Home » Archived » BIRT » metadata.ExtensionException --> The design file XXXX has error and can not be run problem
metadata.ExtensionException --> The design file XXXX has error and can not be run problem [message #50558] |
Thu, 23 June 2005 12:11  |
I am using the BIRT 1.0 release bits and I have an ODA driver written as
two plugins (following the flatfile ODA driver example) that I have
written. I exported these plugins from my dev environment and installed
them in eclipse, with BIRT, GEF and EMF jSDK 1.4.2.08. The problem I'm
having is that when I create a template and bind my ODA datasource to
the template and then preview the report I get the following error in
the preview tab:
"The design file
C:\dev\birt\App\ReportInvestigation\test_ODA_report.rptdesig n has
error and can not be run. "
Note, that before the message is presented, there is a few moments of
churning and the progress bar progresses like its doing some work then
the preview pane presents that message.
I have cleaned my workspace, did -clean everything and same results.
I dug around in the log files and found the following meta.log that
contains the following exception, right after I run the report and get
the error:
2005-06-23 09:08:20 Message [Extension loading error]
Exception
[org.eclipse.birt.report.model.metadata.ExtensionException: Message:The
extension point [org.eclipse.birt.report.model.encryptionHelper] is not
found. Error code:EXTENSION_POINT_NOT_FOUND
org.eclipse.birt.report.model.metadata.ExtensionLoader.doLoa d(ExtensionLoader.java:102)
org.eclipse.birt.report.model.metadata.ExtensionLoader.load( ExtensionLoader.java:62)
org.eclipse.birt.report.model.metadata.ExtensionManager.init ialize(ExtensionManager.java:40)
org.eclipse.birt.report.model.api.DesignEngine.initialize(De signEngine.java:110)
org.eclipse.birt.report.model.api.DesignEngine.newSession(De signEngine.java:156)
org.eclipse.birt.report.engine.parser.ReportParser.parse(Rep ortParser.java:79)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:87)
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngine.java:212)
org.eclipse.birt.report.viewer.aggregation.BaseFragment.prep areAttributeBean(Unknown
Source)
org.eclipse.birt.report.viewer.aggregation.BaseFragment.serv ice(Unknown
Source)
at org.eclipse.birt.report.viewer.servlets.ViewerServlet.doPost (Unknown
Source)
at org.eclipse.birt.report.viewer.servlets.ViewerServlet.doGet( Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Unknown Source)
Below this email is the report causing the problem. As you can see I
have only defined my data source. I suspect that some interface in my
ODA driver is failing silently or something. However, and heres the
pain, when I run on 1.0 source code via debugger and runtime workbench
and do the same thing, everything is fine. No errors and the preview
pane works.
As a further data point, I also tried to create a template and add some
data sets to it and I can view the data sets, and navigate all the pages
of the data set editor with no problems presented. just when I go to
preview the report do I get this bizarre message. This is just plain weird.
Perhaps when I export my ODA plugins I need to export something else
with them, maybe?
Any ideas? (below is the simple report pasted)
<!-- Written by Eclipse BIRT 1.0 -->
<report xmlns=" http://www.eclipse.org/birt/2005/design" version="1">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.0
Build <20050601-0809></property>
<property name="units">in</property>
<data-sources>
<oda-data-source extensionID="mydriver.connection" name="Data
Source">
<property
name="FILE_PATH_PROPERTY">C:\builds\birt_oda_rsa_setup\mp_oda_driver\root.xxx </property>
</oda-data-source>
</data-sources>
<page-setup>
<simple-master-page name="Simple MasterPage">
<page-footer>
<text>
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
</report>
Re: metadata.ExtensionException --> The design file XXXX has error and can not be run problem [message #50587 is a reply to message #50558] |
Thu, 23 June 2005 12:34   |
as a follow on question to use birt fully in my client app all I need in
addition to the support structure is
birt-report-framework-1_0.zip
correct? anything else needed?
> the preview tab:
> "The design file
> the error:
> Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> org.eclipse.birt.report.viewer.servlets.ViewerServlet.doGet( Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> pane works.
> with them, maybe?
