How to use the VE SDK [message #50438] |
Thu, 15 July 2004 16:46  |
I'm new to Eclipse PlugIn development. I'm interested in creating a
VisualBuilder for our own proprietary 4GL development system.
So wanted to run VE and examine source of VE.
I've downloaded the latest version of the SDK (VE-SDK-20040628.zip).
I unzipped this to my plugin directory and restarted Eclipse.
When I view the "Help About" the set of features for GEF, EMF, JEM, and VE
match what is mentioned in the FAQ.
But I get the below exception when I try to open the Visual Editor on a
java file.
I tried the procedure in the FAQ named:
How do I develop on top of VE (i.e. extend the VE)?
I still get the exception below and now I have a ton of projects in my
workspace.
org.eclipse.core.runtime.CoreException[1]:
java.lang.ClassNotFoundException:
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:404)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:307)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:336)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1313)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:131)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:124)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:113)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:196)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:193)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:790)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:788)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:775)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:585)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:573)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2201)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2134)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2126)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2113)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2108)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2091)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:258)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:251)
org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:166)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Re: How to use the VE SDK [message #50912 is a reply to message #50857] |
Mon, 19 July 2004 15:11  |
Steve
You have (maybe) any plugin with gef libraries inside plugin
(jfacedbc or sqlexplorer have this; older version myeclipse <3.8beta2
have gef < 3.0, too)
You try delete this plugin (if You have one)
regards
Steve Harper wrote:
> "Help About | Feature Details" shows these versions:
> Eclipse Project SDK 3.0.0
> Visual Editor 1.0.0
> GEF 3.0.0
> EMF 2.0.0
> I tried a reinstall and reloaded just the runtime of VE and insured I had
> the recommended version of GEF and EMF - still got the same ClassNotFound
> exception when I try to run the created Visual Editor Wizard or open an
> exising Java file with the Visual Editor.
> What happens to the rest of my eclipse environment if I delete the
> configuration directory. I also use Eclipse to develop Java that is not a
> PlugIn. Sure it's OK to delete configuration directory?
> Jeff Myers wrote:
>> Steve,
>> Please reply with a list the versions of VE, GEF, EMF and Eclipse you
>> have installed. It may also help to delete the configuration directory
>> in your eclipse directory and see if that helps.
>> Thanks,
>> - Jeff
Re: How to use the VE SDK [message #50939 is a reply to message #50885] |
Mon, 19 July 2004 13:30  |
Thanks Rich the -clean option worked.
I can now run VE.
Thanks for all the help.
Rich Kulp wrote:
> Just use the -clean argument on your command line. That is the better
> equivalent to erasing the configuration directory. BUT only do it the
> first, DON'T use -clean everytime or you will keep clearing the
> configuration directory and recreating it.
Re: How to use the VE SDK [message #50967 is a reply to message #50939] |
Mon, 19 July 2004 14:05  |
Steve,
Using the -clean option is equivalent to removing your configuration
directory. The configuration directory is a cache of the information
about the plug-ins you have installed. Your user Eclipse options and
preferences are stored in the .metadata directory in your workspace.
This trouble with the configuration directory that so many people are
running into is due to the builds of VE having the same plug-in version
number. When Eclipse comes up it checks to see if the version numbers
have changed, and if not, doesn't bother updating the cached info for
that plug-in. So often when upgrading to new development versions of VE
(as opposed to new point releases) you need to clear out the cached
configuration info to get it to recognize the changes properly.
- Jeff
> I can now run VE.
Re: How to use the VE SDK [message #595325 is a reply to message #50438] |
Thu, 15 July 2004 20:48  |
You have wrong GFE or draw2d (maybe from another plugin like myeclipse,
jfacedbc, sqlexplorer etc)
regards
> java file.
> workspace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: How to use the VE SDK [message #595383 is a reply to message #50438] |
Fri, 16 July 2004 10:22  |
Steve,
- Jeff
> java file.
> workspace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: How to use the VE SDK [message #595470 is a reply to message #50606] |
Mon, 19 July 2004 11:57  |
Visual Editor 1.0.0
GEF 3.0.0
EMF 2.0.0
Jeff Myers wrote:
> Steve,
> - Jeff
Re: How to use the VE SDK [message #595475 is a reply to message #50857] |
Mon, 19 July 2004 12:50  |
Thanks, Rich Kulp
Re: How to use the VE SDK [message #595479 is a reply to message #50857] |
Steve
regards
> Visual Editor 1.0.0
> GEF 3.0.0
> EMF 2.0.0
> Jeff Myers wrote:
>> Steve,
>> Thanks,
>> - Jeff
Re: How to use the VE SDK [message #595483 is a reply to message #50885] |
I can now run VE.
Re: How to use the VE SDK [message #595492 is a reply to message #50939] |
Steve,
- Jeff
> I can now run VE.
FUDForum. Page generated in 0.18654 seconds
