Home » Eclipse Projects » GEF » Connection Anchor question in Logic Editor Example
Connection Anchor question in Logic Editor Example [message #50789] Mon, 23 December 2002 12:10 Go to next message
Why I can't connect multiple incoming connections to OrGate, but I can draw
multiple outgoing connections from an OrGate?
Everytime I connect a second connection to the OrGate, the first connection
pointing to the middle of the diagram. I think it is pointing to (100,100),
from a previous positing, that means it can't find a connection positing. My
question is why this happens when I try to connect a second connection? This
should not affect the first connection.
I even try changing the logic example to use ChopBoxConnection Anchor
instead of the FixedConnectionAnchor, same thing happens: one 1 incoming
connection, but multiple outgoing connection.
Thank you for any help.
Re: Connection Anchor question in Logic Editor Example [message #50874 is a reply to message #50789] Mon, 23 December 2002 21:04 Go to previous messageGo to next message
Originally posted by: truenoto.yahoo.com
Look at the code for the LogicSubpart.
For incoming connections, it uses a HashTable.
For outgoing connections, it uses a Vector.
"Hal" <otaconss2@hotmail.com> wrote in message
news:au7fhd$d56$1@rogue.oti.com...
draw
connection
(100,100),
My
This
Re: Connection Anchor question in Logic Editor Example [message #50957 is a reply to message #50789] Tue, 24 December 2002 11:35 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
This is a bug in the Command. It should prevent the operation.
Only one input is valid.
draw
connection
(100,100),
My
This
Re: Connection Anchor question in Logic Editor Example [message #51066 is a reply to message #50957] Tue, 24 December 2002 19:53 Go to previous messageGo to next message
This is a bug in the Command in the logic editor example? or a bug in the
command in the GEF framework?
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:aua20s$gj2$1@rogue.oti.com...
> draw
> connection
> (100,100),
positing.
> My
> This
Re: Connection Anchor question in Logic Editor Example [message #51149 is a reply to message #51066] Thu, 26 December 2002 12:03 Go to previous message
the logic example
"Takumi Fujiwara" <truenoto@yahoo.com> wrote in message
news:auav0m$q2a$1@rogue.oti.com...
> > draw
> > connection
> > (100,100),
> positing.
> > My
connection?
> > This
incoming
Previous Topic:Is this me or is this a bug?
Next Topic:how to refresh the view after a part was added?
Current Time: Thu Sep 25 15:09:22 EDT 2025
Powered by FUDForum. Page generated in 0.08079 seconds