> <property name="createdBy">Eclipse BIRT Designer Version 1.0.0 Build
> <data-sources>
> Source">
> <property
> </oda-data-source>
> </data-sources>
> <page-setup>
> <page-footer>
> <text>
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> </report>
Re: metadata.ExtensionException --> The design file XXXX has error and can not be run problem [message #50697 is a reply to message #50558] |
Thu, 23 June 2005 14:21   |
futher information I found an additional log for the report designer
with the following error message:
un 23, 2005 11:19:21 AM org.eclipse.birt.core.util.BirtTimer logTimeTaken
INFO: Engine startup takes 341 Milliseconds.
Jun 23, 2005 11:19:22 AM
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper openReportDesign
SEVERE: invalid design file
C:\dev\birt\App\workspace\ddddd\new_report.rptdesign
Bizarre problem. any help is REALLY appreciated at this point.
> the preview tab:
> "The design file
> the error:
> Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> pane works.
> with them, maybe?
> <data-sources>
> Source">
> <property
> </oda-data-source>
> </data-sources>
> <page-setup>
> <page-footer>
> <text>
> </text>
> </page-footer>
> </page-setup>
> </report>
Re: metadata.ExtensionException --> The design file XXXX has error and can not be run problem [message #50799 is a reply to message #50558] |
Thu, 23 June 2005 15:58   |
Mike,
Did you also export your ODA runtime plugin (the one that implements the
org.eclipse.birt.data.oda.dataSource extension point) to the viewer's
plugins directory:
\eclipse\plugins\org.eclipse.birt.report.viewer_1.0.0\birt\W EB-INF\plugins ?
Without this the viewer web app will not be able to access the ODA runtime
driver for report viewing.
Gary
"Mike Boyersmith" <mjboyers@us.ibm.com> wrote in message
news:d9emv7$t0t$1@news.eclipse.org...
> the preview tab:
> "The design file
> the error:
> Exception
> at
r.java:102)
> at
java:62)
> at
Manager.java:40)
> at
110)
> at
156)
> at
9)
> at
> at
e.java:212)
> at
(Unknown
> Source)
> at
> Source)
> Source)
> Source)
> at
> at
ain.java:193)
> at
va:256)
> at
> at
> at
va:191)
> at
> at
46)
> at
> at
> at
> at
> at
> at
java:171)
> at
> at
tValve.java:153)
> at
> at
> at
:174)
> at
> at
> at
> at
> at
> at
a:683)
> pane works.
weird.
> with them, maybe?
> <data-sources>
> Source">
> <property
x</property>
> </oda-data-source>
> </data-sources>
> <page-setup>
> <page-footer>
> <text>
> <text-property
> </text>
> </page-footer>
> </page-setup>
> </report>
Re: metadata.ExtensionException --> The design file XXXX has error and can not be run problem [message #50911 is a reply to message #50799] |
Thu, 23 June 2005 16:52  |
That fixed it, thanks for the quick replies.
BTW: that error message and the exception in the log, really didn't give
a clue that this was the problem. I'm going to file an RFE to maybe give
better logging for this problem.
Thanks again BIRT team!
- Mike
Gary Xue wrote:
> Mike,
> plugins directory:
> Gary
>>the preview tab:
>>"The design file
>>the error:
>>Exception
>>at
> r.java:102)
>>at
> java:62)
>>at
> Manager.java:40)
>>at
> 110)
>>at
> 156)
>>at
> 9)
>>at
>>at
> e.java:212)
>>at
> (Unknown
>>Source)
>>at
>>Source)
>>Source)
>>Source)
>>at
>>at
> ain.java:193)
>>at
> va:256)
>>at
>>at
>>at
> va:191)
>>at
>>at
> 46)
>>at
>>at
>>at
>>at
>>at
>>at
> java:171)
>>at
>>at
> tValve.java:153)
>>at
>>at
>>at
> :174)
>>at
>>at
>>at
>>at
>>at
>>at
> a:683)
>>pane works.
> weird.
>>with them, maybe?
>><?xml version="1.0" encoding="UTF-8"?>
>> <data-sources>
>>Source">
>> <property
> x</property>
>> </oda-data-source>
>> </data-sources>
>> <page-setup>
>> <page-footer>
>> <text>
>> <text-property
>> </text>
>> </page-footer>
>> </page-setup>
>></report>
Current Time: Sun Aug 31 12:57:38 EDT 2025
Powered by FUDForum. Page generated in 0.04317 seconds
