Home » Modeling » Epsilon » (Beginner) Ant/Epsilon: Exception with EGL
(Beginner) Ant/Epsilon: Exception with EGL [message #4431] |
Fri, 21 November 2008 06:40  |
Further to my last post, which concerned running ETL via ANT, I have
another quick question when using EGL.
I have a simple .launch file that successfully triggers EGL and generates
some output. However, when I try to replicate the task using ANT, I get an
exception. The ANT contains the following:
<target name="main">
<epsilon.egl src="PrintExample.egl">
<model ref="APreviouslyLoadedModel"/>
</epsilon.egl>
</target>
And the exception I get is:
[simple.egl] EXCEPTION: java.lang.NoClassDefFoundError:
org/eclipse/epsilon/egl/EglModuleImpl
[simple.egl] at
org.eclipse.epsilon.workflow.tasks.EglTask.createModule(EglT ask.java:25)
[simple.egl] at
org.eclipse.epsilon.workflow.tasks.ExecutableModuleTask.exec uteImpl(ExecutableModuleTask.java:75)
I'm probably making another basic error, but I couldn't find the source of
the problem elsewhere, so thought I'd try here again.
Best,
Edd
Re: (Beginner) Ant/Epsilon: Exception with EGL [message #4642 is a reply to message #4572] |
Fri, 21 November 2008 07:11   |
Hi Edd,
Looking at the stack trace it seems that it can't find the class
EglModuleImpl (which hasn't been around for a while). May I ask how you
have installed Epsilon (update site, plugins or via SVN)?.
Dimitrios
Louis Rose wrote:
> Hi Edd,
> Edd wrote:
>> generates some output. However, when I try to replicate the task using
>> ANT, I get an exception. The ANT contains the following:
>> </epsilon.egl> </target>
> Your Ant script looks fine.
>> [simple.egl] at
>> [simple.egl] at
> It looks like the Ant runtime can't locate the EGL plugin.
> Are you running the Ant script from the same workspace that you used to
> successfully execute the EGL transformation using the development tools?
> Could you export a copy of your project and post it here for us to explore?
> Cheers,
> Louis.
Re: (Beginner) Ant/Epsilon: Exception with EGL [message #562183 is a reply to message #4431] |
Fri, 21 November 2008 07:01  |
Hi Edd,
Edd wrote:
> [simple.egl] at
> [simple.egl] at
Louis.
Re: (Beginner) Ant/Epsilon: Exception with EGL [message #562208 is a reply to message #4572] |
Hi Edd,
Dimitrios
Louis Rose wrote:
> Hi Edd,
> Edd wrote:
>> [simple.egl] at
>> [simple.egl] at
> Cheers,
> Louis.
Re: (Beginner) Ant/Epsilon: Exception with EGL [message #562230 is a reply to message #4642] |
Fri, 21 November 2008 07:55  |
Hi Dimitrios,
Yes, I noticed that I couldn't find EglModuleImpl in the Epsilon jars...
I installed it at the MODELS conference, end of September / beginning of
October, this year. The version that I have is 0.8.1.1, and it was
installed via the update site as described in the installation
instructions.
Ta,
Edd
Dimitrios Kolovos wrote:
Re: (Beginner) Ant/Epsilon: Exception with EGL [message #562252 is a reply to message #4711] |
Fri, 21 November 2008 08:08  |
Hi Edd,
Could you please update to the latest 0.8.2.1? This should fix this problem.
Dimitrios
Edd wrote:
> Hi Dimitrios,
> instructions.
> Ta,
> Edd
Current Time: Wed Jul 30 08:50:39 EDT 2025
Powered by FUDForum. Page generated in 0.11812 seconds
