Home » Archived » XML Schema Definition (XSD) » How to find "root" element in a schema. Check if an element is referenced
How to find "root" element in a schema. Check if an element is referenced [message #50579] Wed, 18 August 2004 18:41 Go to next message
Originally posted by: gj.puredge.com
I have a schema loaded into an XSDSchema model which consists of a lot of
element definitions of which only one is the root element for my document.
In this case all the elements are defined "globally" (sorry if that's the
incorrect term) and then referenced in other element definitions. For
example: <xs:element ref="title" /> where "title" is declared elsewhere.
I understand that there need not be a concept of a root element since schema
simply defines elements that can be present in a document. In this
particular case the schema defines a single document and there really is a
root element. The "root" element should be the only one which is not
referred to by anything else. Does this sound resonable?
I process the schema by fetching all the Element Declarations:
EList elements = schema.getSchema().getElementDeclarations()
and processing each one.
for (Iterator iter = elements.iterator(); iter.hasNext(); )
XSDElementDeclaration element = (XSDElementDeclaration)iter.next();
// Check if this is the root element
boolean flag = isReferenced(element, schema);
Assuming that this is the correct approach how can I easily find out if a
given element is referenced by another element in the schema? In other
words I need an isReferenced() method.
Does anyone have any ideas or am I so far off track it isn't funny?
Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #50637 is a reply to message #50579] Thu, 19 August 2004 06:26 Go to previous messageGo to next message
Gary,
This sounds reasonable. You can use
org.eclipse.xsd.util.XSDUtil.UsageCrossReferencer to find all
references. Note that getElementDeclarations returns all element
declarations, including imported ones.
Gary J wrote:
>Hi,
>Thanks
>Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #50694 is a reply to message #50637] Thu, 19 August 2004 14:00 Go to previous messageGo to next message
Thanks Ed,
I tried it on a simple schema and got back a collection in both cases where
the element was referenced and where it was not.
Here's what I did:
EList elements = schema.getSchema().getElementDeclarations();
for (Iterator iter = elements.iterator(); iter.hasNext();)
// Test if element referenced
ArrayList list = (ArrayList)UsageCrossReferencer.find(element, elements);
The schema looks like this: (its the standard po example - file7)
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:complexType name="PurchaseOrderType">
<xsd:element minOccurs="0" ref="comment"></xsd:element>
</xsd:complexType>
<xsd:element name="purchaseOrder" type="PurchaseOrderType"></xsd:element>
<xsd:element name="comment" type="xsd:string"></xsd:element>
</xsd:schema>
I get back two elements and check each one for referenced. Sorry if I'm
totally stupid. How do I determine that the element comment is referenced
by the element purchaseOrder? I've looked everywhere in 'list' in debug but
can not find anything.
Re: How to find "root" element in a schema. Check if an element is referenced [message #50722 is a reply to message #50694] Thu, 19 August 2004 15:09 Go to previous messageGo to next message
How do I determine that the element comment is referenced by the element
purchaseOrder? look at the schema.
1. the element with name="purchaseOrder" is of type="PurchaseOrderType"
2. xsd:complexType name="PurchaseOrderType" contains an element with
ref="comment", a reference to the element comment.
norwood sisson
Gary J wrote:
> Thanks Ed,
> Here's what I did:
> </xsd:complexType>
> </xsd:schema>
> Thanks
Re: How to find "root" element in a schema. Check if an element is referenced [message #50777 is a reply to message #50637] Thu, 19 August 2004 15:12 Go to previous messageGo to next message
I think I answered part of my own question. I was only checking Element
declarations, not types. I'm now checking both and get back a larger list
for "comments".
Is there any documentation about what I should be seeing in these lists?
