Loading Images in plug-in [message #50636] |
Mon, 11 April 2005 11:19 |
Originally posted by: flamereaver.yahoo.co.in
Hi all,
I'm writing a plug-in, and when I use the setImage function on a Shell
object, with a relative path like
objShell.setImage(objDisplay,"icons/pic1.gif");
I get a java.io.FileNotFoundException (due to the relative path). It works
properly for absolute paths.
How do I write a function in my plug-in that "accepts just the relative
path of the image and returns an Image object to it". The function should
be like...
import org.eclipse.swt.graphics.Image;
public static Image getImageFunction(Display display, String filename){
* return Image, on no error;
* null, otherwise
Thanks in advance,
Siv
P.S. For what is is worth!
1. All source files are inside a single package inside the 'src' directory
2. The icon files are not. They are in an 'icons' directory, at the same
level as the 'src' directory.
FUDForum. Page generated in 0.07581 seconds
