Home » Modeling » TMF (Xtext) » [Xtext] Code Formatting via menu, but "Source" menu is not present
[Xtext] Code Formatting via menu, but "Source" menu is not present [message #50627] Fri, 12 June 2009 05:30 Go to next message
I'm using the personalizable formatting feature and can format my textual
model via CTRL-SHIFT-F.
Unfortunately the formatting is not reachable via the menu entry
Source->Format because the whole Source menu gets invisible when I go into
the text view.
Is this true or do I make a mistake here? If it is true, whe can I expect
that this menu entry gets visible?
Ciao, Michael
Re: [Xtext] Code Formatting via menu, but "Source" menu is not present [message #51296 is a reply to message #50627] Sun, 14 June 2009 15:39 Go to previous message
Originally posted by: peter.friese.itemis.com
Michael,
there is no "Format" menu item yet, as we do not yet have a "Source" menu.
Would you be interested in having a context menu entry, a main menu
entry (in the yet to be created "Source" menu), or both?
If you are interested in having a source menu, please open a bug. As
always, a patch is very welcome!
I created a patch (see bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=280200 ) to add the
"Toggle Comment" command to the editor context menu, this might serve
as an inspiration for a patch.
Peter
On 2009-06-12 11:30:36 +0200, "Michael Mühlberg"
<michael.muehlberg@sap.com> said:
> Hello,
> the text view.
> Ciao, Michael
Previous Topic:Errors in Xtext Grammar File
Next Topic:Uniqueness Check
Current Time: Sat Jul 19 03:23:25 EDT 2025
Powered by FUDForum. Page generated in 0.06687 seconds