Here's my code:
EList types = schema.getSchema().getTypeDefinitions();
System.out.println(" Element: " + element.getName());
ArrayList elist = (ArrayList)UsageCrossReferencer.find(element,
elements);
// list contents of element references
for (Iterator i = elist.iterator(); i.hasNext();)
Object obj = i.next();
System.out.println(" Element ref: " + obj.getClass());
ArrayList tlist = (ArrayList)UsageCrossReferencer.find(element, types);
// list contents of type references
for (Iterator i = tlist.iterator(); i.hasNext();)
System.out.println(" Type ref: " + obj.getClass());
Here's what I get:
For the "comment" element I get:
Element: comment
Element ref: class org.eclipse.emf.ecore.impl.BasicEObjectImpl$2
Element ref: class org.eclipse.emf.ecore.util.EObjectEList
Type ref: class org.eclipse.emf.ecore.impl.BasicEObjectImpl$2
For the "purchaseOrder" element I get:
Element: purchaseOrder
How do I decode all this?
Gary
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cg1v5q$fu2$1@eclipse.org...
> Gary,
> Gary J wrote:
> >Hi,
document.
elsewhere.
schema
a
> >Thanks
> >Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #50826 is a reply to message #50722] Thu, 19 August 2004 15:18 Go to previous messageGo to next message
Thanks, you are correct that it is all in the schema but I was talking about
the XML Infoset Model, not the .xsd text file.
In the Infoset model the schema is expressed in a model of java objects
which the user can query. How to perform the traversing and interpret the
results was my question.
<user@domain.invalid> wrote in message news:cg2tma$7fn$1@eclipse.org...
> norwood sisson
> norwood sisson
> Gary J wrote:
> > Thanks Ed,
where
> > Here's what I did:
elements);
> > <?xml version="1.0" encoding="UTF-8"?>
> > </xsd:complexType>
> > </xsd:schema>
referenced
but
> > Thanks
Re: How to find "root" element in a schema. Check if an element is referenced [message #50854 is a reply to message #50777] Thu, 19 August 2004 15:55 Go to previous messageGo to next message
--------------090206070101090509000002
Content-Type: text/plain; charset=us-ascii; format=flowed
Gary,
You should be doing the find against the whole resource set, the whole
resource, or the whole schema, not just against the list of elements or
the list of types. The objects in the list are of type
org.eclipse.emf.ecore.EStructuralFeature.Setting from which you can
determine the object doing the referencing as well as the feature of the
object that holds the reference. Only the base class in EMF
(EcoreUtil.UsageCrossReferencer) has javadoc...
>for "comments".
>Here's my code:
>elements);
>Here's what I get:
>Element: comment
>Thanks
>Gary
>>Gary,
>>Gary J wrote:
>>>Hi,
>document.
>elsewhere.
>schema
>a
>>>Thanks
>>>Gary
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
the list of types.&nbsp; The objects in the list are of type
the object that holds the reference.&nbsp; Only the base class in EMF
(EcoreUtil.UsageCrossReferencer) has javadoc...<br>
<br>
<br>
Gary J wrote:<br>
<blockquote cite="midcg2tt0$7ps$1@eclipse.org" type="cite">
<pre wrap="">I think I answered part of my own question. I was only checking Element
for "comments".
Here's my code:
elements);
Here's what I get:
Element: comment
Gary
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:cg1v5q$fu2$1@eclipse.org">news:cg1v5q$fu2$1@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Gary,
Gary J wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->document.
</pre>
<pre wrap="">In this case all the elements are defined "globally" (sorry if that's the
example: &lt;xs:element ref="title" /&gt; where "title" is declared
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->elsewhere.
</pre>
<pre wrap="">I understand that there need not be a concept of a root element since
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->schema
</pre>
<pre wrap="">simply defines elements that can be present in a document. In this
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->a
</pre>
<pre wrap="">root element. The "root" element should be the only one which is not
Gary
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------090206070101090509000002--
Re: How to find "root" element in a schema. Check if an element is referenced [message #50881 is a reply to message #50854] Thu, 19 August 2004 17:30 Go to previous messageGo to next message
Thanks Ed,
Once I used the schema to compare against all seems to work. For anyone
else who's interested, here's what I did. Is this a reasonable approach?
