EMF many-valued features, set or sequence? [message #50539] |
Mon, 11 February 2008 02:27  |
Hi.
Up to now I thought EMF features would always result to be sequences,
and I had to write code like
structure
->iterate( ou : OrganizationalUnit;
a : Sequence(OrganizationalUnit) = Sequence{}
| let start: Sequence(OrganizationalUnit)
= a->append(ou) in
ou.allSubUnits()
->iterate(subOu: OrganizationalUnit;
subA: Sequence(OrganizationalUnit) = start
| subA->append(subOu)
all the time. Union or concatenate would be practical...
Then I started to use the "closure" feature of MDT OCL, but when i try
self->closure(directSubRoles)->append(self)
I get an error:
Cannot find operation (append(ContractRole)) for the type
(Set(ContractRole))
Thus here, I end up with a set..
Is there an advice in how to put the members of two ECore features
together? Is there something like "appendAll()"?
Is there a way to make a set from a sequence?
Yes, and before I forget it. Given a many-valued feature F of type T,
when I try:
let f2: Sequence(T) = F in f2
then I get an error. What is the correct OCL type for a a many-valued
feature F of type T?
Best, Philipp
Re: EMF many-valued features, set or sequence? [message #50569 is a reply to message #50539] |
Mon, 11 February 2008 10:17  |
Hi, Philipp,
See some replies in-line, below.
HTH,
Christian
Philipp W. Kutter wrote:
> Hi.
> structure
> = a->append(ou) in
> ou.allSubUnits()
> | subA->append(subOu)
Ouch! How about this:
structure->asSet()->union(structure.allSubUnits()->asSet())
This gathers up the OUs in 'structure' together with all of their subunits.
Or, rather, I think it should :-)
> I get an error:
> (Set(ContractRole))
Right. Sets aren't ordered, so you would do
self->closure(directSubRoles)->including(self)
All Collection types in OCL have a union() operation that constructs a new
collection containing all of the elements of the source collection and all
of the elements of the argument collection (which must be of the same
kind).
Yes. Any kind of collection can be converted to any other kind using the
asSet(), asSequence(), asOrderedSet(), and asBag() operations.
> when I try:
It depends on the uniqueness and orderedness of the feature:
isUnique isOrdered Collection Type
false false Bag
false true Sequence
true false Set
true true OrderedSet
> Best, Philipp
FUDForum. Page generated in 0.03600 seconds
