Home » Eclipse Projects » Eclipse Platform » Currupt workspace.... how to restore projects?
Currupt workspace.... how to restore projects? [message #50776] Tue, 27 May 2003 18:44 Go to next message
Originally posted by: Michael_Scharf.gmx.de
--------------010905010103060103060502
Content-Type: text/plain; charset=us-ascii; format=flowed
This happened to me the third time (each time on a different mashine
with a different workspace). The workspace .metadata is so coprrupt
that eclipse cannot start anymore. I have attached my .log file.
After trying to get it to run again, I figured out, that deleting the file
.metadata\.plugins\org.eclipse.core.resources\.snap
makes eclipse start again.
Unfortunately ALL projects are lost (when I remove the .snap file). I have over
100 projects in that workspace, and I wonder if there is a simple way to restore
them?
It might be that starting eclipse twice on the same workspace might have caused
the problem.
I find it extremely scary, that the workspace relys on some binary files and
that there is no (obvious) way, to restore all directories in the workspace
dicertory as projects....
Michael
name=".log"
Content-Disposition: inline;
filename=".log"
!SESSION Mai 28, 2003 00:27:15.488 ---------------------------------------------
java.version=1.4.2-beta
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86 -data C:\eclipse\workspace -install file:C:/eclipse/2.1/eclipse/
!ENTRY org.eclipse.core.runtime 4 2 Mai 28, 2003 00:27:15.488
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.runtime".
!STACK 0
org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element /test/isource/swig/jisource.i not found.
at org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFo und(AbstractDataTree.java:243)
at org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaD ataTree.java:608)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:54)
at org.eclipse.core.internal.dtree.NoDataDeltaNode.asBackwardDe lta(NoDataDeltaNode.java:56)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:51)
at org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelt a(DeltaDataTree.java:95)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:819)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:818)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:794)
at org.eclipse.core.internal.watson.ElementTree.immutable(Eleme ntTree.java:698)
at org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:511)
at org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1033)
at org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1734)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1537)
at org.eclipse.core.resources.ResourcesPlugin.startup(Resources Plugin.java:268)
at org.eclipse.core.internal.plugins.PluginDescriptor$1.run(Plu ginDescriptor.java:728)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:889)
at org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:740)
at org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
at org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
at org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:185)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:490)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:882)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.acce ss$0(DelegatingURLClassLoader.java:876)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gateLoader.loadClass(DelegatingURLClassLoader.java:90)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassPrerequisites(DelegatingURLClassLoader.java:554)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:890)
at org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:862)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 10)
at java.lang.Class.getConstructor0(Class.java:1922)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
at org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:138)
at org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
at org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
at org.eclipse.core.internal.runtime.InternalPlatform.loaderGet Runnable(InternalPlatform.java:472)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.internal.boot.InternalBootLoader.getRunnabl e(InternalBootLoader.java:471)
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:841)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.core.runtime 4 2 Mai 28, 2003 00:27:15.508
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.Workbench".
!STACK 0
org.eclipse.core.internal.boot.DelegatingLoaderException: org.eclipse.core.runtime.CoreException: Problems encountered starting up plug-in: "org.eclipse.core.resources".
at org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:746)
!STACK 0
!SESSION ------------------------------------------------------------ ----------
!ENTRY org.eclipse.core.launcher 4 0 Mai 28, 2003 24:27:15.518
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
Caused by: java.lang.IllegalArgumentException: Application not found: org.eclipse.ui.workbench.
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:843)
... 7 more
--------------010905010103060103060502--
Re: Currupt workspace.... how to restore projects? [message #56580 is a reply to message #50776] Fri, 30 May 2003 15:29 Go to previous message
Originally posted by: John_Arthorne.oti.com_
Please enter a bug report in bugzilla! Product=Platform,
Component=Core. If you are using something older than release 2.1, this
may be a duplicate of one of the following:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=12575
https://bugs.eclipse.org/bugs/show_bug.cgi?id=30178
Attach the log file to the bug report. However, the most important
piece of information we need is what you were doing immediately prior to
the crash (I assume it crashed, because otherwise there would be no
..snap flie). In particular, were you doing anything in particular with
the reource that it couldn't find: /test/isource/swig/jisource.i.
Has anyone else seen problems like this on release 2.1? If so, please
enter bug reports! We can't fix it if we don't know about it ;)
Michael Scharf wrote:
> have over
> restore
> them?
> caused
> the problem.
> and
> Michael
> !STACK 0
> !STACK 0
> !STACK 0
> !STACK
> ... 7 more
Previous Topic:Can a plugin fragment define a workbench View?
Next Topic:How do I know build is successful?
Current Time: Thu Jul 17 21:29:50 EDT 2025
Powered by FUDForum. Page generated in 0.07670 seconds