XSDElementDeclaration element = (XSDElementDeclaration) iter.next();
if (!isReferenced(element, schema))
System.out.println(" Element: <" + element.getName() + "> is a root
element.");
boolean isReferenced(XSDElementDeclaration element, XSDSchema schema)
int count = 0;
// Determine how many references there are to this element
ArrayList list = (ArrayList) UsageCrossReferencer.find(element, schema);
for (Iterator i = list.iterator(); i.hasNext();)
Setting setting = (Setting) i.next();
EObject obj = setting.getEObject();
if (obj != schema && obj != element)
count++;
return count > 0 ? false : true;
Note I think this also counts references in types that might not themselves
be referenced by elements. A more exact method might be to check for
element references when obj (above) is a particle. Does that sound right?
Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #50910 is a reply to message #50881] Thu, 19 August 2004 17:40 Go to previous messageGo to next message
minor correction.
shoud be
return count > 0 ? true : false;
"Gary J" <gj@puredge.com> wrote in message news:cg360c$k1f$1@eclipse.org...
> Thanks Ed,
> element.");
> int count = 0;
> count++;
themselves
> Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #50937 is a reply to message #50881] Thu, 19 August 2004 17:45 Go to previous messageGo to next message
Gary,
Yes this looks reasonable. I think you are right that an element must
be referenced from a particle in order to be in a content model of
something. The two cases you filtered out (I think) are for the schema
referencing the element in the getElementDeclarations, and the element
referencing itself in the getResolvedElementDeclaration. Note that an
element may reference another element with
getSubstitutionGroupAffiliation. Looking at the feature of the Setting
will help tell you how the object is referencing the element. Note that
something like XSDPackage.eINSTANCE.getXSDParticle_Term() will give you
access to the feature for comparing against the feature you see in the
Setting.
Gary J wrote:
>Thanks Ed,
>element.");
> int count = 0;
> count++;
>Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #50964 is a reply to message #50910] Thu, 19 August 2004 17:47 Go to previous messageGo to next message
--------------020506080505040006010506
Gary,
This would be slightly more simple. ;-)
return count > 0;
Gary J wrote:
>minor correction.
>shoud be
>>Thanks Ed,
>>element.");
>> int count = 0;
>> count++;
>themselves
>>Gary
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
This would be slightly more simple. ;-)<br>
<br>
<blockquote>&nbsp; return count &gt; 0;<br>
</blockquote>
<br>
Gary J wrote:<br>
<blockquote cite="midcg36j6$kqa$1@eclipse.org" type="cite">
<pre wrap="">minor correction.
return count &gt; 0 ? false : true;
shoud be
return count &gt; 0 ? true : false;
"Gary J" <a class="moz-txt-link-rfc2396E" href="mailto:gj@puredge.com">&lt;gj@puredge.com&gt;</a> wrote in message <a class="moz-txt-link-freetext" href="news:cg360c$k1f$1@eclipse.org">news:cg360c$k1f$1@eclipse.org</a>...
</pre>
<pre wrap="">Thanks Ed,
System.out.println(" Element: &lt;" + element.getName() + "&gt; is a root
element.");
int count = 0;
if (obj != schema &amp;&amp; obj != element)
count++;
</pre>
</blockquote>
<pre wrap=""><!---->themselves
</pre>
<pre wrap="">be referenced by elements. A more exact method might be to check for
Gary
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------020506080505040006010506--
Re: How to find "root" element in a schema. Check if an element is referenced [message #50992 is a reply to message #50937] Thu, 19 August 2004 18:59 Go to previous messageGo to next message
I have one more problem which is more related to performance. I have a
large schema with 15000+ lines of element declarations. When I search for
the root elements it takes an extremely long time.
I have looked at the code for XSDUtil.UsageCrossReferencer.find() and it
seems that a new UsageCrossReferencer(schema) Collection is created for
every find().
Is there a way to speed this up by building the UsageCrossReferencer once
and re-using it for subsequent find()'s ?
UsageCrossReferencer is protected so I can not create an instance of it like
this:
UsageCrossReferencer xref = new UsageCrossReferencer(schema);
Should I subclass UsageCrossReferencer to solve this problem or is there a
better way?
