Re: Why not register an adapterfactory with Platform? [message #495571 is a reply to message #495563] |
Thu, 05 November 2009 11:30 |
Ed Merks Messages: 33217 Registered: July 2009 |
Christophe,
Comments below.
Christophe Bouhier wrote:
> The eclipse adapter framework allows adapter factories to be
> registered, so adaptations of an object can be done on the object
> itself, (Versus dragging around an adapterfactory).
Yes, I always considered that a rather poor design feature because it
only allows a single implementation for the entire application.
> In EMF, I find myself doing this a lot: (Editor needs to be in the
> loop all the time).
No, only the adapter factory needs to be known, not any particular editor.
> Adapter what = editor.getAdapterFactory().adapt(object,
> IItemPropertySource.class);
Why do you need to do this directly?
> Would it be possible to register a (composed) adapterfactory like this?
> IAdapterManager aManager = Platform.getAdapterManager();
> ComposedAdapterFactory adapterFactory = new ComposedAdapterFactory(
> ComposedAdapterFactory.Descriptor.Registry.INSTANCE);
> adapterFactory
> .addAdapterFactory(new
> ResourceItemProviderAdapterFactory());
> adapterFactory
> MyModelItemProviderAdapterFactory());
> adapterFactory
> ReflectiveItemProviderAdapterFactory());
> aManager.registerAdapters(adapterFactory, IMyModelClass1.class);
I'm not sure.
> So with this I could then call:
> IItemPropertySource src =
> ((IAdaptable)object).getAdapter(IItemPropertySource.class);
But your objects don't implement IAdaptable do they?.
> object being of type IMyModelClass1
I doubt registering your local factories globally will be a good thing.
I expect they will result in massive leaks.
> Cheers Christophe
Ed Merks
Re: Why not register an adapterfactory with Platform? [message #495573 is a reply to message #495571] |
Thu, 05 November 2009 11:44 |
Christophe Bouhier Messages: 937 Registered: July 2009 |
follow-up below:
Ed Merks wrote:
> Christophe,
> Comments below.
>> loop all the time).
Yep, ok but my adapter factories in the EMF editor are actually defined
in the Editor itself. So you mean, I could instantiate them anywhere
else correct?
The reason I am doing this, is because I am customizing my
adapterfactories to be able to filter certain features. So while doing
this, I was thinking, why aren't these registered globally, and why do I
need to carry around a factory, if the Platform has an AdapterManager?
Actually, I would like to contribute these customizations somewhere.
Would you mind reviewing this? (Will send it separately)
Well my objects are EMF object, I have been under the assumption that
these implement IAdaptable.... So if it's not, I guess the adapter
pattern in EMF is different from the adapter pattern intended for the
Platform? If so, it's fine I will just use a Singleton pattern to get my
customized adapter factory.
>> Cheers Christophe
FUDForum. Page generated in 0.03723 seconds
