Metadata ClassCode and TypeCode validate? [message #50281] |
Tue, 02 June 2009 22:39 |
OHF org.eclipse.ohf.ihe.xds.metadata.extract.cdar2 ExtractClassCode =
ExtractTypeCode,but I found if I used this method to get the ClassCode and
submited the metadata to the server,error:
[DEBUG][XDSResponseParser.java:119] Loading response in EMF.
[DEBUG][XDSResponseParser.java:178] Failure.
[INFO ][XDSResponseParser.java:238] Error #0
Severity=Error
Code=XDSRegistryMetadataError
Code Context=Classification
(classificationScheme=urn:uuid:41a5887f-8865-4c09-adf7-e3624 75b143a
codingScheme=Connect-a-thon classCodes) of object
urn:uuid:01ae1310-41ae-1040-0a50-001d7dab48a4: The code, 34133-9, is not
found in the configuration for the Affinity Domain
Location= CodeValidation.java
I looked over the codes file,I found that the ClassCode and TypeCode
validating do not use the same codes.
ClassCode'classScheme is urn::uuid:41a5887f-8865-4c09-adf7-e362475b143a
TypeCode'classScheme is urn:uuid:f0306f51-975f-434e-a61c-c59651d33983
How I do this?
Thanks!
FUDForum. Page generated in 0.03008 seconds
