Re: Firefox error -8048 accessing bugs.eclipse.org [message #50709 is a reply to message #50681] |
Mon, 26 November 2007 04:19   |
Originally posted by: mauro.molinari.cardinis.com
Denis Roy ha scritto:
> Mauro,
> You're the only one to report an error of this kind, so I'm inclined to
> think there's something strange with your Firefox browser. Would you
> have any specific settings in your Security preferences, or perhaps a
> proxy server that could be configured a specific way (or simply out of
> date)?
> Denis
Hi Denis,
I have default options for Firefox 2. It has been for some days that I
can't access bugs.eclipse.org anymore with it: it had happened rarely
before, and I simply needed to try again to get it to work. But now, it
never works.
To make bugs.eclipse.org work again with my Firefox 2, I have to do the
following:
(I'm transalting from Italian, so in English the item names might be
quite different)
Tools | Settings... | Advanced | Ciphering (last tab) | Verify | Don't
use OCSP to verify certificates.
In this way it works.
Otherwise, if I leave the default "Use OCSP to verify just those
certificates that specify an OCSP service address", it does not.
Please note that I'm not experiencing any problems with other sites
using SSL with Firefox 2 and that I'm using a direct connection to
Internet (no proxy)...
Cheers
Mauro.
Re: Firefox error -8048 accessing bugs.eclipse.org [message #50737 is a reply to message #50709] |
Mon, 26 November 2007 09:24   |
Eclipse Webmaster Messages: 607353 Registered: July 2009 |
>> Mauro,
>> to think there's something strange with your Firefox browser. Would
>> you have any specific settings in your Security preferences, or
>> perhaps a proxy server that could be configured a specific way (or
>> simply out of date)?
>> Denis
> Hi Denis,
> never works.
> following:
> quite different)
> Cheers
> Mauro.
Mauro,
Indeed, I get the same error if I enable OCSP verification on Firefox
(any version). I checked our certificate, and it does specify an OCSP
URI (which points to our certificate provider). I've opened a support
issue with them for this.
On a side note, I checked all my Firefox installations, and my default
is Don't Use OCSP. Because Firefox 2 is the #1 browser for
bugs.eclipse.org, I'm guessing that the global default is Don't Use OCSP.
I also checked a dozen https sites out there, and none of them specify
an OCSP URI. I think you can simply set the verification option to 'Do
not verify' and you won't lose much. As I said, I don't think OCSP is
the default value for Firefox, as I would have heard about this a long
time ago.
I'll casually follow up with our certificate provider about this.
D.
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Firefox error -8048 accessing bugs.eclipse.org [message #50793 is a reply to message #50765] |
Tue, 27 November 2007 12:01  |
> Thanks for reporting this.
Thanks to you Denis, I'm glad to have been of help to solve this.
And yes, I may have changed in some way my Firefox2 default settings by
enabling OCSP verification, although I don't remember when and how... :-P
Mauro.
FUDForum. Page generated in 0.03089 seconds
