Home » Archived » Test and Performance Tools Platform (TPTP) » Extending the tptp UI
Extending the tptp UI [message #50379] Fri, 13 January 2006 11:22 Go to next message
Originally posted by: respond_to_newsgroup.nowhere.com
I've read in various places that the tptp UI can be extended, but I can't
find any documentation describing the available extension points. Can
someone point me to the documentation?
Thanks.
Re: Extending the tptp UI [message #50408 is a reply to message #50379] Fri, 13 January 2006 12:47 Go to previous messageGo to next message
See the examples under File > New > Example > UI. Once you create a
specific example, the help content window will point you to the correct help
page. You can also try reading the documentation under the schema of the
extension points that you're interested in.
"Sarah Ettritch" <respond_to_newsgroup@nowhere.com> wrote in message
news:dq8k4k$km3$1@utils.eclipse.org...
> Thanks.
Re: Extending the tptp UI [message #50492 is a reply to message #50408] Fri, 13 January 2006 15:58 Go to previous message
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:dq8p3j$tor$1@utils.eclipse.org...
> help
Thanks. That'll definitely get me started.
Previous Topic:API for sending commands
Next Topic:serviceconfig.xml
Current Time: Sat Jul 26 06:01:32 EDT 2025
Powered by FUDForum. Page generated in 0.04224 seconds
