Home » Archived » XML Schema Definition (XSD) » What about the future of XSDEdit?
What about the future of XSDEdit? [message #50360] |
Tue, 17 August 2004 04:47  |
Originally posted by: daniel_leo.163.com
I am using XSDEdit to implement our xml schema editor. But there are some
shortages:
1) Only string type can be added
2) SubstitutionGroup can not be defined
3) baseType cannot be defined
These above shortages can be solved by modifying code, but the result
is somewhat ugly, there are very much strange info listed in combox
4) key&keyref cannot be defined
5) Annotation&Documentation can not be defined
These above shortages cannot be solved by modifying code.
And I am wondering what is the future strategy of XSDEdit&XSDEditor. Will
it will support the 4) and 5) feature? Will it become a fully-featured XML
schema editor, like XMLSpy ? Or XSDEdit&XSDEditor is just a prototype that
just shows the functions of XSD library?
So if the XSDEdit/XSDEditor can support XML schema editing perfectly,like
XMLSpy, that can make XSD be popular for most ternimal users.The question
is what is the future of XSDEdit, or what is the roadmap of XSDEdit?
Brs/
Daniel Leo
Re: What about the future of XSDEdit? [message #50388 is a reply to message #50360] |
Tue, 17 August 2004 06:49   |
Daniel,
The XSD Edit support has been used more for viewing schemas than for
full-function editing so there hasn't been much demand to improve all
the editing capabilities. The XSD Editor is really just a demonstration
of how the XSD capabilities can be used to build an editor. We've had
no time or resource to improve it beyond the current stage. Items 1-4
could be added fairly easily, but full support for 5 would require full
XML editing capability, which would be a lot of work. Our fall back is
that in the sample editor, it's always possible for users to edit by
changing text in the source view.
There are other tools that build on XSD's support. For example, WSAD
includes a schema editor that uses XSD. But given our resource
constraints, we will need to rely on others to build a full function XML
Schema editor like XML Spy. I believe there is an XML tools project in
the works that will have a mission to build a fully functional editor.
If there are improvements to XSD you'd like to prototype and contribute
back to the project, that would be welcome as well...
daniel leo wrote:
>Hi,
>shortages:
>Thanks:)
>Brs/
>Daniel Leo
Re: What about the future of XSDEdit? [message #50415 is a reply to message #50388] |
Tue, 17 August 2004 07:34   |
Thank you very much:)
Brs/
Daniel Leo
Ed Merks wrote:
> Daniel,
> daniel leo wrote:
> >Hi,
> >shortages:
> >Thanks:)
> >Brs/
> >Daniel Leo
Re: What about the future of XSDEdit? [message #51241 is a reply to message #50360] |
Mon, 23 August 2004 15:37  |
Daniel,
Check out the new Eclipse Web Tools project. It is still in a formative
stage digesting initial open source contributions from IBM and Object Web,
but the IBM contribution includes a nice first cut at an XSD editor and an
XML document editor. The graphical view of the XSD editor is very similar
to that from other commercial XML Schema editors. I believe this
contribtion was extracted from a subset of IBM's WSAD code, so it is already
quite mature.
I have not had a chance to review the source code, but I believe the editor
is based on the EMF/XSD model, although maybe not the EMF generated editor.
The source is not yet in CVS, but zip files of the initial source
contribution are available for download.
Dave Carlson
"daniel leo" <daniel_leo@163.com> wrote in message
news:cfsgn8$rl9$1@eclipse.org...
> shortages:
> Thanks:)
> Brs/
> Daniel Leo
Re: What about the future of XSDEdit? [message #590225 is a reply to message #50360] |
Daniel,
daniel leo wrote:
>Hi,
>shortages:
>Thanks:)
>Brs/
>Daniel Leo
Re: What about the future of XSDEdit? [message #590242 is a reply to message #50388] |
Brs/
Daniel Leo
Ed Merks wrote:
> Daniel,
> daniel leo wrote:
> >Hi,
> >shortages:
> >Thanks:)
> >Brs/
> >Daniel Leo
Re: What about the future of XSDEdit? [message #590743 is a reply to message #50360] |
Daniel,
quite mature.
Dave Carlson
> shortages:
> Thanks:)
> Brs/
> Daniel Leo
Current Time: Tue Jul 22 19:13:18 EDT 2025
Powered by FUDForum. Page generated in 0.03532 seconds