Gary
news:cg36uk$l8k$1@eclipse.org...
> Gary,
> Setting.
> Gary J wrote:
> >Thanks Ed,
> >element.");
> > int count = 0;
schema);
> > count++;
> > return count > 0;
themselves
right?
> >Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #51020 is a reply to message #50992] Thu, 19 August 2004 20:28 Go to previous messageGo to next message
--------------030706010606050706060802
Gary,
You should probably use findAll(xsdSchema.getElementDeclarations(),
xsdSchema) to find the usages of all the elements at once. The result
is a map from element to a Collection of Settings, i.e., the Collection
for a find of a single element. This way the whole schema is only
walked once.
>every find().
>this:
>better way?
>Thanks
>Gary
>>Gary,
>>Setting.
>>Gary J wrote:
>>>Thanks Ed,
>>>element.");
>>> int count = 0;
>schema);
>>> count++;
>>> return count > 0;
>themselves
>right?
>>>Gary
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
You should&nbsp; probably use findAll(xsdSchema.getElementDeclarations(),
xsdSchema) to find the usages of all the elements at once.&nbsp; The result
for a find of a single element.&nbsp; This way the whole schema is only
walked once.<br>
<br>
<br>
Gary J wrote:<br>
<blockquote cite="midcg3b7e$pt3$1@eclipse.org" type="cite">
<pre wrap="">I have one more problem which is more related to performance. I have a
every find().
this:
better way?
Gary
<a class="moz-txt-link-freetext" href="news:cg36uk$l8k$1@eclipse.org">news:cg36uk$l8k$1@eclipse.org</a>...
</pre>
<pre wrap="">Gary,
Setting.
Gary J wrote:
</pre>
element.");
int count = 0;
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->schema);
</pre>
<pre wrap=""> for (Iterator i = list.iterator(); i.hasNext();)
count++;
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->right?
</pre>
<pre wrap="">Gary
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------030706010606050706060802--
Re: How to find "root" element in a schema. Check if an element is referenced [message #51347 is a reply to message #51020] Tue, 24 August 2004 06:19 Go to previous messageGo to next message
Originally posted by: gnoutsa.hotmail.com
I Ed ,
>Ed Merks wrote:
> Gary,
I don' t really understand what this map contain .
is that something like this : map("elementDeclarations","ArrayList")
please correct me if i' am wrong :
- the Key are all the Element "ElementDeclarations" retrieve
"directly"
from the Schema : sxdSchema.getElementDeclarations().
- the value is an "ArrayList" : what is the contain of this
"ArrayList" ?
is it possible that the map something else than ArrayList
> walked once.
> >every find().
> >this:
> >better way?
> >Thanks
> >Gary
> >>Gary,
> >>Setting.
> >>Gary J wrote:
> >>>Thanks Ed,
> >>>element.");
> >>> int count = 0;
> >schema);
> >>> count++;
> >>> return count > 0;
> >themselves
> >right?
> >>>Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #51403 is a reply to message #51347] Tue, 24 August 2004 07:35 Go to previous message
--------------080706020903080502040700
Bertrand,
In general, it is a map from Map<EObject,
Collection<EStructuralFeature.Setting>>, so the items in the list are of
type EStructuralFeature.Setting.
Bertrand N. wrote:
>I Ed ,
>>Ed Merks wrote:
>>Gary,
>"directly"
>"ArrayList" ?
>>walked once.
>>>every find().
>>>this:
>>>better way?
>>>Thanks
>>>Gary
>>>>Gary,
>>>>Setting.
>>>>Gary J wrote:
>>>>>Thanks Ed,
>>>>>element.");
>>>>>int count = 0;
>>>schema);
>>>>> count++;
>>>>>return count > 0;
>>>themselves
>>>right?
