Home » Eclipse Projects » Mylyn » 'Move To' copies instead of moving
'Move To' copies instead of moving [message #50531] Thu, 19 June 2008 11:12 Go to next message
When in 'Task List' view, hightlighting a task in the category based on a
Bugzilla query and clicking 'Move To' to move it to a local category
doesn't move the chosen task, but instead copies it there so it appears in
both categories now. Is that the correct behavior? Is it possible to
just move the task?
Thank you in advance,
Simeon
Re: 'Move To' copies instead of moving [message #51275 is a reply to message #50531] Fri, 27 June 2008 20:51 Go to previous messageGo to next message
Originally posted by: rob.elves.eclipse.org
Hi Simeon,
This behavior is by design. When moving a task from a query to a
category the task is essentially copied. The reasoning behind this is
that a query in the Task List is a true representation of the tasks that
result from executing the query on the repository. If the contents
don't line up, information can be lost and results confusing. For this
reason, you can't selectively remove tasks from a query. To do so you
must redefine your query.
-Rob
> a Bugzilla query and clicking 'Move To' to move it to a local category
> in both categories now. Is that the correct behavior? Is it possible
> to just move the task?
> Simeon
Re: 'Move To' copies instead of moving [message #51998 is a reply to message #51275] Thu, 03 July 2008 07:38 Go to previous messageGo to next message
Hi, Rob
Thanks for the explanation, it makes sense the way you are describing it.
The 'Move to' name makes it a bit misleading, perhaps 'Copy/Clone to'
would capture it more accurately... The functionality I was looking for
was some kind of a simple workflow starting out from the task on a query
and then moving through a set of folders depending on changes in
particular attributes of a task through its lifecycle. Not sure if
something like this is envisioned by Mylyn's use cases or it had different
usage patterns in mind?
Thank you,
Simeon
Re: 'Move To' copies instead of moving [message #52024 is a reply to message #51998] Thu, 03 July 2008 09:50 Go to previous message
Originally posted by: mauro.molinari.cardinis.com
Simeon Leyzerzon ha scritto:
> Hi, Rob
> it. The 'Move to' name makes it a bit misleading, perhaps 'Copy/Clone
> to' would capture it more accurately... The functionality I was looking
> for was some kind of a simple workflow starting out from the task on a
> query and then moving through a set of folders depending on changes in
> different usage patterns in mind?
> Thank you,
> Simeon
IMHO, I find that showing queries like folders but treating them
differently "under the hood" is not very user-friendly.
I opened a request enhancement some time ago for this (I would have
liked to delete and move tasks from queries, too), but it has been
closed as wontfix: https://bugs.eclipse.org/bugs/show_bug.cgi?id=196925
Mauro.
Re: 'Move To' copies instead of moving [message #590588 is a reply to message #50531] Fri, 27 June 2008 20:51 Go to previous message
Hi Simeon,
-Rob
> Simeon
Re: 'Move To' copies instead of moving [message #590835 is a reply to message #51275] Thu, 03 July 2008 07:38 Go to previous message
Hi, Rob
Thank you,
Simeon
Re: 'Move To' copies instead of moving [message #590857 is a reply to message #51998] Thu, 03 July 2008 09:50 Go to previous message
> Hi, Rob
> Thank you,
> Simeon
Mauro.
Previous Topic:Hello world for Mylyn monitor
Next Topic:Help with Project Explorer
Current Time: Fri Jul 11 22:53:30 EDT 2025
Powered by FUDForum. Page generated in 0.04732 seconds
