Re: Install conflicts? [message #501531 is a reply to message #501377] |
Wed, 02 December 2009 16:35 |
Did you get this fixed?
Jason
designing woman wrote:
> I had Eclipse (Build id: 20090621-0832) running with ZK. Then
> (unfortunately) I loaded BIRT 2.5. I added a simple report, and that now
> seems to have made any ZUL files unrecognizable to the web server
> Tomcat. The error is a 404 The requested resource
> (/My_Project/event.zul) is not available."
> I created another Test project and that works.
> What did BIRT do? How can it be fixed?
Re: Install conflicts? [message #502842 is a reply to message #501531] |
Wed, 09 December 2009 22:00 |
designing woman Messages: 10 Registered: December 2009 |
Junior Member |
No.
The message is back. I created a new project, and did all the work over. I even made a WAR file.
The I started working on one program to add listboxes. Now when I try running ANY file in the project, the message
The requested resource {resource-name} is not available.
I think this is either a bug in Eclipse or ZK. Something is corrupting a key file.
Note: I can execute .zul files from another project just fine.
Ideas?
[Updated on: Wed, 09 December 2009 22:02] Report message to a moderator
Re: Install conflicts? [message #502851 is a reply to message #502842] |
Wed, 09 December 2009 22:49 |
Can you open a bugzilla entry? This may not be a BIRT bug, but it will
be good to get it logged.
> No.
> The I started working on one program to add listboxes. When I try
> key file.
> Ideas?
Re: Install conflicts? [message #502855 is a reply to message #502852] |
Wed, 09 December 2009 23:44 |
I should of been clearer. If you log it the devs may be able to help
diagnose the issue. What download did you use for ZK install? I will
try to reproduce the issues.
Jason
> I need to get it fixed not logged.
> I'd like someone else to confirm this happens. It happened twice to me.
> I am sure it has happened to others. I'd like to hear how they resolved it.
FUDForum. Page generated in 0.03718 seconds