>>>>>Gary
<html>
<head>
<title></title>
</head>
Bertrand,<br>
<br>
In general, it is a map from Map&lt;EObject,
Collection&lt;EStructuralFeature.Setting&gt;&gt; , so the items in the
list are of type EStructuralFeature.Setting.<br>
<br>
<br>
Bertrand N. wrote:
<blockquote cite="midcgf4na$m9e$1@eclipse.org" type="cite">
<pre wrap="">I Ed ,
</pre>
<pre wrap="">Ed Merks wrote:
</pre>
</blockquote>
</pre>
<pre wrap="">Gary,
</pre>
</blockquote>
</pre>
<pre wrap="">You should probably use findAll(xsdSchema.getElementDeclarations(),
</pre>
</blockquote>
"directly"
"ArrayList" ?
</pre>
<pre wrap="">This way the whole schema is only
walked once.
</pre>
</blockquote>
</pre>
<pre wrap="">Gary J wrote:
</pre>
</blockquote>
</pre>
every find().
this:
better way?
Gary
</pre>
<pre wrap="">Gary,
Setting.
Gary J wrote:
</pre>
element.");
int count = 0;
</pre>
</blockquote>
</blockquote>
<pre wrap="">schema);
</pre>
<pre wrap="">for (Iterator i = list.iterator(); i.hasNext();)
count++;
</pre>
</blockquote>
</blockquote>
<pre wrap="">themselves
</pre>
</pre>
</blockquote>
</blockquote>
<pre wrap="">right?
</pre>
<pre wrap="">Gary
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------080706020903080502040700--
Re: How to find "root" element in a schema. Check if an element is referenced [message #590383 is a reply to message #50579] Thu, 19 August 2004 06:26 Go to previous message
Gary,
Gary J wrote:
>Hi,
>Thanks
>Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #590417 is a reply to message #50637] Thu, 19 August 2004 14:00 Go to previous message
Thanks Ed,
Here's what I did:
</xsd:complexType>
</xsd:schema>
Re: How to find "root" element in a schema. Check if an element is referenced [message #590428 is a reply to message #50694] Thu, 19 August 2004 15:09 Go to previous message
norwood sisson
Gary J wrote:
> Thanks Ed,
> Here's what I did:
> </xsd:complexType>
> </xsd:schema>
> Thanks
Re: How to find "root" element in a schema. Check if an element is referenced [message #590457 is a reply to message #50637] Thu, 19 August 2004 15:12 Go to previous message
for "comments".
Here's my code:
elements);
Here's what I get:
Element: comment
Gary
> Gary,
> Gary J wrote:
> >Hi,
document.
elsewhere.
schema
a
> >Thanks
> >Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #590478 is a reply to message #50722] Thu, 19 August 2004 15:18 Go to previous message
> norwood sisson
> norwood sisson
> Gary J wrote:
> > Thanks Ed,
where
> > Here's what I did:
elements);
> > </xsd:complexType>
> > </xsd:schema>
referenced
but
> > Thanks
Re: How to find "root" element in a schema. Check if an element is referenced [message #590495 is a reply to message #50777] Thu, 19 August 2004 15:55 Go to previous message
Gary,
>for "comments".
>Here's my code:
>elements);
>Here's what I get:
>Element: comment
>Thanks
>Gary
>>Gary,
>>Gary J wrote:
>>>Hi,
>document.
>elsewhere.
>schema
>a
>>>Thanks
>>>Gary
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
<br>
<br>
Gary J wrote:<br>
for "comments".
Here's my code:
elements);
Here's what I get:
Element: comment
Gary
</pre>
<pre wrap="">Gary,
Gary J wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
Gary
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: How to find "root" element in a schema. Check if an element is referenced [message #590522 is a reply to message #50854] Thu, 19 August 2004 17:30 Go to previous message
Thanks Ed,
element.");
int count = 0;
count++;
Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #590545 is a reply to message #50881] Thu, 19 August 2004 17:40 Go to previous message
minor correction.
shoud be
> Thanks Ed,
> element.");
> int count = 0;
> count++;
themselves
> Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #590564 is a reply to message #50881] Thu, 19 August 2004 17:45 Go to previous message
Gary,
Setting.
