Home » Newcomers » Newcomers » can't start eclipse (JVM terminated exit code=2)
can't start eclipse (JVM terminated exit code=2) [message #4453] Tue, 18 January 2005 06:24 Go to next message
Originally posted by: dd.nospamplease.com
Every time I try and start Eclipse I just get the dialog box
come up with JVM terminated Exit code=2. I notice it's
using javaw.exe from windows\system32 instead of from
program files\java (which is my 1.4.2 Sun java installation).
I'm confused as to why Java is launched, after all, I'm only
starting the IDE.
~dd
Re: can't start eclipse (JVM terminated exit code=2) [message #4594 is a reply to message #4453] Tue, 18 January 2005 09:47 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
The eclipse IDE is a java program (eclipse is written in Java).
The launcher is a small native program that runs a JVM with the eclipse
application.
You probably have a rougue environment variable pointing to a non-existent
JAVA HOME.
You can influence what VM to use by creating a shortcut to the launcher
(eclipse.exe)
and pass the argument "-vm [path-to-jre]/jre/bin/javaw.exe"
More explanation is given in
http://www.eclipsefaq.org/chris/faq/html/faq25.html
Chris Laffra, http://eclipsefaq.org
"d d" <dd@nospamplease.com> wrote in message
news:csirl0$1os$1@www.eclipse.org...
> starting the IDE.
> ~dd
Re: can't start eclipse (JVM terminated exit code=2) [message #4866 is a reply to message #4594] Tue, 18 January 2005 10:10 Go to previous message
Doh!! I assumed having the path to my sun JVM at the front of
the path env. var would be sufficient. I'd seen that FAQ but didn't
think it was an issue as I didn't see how it could find Microsoft's
JVM before the Sun one.
Well naturally that did the trick. Thanks Chris.
~dd
"Chris Laffra" <Chris_Laffra@ca.ibm.com> wrote in message
news:csj7in$k3j$1@www.eclipse.org...
> application.
> JAVA HOME.
> (eclipse.exe)
>> starting the IDE.
>> ~dd
Previous Topic:Installation of Eclipse on Windows XP
Next Topic:What file to download? GNU/Linux
Current Time: Mon Jul 21 21:33:26 EDT 2025
Powered by FUDForum. Page generated in 0.06257 seconds
