suen wrote:
> > > Hi Heinz,
> editpart,
the
> > > Regards
> > > Eric Suen
to
> see
> > > | the
> > > | added node element.
(the
node
available?
> > > | Heinz
Previous Topic:Connection Anchor question in Logic Editor Example
Next Topic:GUI-Editor with GEF
Current Time: Sun Aug 31 12:57:50 EDT 2025
Powered by FUDForum. Page generated in 0.14075 seconds
