Home » Modeling » OCL » help me with a constraint please :)
help me with a constraint please :) [message #50427] Thu, 07 February 2008 05:53 Go to next message
Originally posted by: ingelin.isfeldt.gmail.com
Newbie to OCL and here is mye question:
In my model, a Puzzle contains Field. Row, Column and Box extends Field.
Row contains Cell and Row, Column and Box refers to cells.
Now, from my Puzzle I need to check that any row and column has exactly
one cell in common.
Any ideas for this?
Hope someone can help me out :)
Thanks!
Re: help me with a constraint please :) [message #50511 is a reply to message #50427] Fri, 08 February 2008 08:47 Go to previous message
Hi, ingelin,
An answer will depend on what, precisely, your model looks like.
Is the association between Column and Cell bidirectional? If so, assuming
conventional association-end names, the following might work:
context Row
inv unique_cells: self.cell->isUnique(c : Cell | c.column)
This would work also in the case that your model is a UML model, and not an
Ecore model, because OCL in UML can navigate non-navigable and even unnamed
association ends.
Otherwise, if a Cell does not know its column, you might try:
context Row
Column.allInstances()->any(col | col.cell->includes(c)))
but this wastes time looking at all Columns, not just those in the same
puzzle.
As I say, this really depends on the specific structure of your model.
HTH,
Christian
> one cell in common.
> Any ideas for this?
> Thanks!
Previous Topic:OCL and uml::InstanceSpecification
Next Topic:EMF many-valued features, set or sequence?
Current Time: Sun Jul 13 23:14:11 EDT 2025
Powered by FUDForum. Page generated in 0.23321 seconds
