force 'dirty' state? [message #50757] |
Fri, 28 March 2003 21:06  |
Is there a way to manually force a 'dirty' state in a given editor / command stack
instance, i.e., so that the file can be Saved by the user? When I create a bookmark for a
graphical application (the marker is associated with a GEF AbstractEditPart), I need to
maintain the marker ID in the model. However, creating the marker does not cause the
resource to show 'modified' (i.e., w/asterisk). I've tried doing
EditorPart.firePropertyChange( IEditorPart.PROP_DIRTY ) in the editor as well as
firePropertyChange() in the EditPart's model instance. Neither works. Any thoughts
appreciated.
thanks,
Ron
Re: force 'dirty' state? [message #51069 is a reply to message #50757] |
Wed, 02 April 2003 03:10   |
Originally posted by: spambucket.baverman.se
I don't know this API, but to it sounds as if the methods You have been
trying should be
called AFTER the change has already happened and not to make it happen.
When the editor has changed tell everybody that wants to know this by
calling
firePropertyChange(...).
I suggest you look for a method that marks the edited file as dirty, or if
you cannot find that
just try to substitute one character in the file with the same character.
This will effectively not change
the file content, but could make the editor think that it's dirty.
Just my 0.02 worth.
/Bengt B
[Substitute spambucket with bengt if you want to send me an email]
"Ron" <rr.cm@cox.net> wrote in message news:3E84FF94.20606@cox.net...
command stack
a bookmark for a
not cause the
well as
Any thoughts
> appreciated.
> thanks,
> Ron
Re: force 'dirty' state? [message #53114 is a reply to message #50757] |
Thu, 24 April 2003 07:12  |
Originally posted by: sahni_rishi.rediffmail.com
Add
firePropertyChange(PROP_DIRTY);
after you are done with your changes
Rishi
Ron wrote:
stack
bookmark for a
cause the
well as
thoughts
> appreciated.
> thanks,
> Ron
Re: force 'dirty' state? [message #592342 is a reply to message #50757] |
trying should be
calling
Just my 0.02 worth.
/Bengt B
command stack
a bookmark for a
not cause the
well as
Any thoughts
> appreciated.
> thanks,
> Ron
Re: force 'dirty' state? [message #593224 is a reply to message #50757] |
Add
Rishi
Ron wrote:
stack
bookmark for a
cause the
well as
thoughts
> appreciated.
> thanks,
> Ron
FUDForum. Page generated in 0.06251 seconds
