Re: Runing examples on tomcat6.018 [message #500988 is a reply to message #500901] |
Mon, 30 November 2009 15:31 |
Maxel,
Are you running tomcat as a service? Does it have write permission to
the WEB-INF/platform directory? Also verify that you do not have a
version of tidy.jar in the application servers classpath.
Jason
maxel wrote:
> Hi, I am new to birt and try to run the examples on a opensuse-11.1
> Tomcat 6.018.
> It works (local or remote) fine until the start of the example
> " http://server:8080/birt-viewer/frameset?__report=test.rptdes ign&sample=my+parameter"
> the catalina log says:
> 30.11.2009 09:42:46 org.eclipse.birt.report.engine.api.impl.RenderTask
> render
> SCHWERWIEGEND: Error happened while running the report.
> java.lang.NoClassDefFoundError: org/w3c/tidy/Tidy
> at
> org.eclipse.birt.report.engine.parser.HTMLTextParser.<init>(HTMLTextParser.java:55)
> at org.eclipse.birt.report.engine.parser.TextParser.parse(TextP
> arser.java:110)
> at org.eclipse.birt.report.engine.emitter.html.HTMLReportEmitte
> r.outputHtmlText(HTMLReportEmitter.java:2564)
> r.startForeign(HTMLReportEmitter.java:2541)
> at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.st
> artContent(ContentEmitterUtil.java:77)
> at org.eclipse.birt.report.engine.layout.html.buffer.DummyPageB
> uffer.startContent(DummyPageBuffer.java:125)
> at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.st
> art(HTMLLeafItemLM.java:67)
> at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la
> yout(HTMLAbstractLM.java:136)
> at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking
> LM.layoutNodes(HTMLBlockStackingLM.java:70)
> at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout
> (HTMLPageLM.java:90)
> at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE
> ngine.layout(HTMLReportLayoutEngine.java:99)
> at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRange
> Render.render(RenderTask.java:600)
> at org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re
> nderTask.java:221)
> at org.eclipse.birt.report.service.ReportEngineService.renderRe
> port(ReportEngineService.java:1461)
> at org.eclipse.birt.report.service.BirtViewerReportService.getP
> age(BirtViewerReportService.java:204)
> at org.eclipse.birt.report.service.actionhandler.AbstractGetPag
> eActionHandler.doExecution(AbstractGetPageActionHandler.java :238)
> eActionHandler.__execute(AbstractGetPageActionHandler.java:1 05)
> at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc
> tionHandler.execute(AbstractBaseActionHandler.java:90)
> at org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc
> umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
> at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom
> ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
> at org.eclipse.birt.report.soapengine.processor.BirtDocumentPro
> cessor.handleGetPage(BirtDocumentProcessor.java:87)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce
> ssorImpl.java:57)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe
> thodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:616)
> ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
> at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI
> mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
> ssorImpl.java:57)
> at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP
> rovider.java:397)
> at org.apache.axis.providers.java.RPCProvider.processMessage(RP
> CProvider.java:186)
> at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi
> der.java:323)
> at org.apache.axis.strategies.InvocationStrategy.visit(Invocati
> onStrategy.java:32)
> at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
> at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
> at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService
> .java:454)
> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
> at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle
> t.java:699)
> at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer
> vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
> at org.apache.axis.transport.http.AxisServletBase.service(AxisS
> ervletBase.java:327)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
> vlet.service(BirtSoapMessageDispatcherServlet.java:122)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFi
> lter(ApplicationFilterChain.java:290)
> at org.apache.catalina.core.ApplicationFilterChain.doFilter(App
> licationFilterChain.java:206)
> at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF
> ilter.java:68)
> lter(ApplicationFilterChain.java:235)
> at org.apache.catalina.core.StandardWrapperValve.invoke(Standar
> dWrapperValve.java:233)
> at org.apache.catalina.core.StandardContextValve.invoke(Standar
> dContextValve.java:191)
> at org.apache.catalina.core.StandardHostValve.invoke(StandardHo
> stValve.java:128)
> at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo
> rtValve.java:102)
> at org.apache.catalina.core.StandardEngineValve.invoke(Standard
> EngineValve.java:109)
> at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd
> apter.java:286)
> at org.apache.coyote.http11.Http11Processor.process(Http11Proce
> ssor.java:845)
> at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand
> ler.process(Http11Protocol.java:583)
> at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin
> t.java:447)
> at java.lang.Thread.run(Thread.java:636)
> Are there ideas to resolve the problem. (I'm a c++ programmer with less
> experience in java)
FUDForum. Page generated in 0.03851 seconds
