Home » Eclipse Projects » DTP » Sources for DTP 1.6.1 SDK cannot be loaded?
Sources for DTP 1.6.1 SDK cannot be loaded? [message #50283] Mon, 29 September 2008 03:46 Go to next message
Hello All:
I installed DTP 1.6.1 on top of Eclipse 3.3.2 (+EMF, etc) and the DTP
sources cannot be viewed when I click on any DTP class (for example
AdaptableDataSourceProfile), instead I get the Class File Editor. I've
added all DTP plugins as dependencies to one of my projects.
I tried two different Eclipse installations in two different
directories. For one, I unzipped 1.6.1 on top of Eclipse which also had
1.5.2.
For the second I used Software Update to get 1.6.1 to replace 1.5.2. I
used to be able to see 1.5.2 sources but I cannot see the 1.6.1.
Could it be that there is a mismatch in the 1.6.1 SDK between the code
jars and source feature (and src.zip files)? How can I troubleshoot this?
Thank you,
Gary
Re: Sources for DTP 1.6.1 SDK cannot be loaded? [message #50343 is a reply to message #50283] Mon, 29 September 2008 11:44 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hi Gary...
A few questions for you...
1) Are you loading the SDK or runtime/user versions of the DTP build?
2) What's the exact Zip file names you've tried?
The Ganymede packages do not include source, such as the J2EE (JEE) package.
Now... I was able to grab the latest Ganymede SR1 J2EE (JEE) package and the
latest DTP 1.6.1 SDK download. I unzipped the JEE package like normal. And
then I unzipped the DTP 1.6.1 SDK zip into the dropins directory of my new
JEE package installation.
By going that route, I'm able to grab source just fine by importing any of
the DTP packages.
--Fitz
"Gary Gregory" <ggregory@seagullsw.com> wrote in message
news:gbq13v$ml1$1@build.eclipse.org...
> Hello All:
> 1.5.2.
> Thank you,
> Gary
Re: Sources for DTP 1.6.1 SDK cannot be loaded? [message #50370 is a reply to message #50343] Mon, 29 September 2008 13:14 Go to previous messageGo to next message
Hi Brian :
Your message made me creating precise reproducible steps and as I was
doing so I was able to see the source. I am guessing that I unzipped the
non SDK ZIP file. Carbon based error!
Thank you,
Gary
Brian Fitzpatrick wrote:
> Hi Gary...
> the DTP packages.
> --Fitz
>> Hello All:
>> 1.5.2.
>> Thank you,
>> Gary
Re: Sources for DTP 1.6.1 SDK cannot be loaded? [message #50397 is a reply to message #50370] Mon, 29 September 2008 13:38 Go to previous message
No worries. Glad we could help! Just holler if you have more questions.
--Fitz
news:gbr2d6$q2p$1@build.eclipse.org...
> Hi Brian :
> Thank you,
> Gary
>> Hi Gary...
>> package.
>> the
>> And
>> new
>> of
>> the DTP packages.
>> --Fitz
>>> Hello All:
>>> 1.5.2.
>>> this?
>>> Thank you,
>>> Gary
Re: Sources for DTP 1.6.1 SDK cannot be loaded? [message #593265 is a reply to message #50283] Mon, 29 September 2008 11:44 Go to previous message
Hi Gary...
the DTP packages.
--Fitz
> Hello All:
> 1.5.2.
> Thank you,
> Gary
Re: Sources for DTP 1.6.1 SDK cannot be loaded? [message #593273 is a reply to message #50343] Mon, 29 September 2008 13:14 Go to previous message
Hi Brian :
Thank you,
Gary
> Hi Gary...
> the DTP packages.
> --Fitz
>> Hello All:
>> 1.5.2.
>> Thank you,
>> Gary
Re: Sources for DTP 1.6.1 SDK cannot be loaded? [message #593283 is a reply to message #50370] Mon, 29 September 2008 13:38 Go to previous message
--Fitz
> Hi Brian :
> Thank you,
> Gary
>> Hi Gary...
>> package.
>> the
>> And
>> new
>> of
>> the DTP packages.
>> --Fitz
>>> Hello All:
>>> 1.5.2.
>>> this?
>>> Thank you,
>>> Gary
Previous Topic:Any way to map from ConnectionProfile to DatabaseDefinition?
Next Topic:catalogs vs. schemas
Current Time: Sat Oct 25 03:33:30 EDT 2025
Powered by FUDForum. Page generated in 0.04003 seconds