Gary J wrote:
>Thanks Ed,
>element.");
> int count = 0;
> count++;
>Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #590580 is a reply to message #50910] Thu, 19 August 2004 17:47 Go to previous message
Gary,
return count > 0;
Gary J wrote:
>minor correction.
>shoud be
>>Thanks Ed,
>>element.");
>> int count = 0;
>> count++;
>themselves
>>Gary
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
<br>
</blockquote>
<br>
Gary J wrote:<br>
shoud be
</pre>
element.");
int count = 0;
count++;
</pre>
</blockquote>
</pre>
Gary
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: How to find "root" element in a schema. Check if an element is referenced [message #590598 is a reply to message #50937] Thu, 19 August 2004 18:59 Go to previous message
every find().
this:
better way?
Gary
> Gary,
> Setting.
> Gary J wrote:
> >Thanks Ed,
> >element.");
> > int count = 0;
schema);
> > count++;
> > return count > 0;
themselves
right?
> >Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #590622 is a reply to message #50992] Thu, 19 August 2004 20:28 Go to previous message
Gary,
walked once.
>every find().
>this:
>better way?
>Thanks
>Gary
>>Gary,
>>Setting.
>>Gary J wrote:
>>>Thanks Ed,
>>>element.");
>>> int count = 0;
>schema);
>>> count++;
>>> return count > 0;
>themselves
>right?
>>>Gary
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
walked once.<br>
<br>
<br>
Gary J wrote:<br>
every find().
this:
better way?
Gary
</pre>
<pre wrap="">Gary,
Setting.
Gary J wrote:
</pre>
element.");
int count = 0;
</pre>
</blockquote>
</blockquote>
</pre>
count++;
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
</pre>
<pre wrap="">Gary
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: How to find "root" element in a schema. Check if an element is referenced [message #590832 is a reply to message #51020] Tue, 24 August 2004 06:19 Go to previous message
I Ed ,
>Ed Merks wrote:
> Gary,
"directly"
"ArrayList" ?
> walked once.
> >every find().
> >this:
> >better way?
> >Thanks
> >Gary
> >>Gary,
> >>Setting.
> >>Gary J wrote:
> >>>Thanks Ed,
> >>>element.");
> >>> int count = 0;
> >schema);
> >>> count++;
> >>> return count > 0;
> >themselves
> >right?
> >>>Gary
Re: How to find "root" element in a schema. Check if an element is referenced [message #590877 is a reply to message #51347] Tue, 24 August 2004 07:35 Go to previous message
Bertrand,
Bertrand N. wrote:
>I Ed ,
>>Ed Merks wrote:
>>Gary,
>"directly"
>"ArrayList" ?
>>walked once.
>>>every find().
>>>this:
>>>better way?
>>>Thanks
>>>Gary
>>>>Gary,
>>>>Setting.
>>>>Gary J wrote:
>>>>>Thanks Ed,
>>>>>element.");
>>>>>int count = 0;
>>>schema);
>>>>> count++;
>>>>>return count > 0;
>>>themselves
>>>right?
>>>>>Gary
<html>
<head>
<title></title>
</head>
Bertrand,<br>
<br>
<br>
<br>
<pre wrap="">I Ed ,
</pre>
</pre>
</blockquote>
</pre>
<pre wrap="">Gary,
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
"directly"
"ArrayList" ?
</pre>
walked once.
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
every find().
this:
better way?
Gary
</pre>
<pre wrap="">Gary,
Setting.
Gary J wrote:
</pre>
element.");
int count = 0;
</pre>
</blockquote>
</blockquote>
</pre>
count++;
</pre>
</blockquote>
</blockquote>
</pre>
</pre>
</blockquote>
</blockquote>
<pre wrap="">right?
</pre>
<pre wrap="">Gary
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Previous Topic:I need some XSDSchema to test my Application
Next Topic:JDOM & Eclipse
Current Time: Sun Jul 27 03:08:09 EDT 2025
Powered by FUDForum. Page generated in 0.28816 seconds
