Home » Eclipse Projects » Plugin Development Environment (PDE) » Scala OSGi plugin template
Scala OSGi plugin template [message #423] Thu, 10 April 2008 10:45
I want to build a plugin template to create OSGi Scala bundles that,
optionally, add an Activator written in Scala (http://www.scala-lang.org/)
Based on a previous Wizard of Neil Bartlett
( http://neilbartlett.name/blog/2007/06/13/eclipse-pde-does-sc ala/) I would
like to do two things:
1) Substitute the RequiredBundle with ImportPackages, and require
pureOSGi plugins (done)
2) Add a template to the wizard for the Scala Activator
I have some problems with this second point:
A) It only have sense to add the Scala Activator if we don't have a Java
Activator. I would like to show my Wizard only if the (Java) Activator
check box is not activated, but the boolean property "requiresActivator"
of wizard extensions doesn't allow to express it in that way. There is any
other way?
B) More important than A: How could I modify the MANIFEST to add the
“BundleActivator” header with the package and class provided by the user?
Miguel
Previous Topic:Problems building my own plugin template
Next Topic:Scala OSGi plugin template
Current Time: Mon Nov 10 00:13:18 EST 2025
Powered by FUDForum. Page generated in 0.02618 seconds
