String sorting and Locale problem [message #500664] |
Fri, 27 November 2009 11:42 |
Originally posted by: bdraba.gmail.com
What I need to set to have properly (in locale different than English)
sorted column of strings data in the table?
Thanks!
Bartek
Re: String sorting and Locale problem [message #500949 is a reply to message #500664] |
Mon, 30 November 2009 12:14 |
Hi again,
Maybe I wasn't clear enough. I want to sort column of strings in my table
and BIRT sorts it in natural order in English alphabet
but I need to do this in other language (alphabet).
The question is what and where set my Locale (or other properties) to make
BIRT sorting in my Language.
Thanks a lot,
Bartek
> Hello,
> Thanks!
> Bartek
Re: String sorting and Locale problem [message #500984 is a reply to message #500949] |
Mon, 30 November 2009 15:16 |
Are you adding &__locale=yourlocale to the report url?
Two other things you can do:
1 - Build a custom sort order by entering an expression for the key.
For example assume I sort on orderlinenumber and I want to sort it like
3
1
2
4
I could enter this expression:
var ol = row["ORDERLINENUMBER"];
if( ol == 3 ){
1
}else if( ol == 1 ){
2
}else if( ol == 2 ){
3
}else if( ol == 4 ){
4
2 - Try adding the sort key in the beforeFactory script of the report.
importPackage(Packages.org.eclipse.birt.report.model.api);
importPackage(Packages.org.eclipse.birt.report.model.api.ele ments);
importPackage(Packages.com.ibm.icu.util);
var lc = new ULocale("fr_FR");
delm = reportContext.getDesignHandle().findElement("mytable");
sc = StructureFactory.createSortKey();
sc.setKey("row[\"ORDERNUMBER\"]");
sc.setDirection("desc");
sc.setLocale(lc);
ph = delm.getPropertyHandle(TableHandle.SORT_PROP);
ph.addItem(sc);
notice the ULocale object. The sort key has a setLocale method. I have
not tried this but its worth a try.
Jason
drabek wrote:
> Hi again,
> Thanks a lot,
> Bartek
>> Hello,
>> Thanks!
>> Bartek
Re: String sorting and Locale problem [message #502435 is a reply to message #500984] |
Tue, 08 December 2009 08:58 |
Originally posted by: maciej.dot.kruk.alan-systems.dot.com
hi,
no way:
> sc.setLocale(lc);
> ph.addItem(sc);
No, org.eclipse.birt.report.model.api.elements.structures.SortKe y does not
have the setLocale method.
Actually, BIRT is able only to sort the data binary or not. Don't think of
use java.text.Collator strengths or any kind of it!
The lack of this feature disqualifies BIRT to use in multilingual
applications, doesn't it?
Maciek
Re: String sorting and Locale problem [message #502562 is a reply to message #502435] |
Tue, 08 December 2009 20:02 |
Maciek,
What version of BIRT are you using?
2.5.1
org.eclipse.birt.report.model.api.elements.structures.SortKe y does have
a setLocale method, which the SortKeyHandle uses. There is also a
setStrength method. The data engine uses com.ibm.icu.text.Collator. If
this is not functioning right a bug will need to be logged.
Can you try this:
importPackage(Packages.org.eclipse.birt.data.engine.api);
sc.setLocale(lc);
//ASCII_SORT_STRENGTH or DEFAULT_SORT_STRENGTH for Collator
sc.setStrength( ISortDefinition.DEFAULT_SORT_STRENGTH );
ph.addItem(sc);
Jason
Maciej Kruk wrote:
> hi,
> no way:
>> sc.setLocale(lc);
>> ph.addItem(sc);
> Maciek
FUDForum. Page generated in 0.03994 seconds
