Home » Eclipse Projects » Nebula » Re: Need a multi-column list widget for SWT
Re: Need a multi-column list widget for SWT [message #50336] Tue, 04 March 2008 11:30 Go to next message
Martin,
This is the SWT newsgroup. The Nebula controls are supported on the
eclipse.technology.nebula newsgroup. I am copying your question there
as these are the right people to answer your question. I have not
actually used Gallery beyond a cursory glance--Nicolas Richeton is the
Gallery maintainer and should be able to help you.
Matthew
Martin Thompson wrote:
> For both the grid and gallery stuff ffrom Nebula I get errors similar to (or
> exactly the same as):
> java.lang.Error: Unresolved compilation problems:
> The constructor Grid(Shell, int) is undefined
> The method setText(String) is undefined for the type GridColumn
> at main.GridSnippet1.main(GridSnippet1.java:35)
> Exception in thread "main"
> Any ideas why there examples don't refer to existing methods and
> constructors???
> "Matthew Hall" <matthall@woodcraftmill.com> wrote in message
> news:fqhp7o$5fc$1@build.eclipse.org...
>> Take a look at the API javadocs--I believe this is supported. It was
>> designed for photos but you can just as easily create a GalleryItem, set
>> the text property, and leave the image property null.
>> Matthew
>>> The gallery control appears to be for photo galleries... I just want a
>>> multi-selectable list of text strings.
>>> news:fqhfg0$bsq$1@build.eclipse.org...
>>>> It sounds like you want a control like Windows Explorer while in "List"
>>>> view. I'm don't know of any SWT controls that do this, however the
>>>> Nebula Gallery control might come close:
>>>> http://www.eclipse.org/nebula/widgets/gallery/gallery.php
>>>> The Nebula project is supported on the eclipse.technology.nebula
>>>> newsgroup.
>>>> Good luck,
>>>> Matthew
>>>>> Is there such a beast? I don't need much functionality just
>>>>> 1) the ability to do wrapping to new column after x number of entries
>>>>> in a list
>>>>> 2) multi-selection of list entries
>>>>> 3) ability to specify number of rows/columns in the list
>>>>> Any ideas? This doesn't seem like a lot to ask... and it has been asked
>>>>> before on the web ... just not sure if it has been addressed here...
>>>>> but didn't find it in a search...
>>>>> regards,
>>>>> Martin
Re: Need a multi-column list widget for SWT [message #50365 is a reply to message #50336] Tue, 04 March 2008 13:26 Go to previous messageGo to next message
Thanks Matthew...
Here's what I want to do... has anyone used Gallery for something simple and
text-based like this?
Point taken Robert...
Attached is a mockup... I need up to 480 3-character channels to be
displayed in the left hand list. I need them wrapped alphanumerically from
left to right each time the individual columns are filled from top to
bottom. As channels are selected (individually or multiples) in the left
hand (multi-column list) they can be moved with the [>] button to the right
hand list (Selected). I get the two lists idea. Really I do.
"Robert B" <oh1226@hotmail.com> wrote in message
news:fqi0qf$3ct$2@build.eclipse.org...
> Your description is not very clear!
> My guess is that you want to have a list of items with multiple
> selections.
> Then you want to put them to another list? Should it be simple?
> Use two lists!
> Regards.
news:fqjteu$mnr$1@build.eclipse.org...
> Martin,
> Matthew
>> (or
>> constructors???
>>> Matthew
>>>>> "List"
>>>>> newsgroup.
