Home » Eclipse Projects » Plugin Development Environment (PDE) » Shared target platform, debugging, and multiple dev platforms
Shared target platform, debugging, and multiple dev platforms [message #50834] |
Wed, 18 March 2009 12:54  |
[Sorry for the cross-post, but I'm not sure which audience is most
likely to be able to help]
Our team uses a shared (in CVS) target platform. This target includes
the Eclipse SDK (3.4.1) and a lot of other features/plugins. It includes
the SWT source plugins for both win32 and macosx.
The problem is when debugging on OS X. During coding, navigating the
code for SWT classes works correctly, it uses the macosx source plugin
and displays the OS X specific code. But when debugging, the debugger is
using the win32 source code instead, even though what is executing is
(obviously) the macosx code. It results in the debugger line numbers not
aligning properly with the displayed source files.
The launch configuration we use for launching our app on Mac
specifically excludes all win32 SWT plugins and specifically includes
the macosx SWT source and binary plugins.
So what is the proper way to set up a dev environment that uses a shared
target platform and will debug properly on both Windows and Mac?
Any help appreciated,
Eric
Re: Shared target platform, debugging, and multiple dev platforms [message #51175 is a reply to message #50948] |
Thu, 19 March 2009 10:58  |
>> includes the SWT source plugins for both win32 and macosx.
>> is using the win32 source code instead, even though what is executing
>> is (obviously) the macosx code. It results in the debugger line
>> numbers not aligning properly with the displayed source files.
> It looks like you are bit by this issue:
> 247766: Incorrect editor opened on breakpoint when delta pack is
> installed in target
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=247766
Yes, Chris, I think that is what we're bumping into. Thanks for the
pointer; I've added some comments about our particular scenario.
Eric
Re: Shared target platform, debugging, and multiple dev platforms [message #593430 is a reply to message #50834] |
Wed, 18 March 2009 18:00  |
installed in target
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Shared target platform, debugging, and multiple dev platforms [message #593590 is a reply to message #50948] |
> installed in target
Eric
Current Time: Mon Jul 07 11:08:32 EDT 2025
Powered by FUDForum. Page generated in 0.07010 seconds
