Home » Eclipse Projects » GEF » draw2d.text
draw2d.text [message #50621] Sun, 22 December 2002 07:32 Go to next message
I was trying to create custom text editor using draw2d.text but
unfortunately found no place where I can use custom rendering for text
editor. I understand that this is more general Eclipse question, but I
believe that draw2d.text was supposed to use for text editors too (I meant
not only for displaying text). So, the question is - how? ;)
Re: draw2d.text [message #50651 is a reply to message #50621] Sun, 22 December 2002 13:15 Go to previous message
For now, the purpose is to render text only. If you want to edit, you must
implement editing behavior. WSAD uses GEF to edit the text, but depending on
what you are trying to do there may be a more direct approach.
"Kirill Paliy" <kpaliy@aaanet.ru> wrote in message
news:au4au0$33s$1@rogue.oti.com...
Previous Topic:[CHANGE] Delete has been changed
Next Topic:[jdt-ui-dev] Pre-reqs are not exported
Current Time: Sun May 11 16:12:13 EDT 2025
Powered by FUDForum. Page generated in 0.02335 seconds
