AspectJ nature breaks JUnit plug-in [message #50750] |
Thu, 21 April 2005 11:58  |
Originally posted by: jeff.kunkle.nearinfinity.com
Adding the AspectJ nature to my projects breaks the integrated JUnit
plug-in. Any time I attempt to run a JUnit test I'm greeted with a red
text console error such as "Class not found
com.nearinfinity.authorization.ConnectionHandlerTest". Remove the AspectJ
nature and the JUnit plug-in happily runs the tests. Add the nature back
in and it breaks once again. Has anyone else experienced this problem and
found a fix or workaround?
Re: AspectJ nature breaks JUnit plug-in [message #50832 is a reply to message #50750] |
Fri, 22 April 2005 09:05  |
Hi Jeff,
We run JUnit tests ourselves in AspectJ projects without problems. I can't
see anything in bugzilla for this, perhaps you could raise it there?
Please include your AJDT and Eclipse versions, and as much detail about
your project as possible.
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: AspectJ nature breaks JUnit plug-in [message #587803 is a reply to message #50750] |
Hi Jeff,
Matt.
Matt Chapman
FUDForum. Page generated in 0.06781 seconds
