Re: How to make an expression plug-in work in the web viewer? [message #502317 is a reply to message #502203] |
Mon, 07 December 2009 16:44 |
Colin,
First - Very cool plugin idea :>
Can you look at the revised plugin example for that blog post here:
http://www.birt-exchange.org/devshare/designing-birt-reports /1101-example-plugin-for-expression-builder/#description
It was modified to work with 2.5.1. Can you verify that it works
deployed for you? If you can send me your plugin in email I can try to
debug it. Note that the arguments for execute have been extended:
public Object execute( Object[] args, IScriptFunctionContext arg1 )
throws BirtException
Also verify you have no dependencies on any ui plugin.
Jason
Colin wrote:
> We have written a plug-in for BIRT as specified in
> http://birtworld.blogspot.com/2008/09/birt-231-adding-functi ons-to-expression.html
> This plug-in converts a date-time from our database according to a time
> zone also from our database.
> It is working fine in the report designer, both 2.3.1 and 2.5 but this
> plug-in is not working in the web viewer when copied to the plug-in
> directory of the web viewer.
> What else is needed?
> Colin
> The web viewer shows the following error:
> Data (id = 1502):
> - Retrieving binding data error.
> Error.BindDataRetrivingError ( 1 time(s) )
> detail : org.eclipse.birt.report.engine.api.EngineException: Retrieving
> binding data error.
> at
> org.eclipse.birt.report.engine.internal.document.v4.DataItem Executor.doExecute(DataItemExecutor.java:97)
> at
> org.eclipse.birt.report.engine.internal.document.v4.ReportIt emExecutor.execute(ReportItemExecutor.java:294)
> at
> org.eclipse.birt.report.engine.internal.document.v4.Containe rExecutor.prepareChildExecutor(ContainerExecutor.java:227)
> at
> org.eclipse.birt.report.engine.internal.document.v4.Containe rExecutor.hasNextChild(ContainerExecutor.java:110)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.hasNextChild(WrappedReportItemExecutor.j ava:85)
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:60)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:27)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:133)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:104)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutNodes(HTMLInlineStackingLM.java:153)
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:68)
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:76)
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:101)
> at
> org.eclipse.birt.report.engine.api.impl.RenderTask$PageRange Render.render(RenderTask.java:530)
> at
> org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re nderTask.java:206)
> at
> org.eclipse.birt.report.service.ReportEngineService.renderRe port(ReportEngineService.java:1365)
> at
> org.eclipse.birt.report.service.BirtViewerReportService.getP age(BirtViewerReportService.java:187)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.doExecution(AbstractGetPageActionHandler.java :240)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(AbstractGetPageActionHandler.java:1 07)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
> at
> org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(BirtDocumentProcessor.java:87)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
> at
> org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
> at
> at
> at
> org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
> at
> org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
> at
> org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
> at
> org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
> at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
> at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
> at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
> at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet..java:225)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
> at
> org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:112)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)
> at
> org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:96)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:202)
> at
> at
> org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
> at
> at
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
> at
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
> at
> org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:175)
> at
> org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:74)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
> at
> org.jboss.web.tomcat.tc5.jca.CachedConnectionValve.invoke(Ca chedConnectionValve.java:156)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
> at
> org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:869)
> at
> org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:664)
> at
> org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)
> at
> org.apache.tomcat.util.net.MasterSlaveWorkerThread.run(Maste rSlaveWorkerThread.java:112)
> at java.lang.Thread.run(Thread.java:619)
> Caused by: org.eclipse.birt.data.engine.core.DataException: Error
> happens when try to read value of column: SiteDateTime. This might cause
> by a runtime error in the evaluation of binding expression, i.e. a
> divide 0 error.
> at
> org.eclipse.birt.data.engine.impl.document.util.ExprDataRead er1.getValueMap(ExprDataReader1.java:277)
> at
> org.eclipse.birt.data.engine.impl.document.util.ExprDataRead er1.getRowValue(ExprDataReader1.java:200)
> at
> org.eclipse.birt.data.engine.impl.document.util.ExprResultSe t.getValue(ExprResultSet.java:141)
> at
> org.eclipse.birt.data.engine.impl.document.ResultIterator.ge tValue(ResultIterator.java:155)
> at
> org.eclipse.birt.report.engine.data.dte.QueryResultSet.getVa lue(QueryResultSet.java:359)
> at
> org.eclipse.birt.report.engine.internal.document.v4.DataItem Executor.doExecute(DataItemExecutor.java:85)
> at
> at
> at
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.tr averse(HTMLAbstractLM.java:402)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.tr averse(HTMLAbstractLM.java:409)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.ha ndleVisibility(HTMLAbstractLM.java:345)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLRowLM.handleV isibility(HTMLRowLM.java:32)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:116)
> ... 63 more
FUDForum. Page generated in 0.03959 seconds