>>>>> Good luck,
>>>>> Matthew
>>>>>> in a list
>>>>>> asked
>>>>>> regards,
>>>>>> Martin
Re: Need a multi-column list widget for SWT [message #50421 is a reply to message #50365] Wed, 05 March 2008 03:22 Go to previous messageGo to next message
Originally posted by: sf.tragwerk-dresden.de
Hi Martin,
have a look at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215504
Sebastian
IGVuOaJKZXpRUFzR [message #55968 is a reply to message #50365] Mon, 14 July 2008 03:59 Go to previous messageGo to next message
Originally posted by: pcdmvl.lypcik.com
9aIYmh <a href="http://xpdhgdcbzdyu.com/">xpdhgdcbzdyu</a>,
xtkgldocnjer,
vzuiyvoeuuoc[/link],
http://mtdykeevwpmf.com/
qhyTlPjgXdbk [message #57413 is a reply to message #50365] Sat, 09 August 2008 19:55 Go to previous messageGo to next message
Originally posted by: syqizt.qsuybr.com
cQ1mAX <a href="http://sqjnfesmqdum.com/">sqjnfesmqdum</a>,
anpkoqztmjaj,
hqfdkegdjwnu[/link],
http://dqqgndkedtnr.com/
MdqyOybmzjFeaStscw [message #57992 is a reply to message #50365] Fri, 15 August 2008 03:37 Go to previous messageGo to next message
Originally posted by: cxsxpu.qcoarg.com
YjL5fl <a href="http://akebwbrqthhn.com/">akebwbrqthhn</a>,
bkovuneyvwyr,
biqjedznmpcc[/link],
http://nxvcjeisyset.com/
Re: IGVuOaJKZXpRUFzR [message #518590 is a reply to message #55968] Thu, 04 March 2010 09:53 Go to previous messageGo to next message
huh?
"pvevfdvo" <pcdmvl@lypcik.com> wrote in message
news:fc2692d83e8009d41c817e358a36c2e0$1@www.planeteclipse.net...
> xtkgldocnjer,
Re: IGVuOaJKZXpRUFzR [message #518591 is a reply to message #518590] Thu, 04 March 2010 09:56 Go to previous messageGo to next message
This is a test for Steven E. Nordin. My account settings have always had
"display email address" as "NO!".
Let's see what we get here!
"Martin Thompson" wrote in message
news:hmohge$ubj$1@build.eclipse.org...
> huh?
>> xtkgldocnjer,
[Updated on: Thu, 04 March 2010 10:43] by Moderator
Re: IGVuOaJKZXpRUFzR [message #518667 is a reply to message #518591] Thu, 04 March 2010 07:46 Go to previous messageGo to next message
This is a test after modifying registry...
news:hmohmo$2sr$1@build.eclipse.org...
>> huh?
>>> xtkgldocnjer,
[Updated on: Thu, 04 March 2010 13:04] by Moderator
Re: IGVuOaJKZXpRUFzR [message #518668 is a reply to message #518667] Thu, 04 March 2010 07:46 Go to previous messageGo to next message
see now?
news:hmoq8b$jli$1@build.eclipse.org...
>>> huh?
>>>> xtkgldocnjer,
[Updated on: Thu, 04 March 2010 13:06] by Moderator
Re: IGVuOaJKZXpRUFzR [message #518669 is a reply to message #518668] Thu, 04 March 2010 07:46 Go to previous messageGo to next message
test
news:hmoq9a$k9m$1@build.eclipse.org...
> see now?
>>>> huh?
>>>>> xtkgldocnjer,
Re: IGVuOaJKZXpRUFzR [message #518670 is a reply to message #518669] Thu, 04 March 2010 07:46 Go to previous messageGo to next message
please!
[Updated on: Thu, 04 March 2010 13:07] by Moderator
Re: IGVuOaJKZXpRUFzR [message #518678 is a reply to message #518670] Thu, 04 March 2010 12:58 Go to previous messageGo to next message
test1
[Updated on: Thu, 04 March 2010 13:08] by Moderator
Re: IGVuOaJKZXpRUFzR [message #518679 is a reply to message #518678] Thu, 04 March 2010 13:01 Go to previous messageGo to next message
test2
"Martin Thompson" <nobodyhere@UncleAecl.com> wrote in message ...
[Updated on: Thu, 04 March 2010 13:09] by Moderator
Re: Need a multi-column list widget for SWT [message #518690 is a reply to message #50421] Thu, 04 March 2010 13:16 Go to previous messageGo to next message
This is a pointer to Nebula... thanks Sebastian...
"Sebastian Fuchs" <sf@tragwerk-dresden.de> wrote in message
news:fqll6p$riu$1@build.eclipse.org...
> Hi Martin,
> have a look at
> Sebastian
Re: Need a multi-column list widget for SWT [message #518691 is a reply to message #518690] Thu, 04 March 2010 13:19 Go to previous message
Test
news:hmotdp$v53$1@build.eclipse.org...
