Home » Modeling » TMF (Xtext) » Problems with imports inside textmodels
Problems with imports inside textmodels [message #50800] Fri, 12 June 2009 14:00 Go to next message
Hi there,
we want to use simple text imports inside text models. Our xtext
definition for that is:
Import : 'import' importedURI=STRING ';';
Umfortunately this doesn't work. If we copy the elements from the imported
file into the base file it works. Here an example:
The grammar:
grammar org.xtext.example.ProblemDSL with
org.eclipse.xtext.common.Terminals
generate problemDSL "http://www.xtext.org/example/ProblemDSL"
Model :
(imports+=Import)*
(exdeus+=Exdeus)*
(refs+=Reference)*;
Import :
Exdeus :
'exdeus' name=ID ';';
Reference :
'ref' name=[Exdeus] ';';
The base model file:
import "MyModel2.psdl";
ref foo;
The imported model file "MyModel2.psdl":
exdeus foo;
The template file is as follows:
«IMPORT problemDSL»;
«DEFINE main FOR Model-»
«FILE "output.txt"»
«EXPAND exdeus FOREACH exdeus»
«EXPAND reference FOREACH refs»
«ENDFILE»
«ENDDEFINE»
«DEFINE exdeus FOR Exdeus»
Exdeus «name»
«ENDDEFINE»
«DEFINE reference FOR Reference»
Reference «name»
«ENDDEFINE»
This in combination throws the following error message:
2101 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]:
classpath:/model/MyModel.pdsl(3): Couldn't resolve reference to Exdeus
foo(Element: -UNKNOWN-; Reported by: MweReader: loading file from
classpath:/model/MyModel.pdsl)
Re: Problems with imports inside textmodels [message #50860 is a reply to message #50800] Fri, 12 June 2009 14:29 Go to previous messageGo to next message
Hi Steffen,
please try something like
Import :
'import' importURI=STRING;
Sebastian
Am 12.06.2009 20:00 Uhr, schrieb Steffen A. Mork:
> Hi there,
> imported file into the base file it works. Here an example:
> The grammar:
> Model :
> (imports+=Import)*
> (exdeus+=Exdeus)*
> (refs+=Reference)*;
> Import :
> Exdeus :
> Reference :
> ref foo;
> exdeus foo;
> «FILE "output.txt"»
> «ENDFILE»
> «ENDDEFINE»
> Exdeus «name»
> «ENDDEFINE»
> Reference «name»
> «ENDDEFINE»
Re: Problems with imports inside textmodels [message #50916 is a reply to message #50800] Sat, 13 June 2009 11:08 Go to previous message
Hi Steffen,
as Sebastian said it's importURI not importedURI.
I've found the missleading occurence in the documentation and have fixed
it. Thanks for the feedback.
Sven
Steffen A. Mork schrieb:
> Hi there,
> The grammar:
> Model :
> (imports+=Import)*
> (exdeus+=Exdeus)*
> (refs+=Reference)*;
> Import :
> Exdeus :
> Reference :
> ref foo;
> exdeus foo;
> «FILE "output.txt"»
> «ENDFILE»
> «ENDDEFINE»
> Exdeus «name»
> «ENDDEFINE»
> Reference «name»
> «ENDDEFINE»
Previous Topic:[XText] An internal error occurred during: "XtextReconcilerJob".
Next Topic:TMF Xtext Getting Started Example
Current Time: Sat Jul 12 08:09:27 EDT 2025
Powered by FUDForum. Page generated in 2.04787 seconds
