Re: Creating ecore file from a schema file for VXML 1.0 [message #4421] |
Thu, 03 August 2006 06:27  |
Replying also to eclipse.modeling.gmf
You'll need to install XSD from the EMF project, which will then give you
the option of creating an *.ecore/*.genmodel from any *.xsd file. In other
words, it's an EMF feature, not GMF.
Best,
Rich
On 8/3/06 6:10 AM, in article
04c8975d3989da3e02c7d3b01e4eb891$1@www.eclipse.org, "Senthil"
<senthil.periasamy@flextronicssoftware.com> wrote:
> Hi Vikas
> Can you tell how to create a ecore from a schema file , i am
> having schema file for VXML 2.0 and i need to create all the necessary
> files like
> ecore,.genmodel,.gmfgen,.gmfgraphm,.gmfmap,.gmftool .
> Regards
> Senthil
Re: Help - Re: Creating ecore file from a schema file for VXML 1.0 [message #4629 is a reply to message #4491] |
Thu, 03 August 2006 07:56  |
Try File -> New -> Other... -> Eclipse Modeling Framework -> EMF Model ->
Select the XML Schema importer and your *.xsd file. From it, an *.ecore
file will be created, along with a *.genmodel. If you don't see this
importer, you don't have XSD installed.
-Rich
On 8/3/06 6:37 AM, in article
e043f6d20342e6b77349ed076b423a12$1@www.eclipse.org, "Senthil"
> i have created an sample gmf project and i have copied my schema file to
> the model folder after that i am not able to find any links or options to
> create an
> ecore from the schema file.
> regards
> senthil
FUDForum. Page generated in 0.06609 seconds