>> Hi Martin,
>> have a look at
>> Sebastian
Re: Need a multi-column list widget for SWT [message #588892 is a reply to message #50336] Tue, 04 March 2008 13:26 Go to previous message
Thanks Matthew...
> selections.
> Use two lists!
> Regards.
> Martin,
> Matthew
>> (or
>> constructors???
>>> Matthew
>>>>> "List"
>>>>> newsgroup.
>>>>> Good luck,
>>>>> Matthew
>>>>>> in a list
>>>>>> asked
>>>>>> regards,
>>>>>> Martin
Re: Need a multi-column list widget for SWT [message #588913 is a reply to message #50365] Wed, 05 March 2008 03:22 Go to previous message
Hi Martin,
have a look at
Sebastian
IGVuOaJKZXpRUFzR [message #591077 is a reply to message #50365] Mon, 14 July 2008 03:59 Go to previous message
xtkgldocnjer,
qhyTlPjgXdbk [message #591599 is a reply to message #50365] Sat, 09 August 2008 19:55 Go to previous message
anpkoqztmjaj,
MdqyOybmzjFeaStscw [message #591810 is a reply to message #50365] Fri, 15 August 2008 03:37 Go to previous message
bkovuneyvwyr,
Re: IGVuOaJKZXpRUFzR [message #599083 is a reply to message #55968] Thu, 04 March 2010 09:53 Go to previous message
huh?
> xtkgldocnjer,
Re: IGVuOaJKZXpRUFzR [message #599089 is a reply to message #518590] Thu, 04 March 2010 09:56 Go to previous message
"Martin Thompson" <thompsma@aecl.ca> wrote in message
> huh?
>> xtkgldocnjer,
Re: IGVuOaJKZXpRUFzR [message #599101 is a reply to message #518591] Thu, 04 March 2010 12:22 Go to previous message
>> huh?
>>> xtkgldocnjer,
Re: IGVuOaJKZXpRUFzR [message #599105 is a reply to message #599101] Thu, 04 March 2010 12:22 Go to previous message
see now?
>>> huh?
>>>> xtkgldocnjer,
Re: IGVuOaJKZXpRUFzR [message #599111 is a reply to message #599105] Thu, 04 March 2010 12:34 Go to previous message
test
> see now?
>>>> huh?
>>>>> xtkgldocnjer,
Re: IGVuOaJKZXpRUFzR [message #599116 is a reply to message #599111] Thu, 04 March 2010 12:34 Go to previous message
please!
news:hmoqui$1hm$1@build.eclipse.org...
> test
>> see now?
>>>> had "display email address" as "NO!".
>>>>> huh?
>>>>>> xtkgldocnjer,
Re: IGVuOaJKZXpRUFzR [message #599127 is a reply to message #599116] Thu, 04 March 2010 12:58 Go to previous message
test1
news:hmoqvo$28m$1@build.eclipse.org...
> please!
>> test
>>> see now?
>>>>>> huh?
>>>>>>> xtkgldocnjer,
Re: IGVuOaJKZXpRUFzR [message #599132 is a reply to message #518678] Thu, 04 March 2010 13:01 Go to previous message
test2
news:hmosc9$p3f$1@build.eclipse.org...
> test1
>> please!
>>> test
>>>> see now?
>>>>>>> huh?
>>>>>>>> xtkgldocnjer,
Re: Need a multi-column list widget for SWT [message #599140 is a reply to message #50421] Thu, 04 March 2010 13:16 Go to previous message
> Hi Martin,
> have a look at
> Sebastian
Re: Need a multi-column list widget for SWT [message #599151 is a reply to message #518690] Thu, 04 March 2010 13:19 Go to previous message
Test
>> Hi Martin,
>> have a look at
>> Sebastian
Previous Topic:Using org.eclipse.swt.accessibility.Accessible in class extending GalleryItem
Next Topic:A BIG "Thank you" for Gallery widget
Current Time: Tue Jul 15 13:27:41 EDT 2025
Powered by FUDForum. Page generated in 0.21214 seconds
